MantisBT - ParaView | |||||
View Issue Details | |||||
0008830 | ParaView | (No Category) | public | 2009-04-01 13:13 | 2009-05-13 13:45 |
Reporter | Ken Moreland | ||||
Assigned To | Ken Moreland | ||||
Status | closed | Resolution | fixed | ||
Product Version | |||||
Target Version | 3.6 | Fixed in Version | |||
Project | |||||
Topic Name | |||||
Type | |||||
Summary | 0008830: Replacement value not being used in calculator | ||||
Description | If you make an expression in the array calculator that results in invalid values, it replaces those values with 0 instead of the value in the Replacement value box. To replicate the issue, do the following. 1. Create a sphere source. Apply. 2. Add the calculator filter. 3. Set the expression to log10(Normals_X). 4. Change Replacement value to 20. 5. Apply This results in an invalid value wherever the normal points in the negative X direction. These values should be replaced with 20, but they are replaced with 0. | ||||
Steps To Reproduce | |||||
Relationships | |||||
Attached Files | |||||
Issue History | |||||
2009-04-01 13:13 | Ken Moreland | New Issue | |||
2009-04-01 13:15 | Ken Moreland | Status | backlog => tabled | ||
2009-04-01 13:15 | Ken Moreland | Assigned To | => Ken Moreland | ||
2009-04-01 13:19 | Ken Moreland | Note Added: 0015887 | |||
2009-04-01 13:19 | Ken Moreland | Status | tabled => @80@ | ||
2009-04-01 13:19 | Ken Moreland | Resolution | open => fixed | ||
2009-04-03 15:34 | Alan Scott | Note Added: 0015909 | |||
2009-04-03 15:34 | Alan Scott | Status | @80@ => closed | ||
2009-05-13 13:45 | Utkarsh Ayachit | Target Version | => 3.6 | ||
Notes | |||||
