MantisBT - ParaView
View Issue Details
0008596ParaView(No Category)public2009-02-24 13:252016-08-12 09:57
Alan Scott
Utkarsh Ayachit
normalfeaturealways
closedmoved
0008596: (Venus - Medium) Ability to set time series plots with data from all time steps
Here is a request from a user:
"Here's another feature request. When setting the y-axis there is the option to hard-set the limits. There's another option to auto-set the limits. Unfortunately, the 'auto-set' resets the limit every timestep for a time series. It would be better if 'auto-set' found the min and max over the entire time series and used that for a single unchanging set of limits. Right now, I go into every xy plot and manually hard-set the limits.
Matt
p.s. I hope you can imagine how sore my clicking finger is getting considering the seg faulting...
No tags attached.
parent of 0008683closed Marcus D. Hanwell Axes in charts rescale by default when animating over time
parent of 0008684closed Marcus D. Hanwell Too many button clicks to adjust axes in plots
parent of 0008687closed  Reset range for chart axes
Issue History
2009-02-24 13:25Alan ScottNew Issue
2009-02-26 17:50Alan ScottNote Added: 0015437
2009-02-26 17:50Alan ScottSummaryAbility to set time series plots with data from all time steps => (Venus - Medium) Ability to set time series plots with data from all time steps
2009-03-06 11:23Ken MorelandRelationship addedparent of 0008683
2009-03-06 11:28Ken MorelandRelationship addedparent of 0008684
2009-03-06 11:34Ken MorelandRelationship addedparent of 0008687
2009-05-13 13:39Utkarsh AyachitTarget Version => 3.8
2010-11-12 13:58Dave DeMarleNote Added: 0023213
2010-11-12 13:58Dave DeMarleStatusbacklog => closed
2010-11-12 13:58Dave DeMarleResolutionopen => won't fix
2010-11-12 14:47Dave DeMarleAssigned To => Utkarsh Ayachit
2010-11-12 14:47Dave DeMarleNote Added: 0023226
2010-11-12 14:47Dave DeMarleStatusclosed => @20@
2010-11-12 14:47Dave DeMarleResolutionwon't fix => reopened
2011-06-16 13:10Zack GalbreathCategory => (No Category)
2015-12-23 22:22Alan ScottNote Added: 0035619
2015-12-23 22:22Alan ScottStatusexpired => backlog
2016-08-12 09:57Kitware RobotNote Added: 0037627
2016-08-12 09:57Kitware RobotStatusbacklog => closed
2016-08-12 09:57Kitware RobotResolutionreopened => moved
Notes
(0015437)
Alan Scott
2009-02-26 17:50
This is a request we hear all the time for numerous filters. For instance,try using Can.exo, glyph filter, vectors - accl. Animate. It is junk. Furthermore, the user has to go through every single frame to find ranges. Worse, some datasets don't have the min/max on one frame, thus lots of manual steps and notes...
(0023213)
Dave DeMarle
2010-11-12 13:58
calculating range over time is expensive
(0023226)
Dave DeMarle
2010-11-12 14:47
We should co-opt the infrastructure that colormaps use to do this when the user explicitly asks for it.
(0035619)
Alan Scott
2015-12-23 22:22
Changing to backlog, since I think it still isn't a bad idea. I probably need to look more carefully.
(0037627)
Kitware Robot
2016-08-12 09:57
Resolving issue as `moved`.
