(0011020)
Berk Geveci
2008-04-01 16:20
Instead of using parallel writer (which is difficult due to the possibility of null or empty nodes), we could have the composite reader/writer handle this case. Every piece would make sure to assign a different filename and when more than one node have a block for the same node, the file would like the following:
<?xml version="1.0"?>
<VTKFile type="vtkMultiBlockDataSet" version="1.0" byte_order="LittleEndian" compressor="vtkZLibDataCompressor">
<vtkMultiBlockDataSet>
<DataSet index="0" file="mb/mb_0.vtp"/>
<Block index="1">
<DataSet index="0" file="mb/mb_1_0.vtp"/>
<DataSet index="0" file="mb/mb_1_1.vtp"/>
<DataSet index="1" file="mb/mb_2.vtp"/>
</Block>
</vtkMultiBlockDataSet>
</VTKFile>
The reader would deal with appending datasets with the same index. Only datasets that can be appended would be supported (i.e. no structured datasets) |
(0013225)
Utkarsh Ayachit
2008-08-29 08:35
vtkXMLCompositeDataWriter now works in parallel. Each
process now always writes out files with process number encoded into the
filename thus assuring that they are unique. Then when writing out the meta-file
the root process locates all leaf nodes that have non-null datasets on more than
1 process and inserts a multi-piece at that location.
eg. writing out can.ex2 on 3 processes results in following XML
<Block index="0">
<Piece index="0">
<DataSet index="0" file="can/can_0_0.vtu"/>
<DataSet index="1" file="can/can_1_0.vtu"/>
<DataSet index="2" file="can/can_2_0.vtu"/>
</Piece>
<Piece index="1">
<DataSet index="0" file="can/can_0_1.vtu"/>
<DataSet index="1" file="can/can_1_1.vtu"/>
<DataSet index="2" file="can/can_2_1.vtu"/>
</Piece>
</Block>
<Block index="1"/>
<Block index="2"/>
<Block index="3"/>
<Block index="4"/>
<Block index="5"/>
<Block index="6"/>
<Block index="7"/>
</VTKFile>
/cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLCompositeDataWriter.cxx,v <-- VTK/IO/vtkXMLCompositeDataWriter.cxx
new revision: 1.3; previous revision: 1.2
/cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLCompositeDataWriter.h,v <-- VTK/IO/vtkXMLCompositeDataWriter.h
new revision: 1.2; previous revision: 1.1
/cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkXMLPMultiBlockDataWriter.cxx,v <-- VTK/Parallel/vtkXMLPMultiBlockDataWriter.cxx
/cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkXMLPMultiBlockDataWriter.h,v <-- VTK/Parallel/vtkXMLPMultiBlockDataWriter.h
new revision: 1.2; previous revision: 1.1 |
(0013365)
Alan Scott
2008-09-08 17:08
Pushed back for feedback. I sent comments in a separate e-mail, along with an example bad dataset. |
(0015251)
Utkarsh Ayachit
2009-02-20 10:46
Alan,
Can you retest this? I cannot reproduce the problem anymore.
Thanks. |
(0015502)
Alan Scott
2009-03-02 21:34
Tested client/ remote server. |
