MantisBT - ParaView | ||||||||||
View Issue Details | ||||||||||
ID | Project | Category | View Status | Date Submitted | Last Update | |||||
0008156 | ParaView | (No Category) | public | 2008-11-24 18:51 | 2016-08-12 09:57 | |||||
Reporter | Ken Moreland | |||||||||
Assigned To | Utkarsh Ayachit | |||||||||
Priority | normal | Severity | minor | Reproducibility | have not tried | |||||
Status | closed | Resolution | moved | |||||||
Platform | OS | OS Version | ||||||||
Product Version | ||||||||||
Target Version | Fixed in Version | |||||||||
Project | ||||||||||
Topic Name | ||||||||||
Type | ||||||||||
Summary | 0008156: Pipeline updates with shifted time (part deux) | |||||||||
Description | There are still some instances where there appears to be problems with pipeline updates when a source with time has fan out, the branches are given temporal shift scales with different shifts, and the branches are then fan in-ed into a multi-input filter. To replicate the problem, do the following. 1. Load the file attached to this bug report (it has a single vertex that moves over time). 2. Add a Temporal Shift Scale with (post) shift = 0. 3. Add a second Temporal Shift Scale (to the original data) with (post) shift = 1. 4. If you play the animation, you will correctly see two points, with one a time step behind the other. 5. Select both Temporal Shift Scale filters and add them to a group datasets filter. 6. With only the group datasets filter visible, play the animation again. You will now see only one point because both are at the same time step. This problem was reported by Eric Monson. | |||||||||
Steps To Reproduce | ||||||||||
Additional Information | ||||||||||
Tags | No tags attached. | |||||||||
Attached Files | ![]() https://www.vtk.org/Bug/file/6866/singlePointTest1.xmf | |||||||||
Issue History | ||||||||||
Date Modified | Username | Field | Change | |||||||
2008-11-24 18:51 | Ken Moreland | New Issue | ||||||||
2008-11-24 18:51 | Ken Moreland | File Added: singlePointTest1.xmf | ||||||||
2008-11-24 18:52 | Ken Moreland | Relationship added | related to 0006307 | |||||||
2008-11-24 19:00 | Ken Moreland | Note Added: 0014169 | ||||||||
2008-11-25 14:30 | Ken Moreland | Note Added: 0014186 | ||||||||
2009-02-17 15:06 | Utkarsh Ayachit | Category | Development => Pending | |||||||
2009-02-20 14:04 | Ken Moreland | Category | Pending => 3.8 | |||||||
2009-05-13 13:40 | Utkarsh Ayachit | Target Version | => 3.8 | |||||||
2010-11-12 14:11 | Dave DeMarle | Status | backlog => tabled | |||||||
2010-11-12 14:11 | Dave DeMarle | Assigned To | => Utkarsh Ayachit | |||||||
2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) | |||||||
2016-08-12 09:57 | Kitware Robot | Note Added: 0037609 | ||||||||
2016-08-12 09:57 | Kitware Robot | Status | expired => closed | |||||||
Notes | |||||
