MantisBT - ParaView |
View Issue Details |
0006307 | ParaView | (No Category) | public | 2008-02-07 16:31 | 2009-05-13 13:59 |
Reporter | Ken Moreland | |
Assigned To | Berk Geveci | |
Priority | normal | Severity | minor | Reproducibility | random |
Status | closed | Resolution | fixed | |
Product Version | | |
Target Version | 3.4 | Fixed in Version | 3.4 | |
Project | |
Topic Name | |
Type | |
Summary | 0006307: Pipeline not always updating when time is shifted |
Description | It has been brought to my attention that in certain circumstances the pipeline does not call algorithms multiple times when different time steps are requested of them. I see this problem most often when the output of an algorithm is attached to time shift scale filters (each with a different shift) and the output of those is combined into a multi-input filter. |
Steps To Reproduce | |
Additional Information | I have uploaded an example state file demonstrating the problem. Notice that there is two different colored blocks, and when you hit play the white one should move and then the purple one moves. Instead, nothing happens for the first part of the animation and then they both move for the second part of the animation. If you disable the visibility of the programmable filter, the animation occurs as expected.
This behavior is intermittent, but seems to be reproducible right after you load the state file. |
Tags | No tags attached. |
Relationships | related to | 0008156 | closed | Utkarsh Ayachit | Pipeline updates with shifted time (part deux) |
Attached Files | TimeShiftTest2.pvsm (418,057) 2008-02-07 16:31 https://www.vtk.org/Bug/file/6304/TimeShiftTest2.pvsm
TimeShiftTest1.pvsm (299,274) 2008-08-14 08:33 https://www.vtk.org/Bug/file/6664/TimeShiftTest1.pvsm |
2008-02-07 16:31 | Ken Moreland | New Issue | |
2008-02-07 16:31 | Ken Moreland | File Added: TimeShiftTest1.pvsm | |
2008-02-07 16:31 | Ken Moreland | File Added: TimeShiftTest2.pvsm | |
2008-02-07 16:32 | Ken Moreland | Note Added: 0010427 | |
2008-04-09 18:25 | Ken Moreland | Status | backlog => tabled |
2008-04-09 18:25 | Ken Moreland | Assigned To | => Berk Geveci |
2008-08-14 08:32 | Berk Geveci | File Deleted: TimeShiftTest1.pvsm | |
2008-08-14 08:33 | Berk Geveci | File Added: TimeShiftTest1.pvsm | |
2008-08-14 08:34 | Berk Geveci | Status | tabled => @80@ |
2008-08-14 08:34 | Berk Geveci | Resolution | open => unable to reproduce |
2008-08-14 08:34 | Berk Geveci | Note Added: 0013005 | |
2008-08-14 17:51 | Alan Scott | Status | @80@ => @20@ |
2008-08-14 17:51 | Alan Scott | Resolution | unable to reproduce => reopened |
2008-08-14 17:51 | Alan Scott | Note Added: 0013029 | |
2008-08-15 11:40 | Berk Geveci | Status | @20@ => @80@ |
2008-08-15 11:40 | Berk Geveci | Resolution | reopened => fixed |
2008-08-15 11:40 | Berk Geveci | Note Added: 0013037 | |
2008-08-19 20:15 | Alan Scott | Status | @80@ => closed |
2008-08-19 20:15 | Alan Scott | Note Added: 0013097 | |
2008-11-24 18:52 | Ken Moreland | Relationship added | related to 0008156 |
