MantisBT - ParaView |
View Issue Details |
0007787 | ParaView | (No Category) | public | 2008-10-07 15:03 | 2016-08-12 09:57 |
Reporter | Ken Moreland | |
Assigned To | Berk Geveci | |
Status | closed | Resolution | moved | |
Product Version | | |
Target Version | | Fixed in Version | | |
Project | |
Topic Name | |
Type | |
Summary | 0007787: Streamlines in x-z plane images wrong |
Description | If you run the streamlines filter on 2D image data defined in the x-z direction, then the streamlines come out wrong.
The attached state file demonstrates the problem. Note that running the streamlines directly on the image (left view) gives the wrong result whereas if you convert the data to unstructured grid and run streamlines on that (right view), you get the correct result. |
Steps To Reproduce | |
Additional Information | |
Tags | No tags attached. |
Attached Files | XZGradientStreamlines.pvsm (209,395) 2008-10-07 15:03 https://www.vtk.org/Bug/file/6759/XZGradientStreamlines.pvsm |
2008-10-07 15:03 | Ken Moreland | New Issue | |
2008-10-07 15:03 | Ken Moreland | File Added: XZGradientStreamlines.pvsm | |
2008-10-08 15:50 | Berk Geveci | Status | backlog => tabled |
2008-10-08 15:50 | Berk Geveci | Assigned To | => Berk Geveci |
2009-02-17 14:14 | Utkarsh Ayachit | Category | 3.6 => 3.8 |
2009-05-13 13:41 | Utkarsh Ayachit | Target Version | => 3.8 |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037597 | |
