MantisBT - ParaView
View Issue Details
0008683ParaView(No Category)public2009-03-06 11:222010-12-14 09:38
Ken Moreland
Marcus D. Hanwell
normalminorhave not tried
closedfixed
3.103.10
0008683: Axes in charts rescale by default when animating over time
When you are plotting some data that changes over time in a bar chart or x-y plot, the axes by default will readjust at every time step if the ranges change. A better default behavior would be to hold them steady to prevent misleading changes in the plot. Basically, the behavior should follow that of the color map in 3D views.
No tags attached.
related to 0008687closed  Reset range for chart axes
child of 0008596closed Utkarsh Ayachit (Venus - Medium) Ability to set time series plots with data from all time steps
Issue History
2009-03-06 11:22Ken MorelandNew Issue
2009-03-06 11:23Ken MorelandRelationship addedchild of 0008596
2009-03-06 11:35Ken MorelandRelationship addedrelated to 0008687
2009-05-13 13:39Utkarsh AyachitTarget Version => 3.8
2010-11-12 14:01Dave DeMarleNote Added: 0023214
2010-11-12 20:30Marcus D. HanwellAssigned To => Marcus D. Hanwell
2010-11-12 20:30Marcus D. HanwellStatusbacklog => tabled
2010-11-12 20:32Marcus D. HanwellNote Added: 0023233
2010-12-06 16:15Marcus D. HanwellTarget Version3.8 => 3.10
2010-12-08 13:53Marcus D. HanwellNote Added: 0023809
2010-12-08 13:53Marcus D. HanwellStatustabled => @80@
2010-12-08 13:53Marcus D. HanwellFixed in Version => 3.10
2010-12-08 13:53Marcus D. HanwellResolutionopen => fixed
2010-12-14 09:38Ken MorelandNote Added: 0023949
2010-12-14 09:38Ken MorelandStatus@80@ => closed
2011-06-16 13:10Zack GalbreathCategory => (No Category)
Notes
(0023214)
Dave DeMarle
2010-11-12 14:01
Marcus please verify that the chart ranges work like colormaps do: fixed to first known, or user specified range.
(0023233)
Marcus D. Hanwell
2010-11-12 20:32
I didn't see the message as you didn't assign this to me - I can confirm the current behavior is as Ken states. User specified ranges are kept, but when animating the chart is rescaled at each time step.
(0023809)
Marcus D. Hanwell
2010-12-08 13:53
This should now be fixed with commit b1d3d35 - please let me know if it does not conform to your requirements.
(0023949)
Ken Moreland
2010-12-14 09:38
Verified local connection.
