MantisBT - ParaView | ||||||||||
| View Issue Details | ||||||||||
| ID | Project | Category | View Status | Date Submitted | Last Update | |||||
| 0008684 | ParaView | Bug | public | 2009-03-06 11:28 | 2016-08-12 09:57 | |||||
| Reporter | Ken Moreland | |||||||||
| Assigned To | Marcus D. Hanwell | |||||||||
| Priority | normal | Severity | minor | Reproducibility | have not tried | |||||
| Status | closed | Resolution | moved | |||||||
| Platform | OS | OS Version | ||||||||
| Product Version | ||||||||||
| Target Version | Fixed in Version | |||||||||
| Project | Sandia | |||||||||
| Topic Name | ||||||||||
| Type | incorrect functionality | |||||||||
| Summary | 0008684: Too many button clicks to adjust axes in plots | |||||||||
| Description | In the x-y plot and bar chart views, it is a very common operation to adjust the range of the axes. I would say it is more common to adjust them than to not. However, it takes a heck of a lot of button clicks to get to the axes adjustments. (Open view settings, open settings for axes, click on the Layout sub menu, spend several more clicks actually doing the settings, then repeat everything for the other axis.) You should be able to adjust the axes with only a few button clicks. | |||||||||
| Steps To Reproduce | ||||||||||
| Additional Information | ||||||||||
| Tags | No tags attached. | |||||||||
| Relationships |
| Attached Files | ||||||||||
| Issue History | ||||||||||
| Date Modified | Username | Field | Change | |||||||
| 2009-03-06 11:28 | Ken Moreland | New Issue | ||||||||
| 2009-03-06 11:28 | Ken Moreland | Relationship added | child of 0008596 | |||||||
| 2009-03-06 11:28 | Ken Moreland | Status | backlog => tabled | |||||||
| 2009-03-06 11:28 | Ken Moreland | Assigned To | => Utkarsh Ayachit | |||||||
| 2009-03-06 11:31 | Ken Moreland | Note Added: 0015592 | ||||||||
| 2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 | |||||||
| 2009-05-14 20:39 | Utkarsh Ayachit | Category | => Bug | |||||||
| 2009-05-14 20:39 | Utkarsh Ayachit | Target Version | 3.6 => 3.8 | |||||||
| 2011-01-21 13:50 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Marcus D. Hanwell | |||||||
| 2011-01-21 13:50 | Utkarsh Ayachit | Target Version | 3.8 => 4.0 | |||||||
| 2013-01-08 21:32 | Alan Scott | Project | => Sandia | |||||||
| 2013-01-08 21:32 | Alan Scott | Type | => incorrect functionality | |||||||
| 2016-08-12 09:57 | Kitware Robot | Note Added: 0037629 | ||||||||
| 2016-08-12 09:57 | Kitware Robot | Status | backlog => closed | |||||||
| 2016-08-12 09:57 | Kitware Robot | Resolution | open => moved | |||||||
| Notes | |||||
