MantisBT - ParaView | ||||||||||
| View Issue Details | ||||||||||
| ID | Project | Category | View Status | Date Submitted | Last Update | |||||
| 0009089 | ParaView | Bug | public | 2009-06-01 12:38 | 2016-08-12 09:57 | |||||
| Reporter | Ken Moreland | |||||||||
| Assigned To | Kitware Robot | |||||||||
| Priority | normal | Severity | minor | Reproducibility | have not tried | |||||
| Status | closed | Resolution | moved | |||||||
| Platform | OS | OS Version | ||||||||
| Product Version | ||||||||||
| Target Version | Fixed in Version | |||||||||
| Project | ||||||||||
| Topic Name | ||||||||||
| Type | ||||||||||
| Summary | 0009089: Extract Block fails when used with temporal data | |||||||||
| Description | A user discovered that the Extract Block filter can fail when you attach to it a filter that requests multiple time steps. It appears that the executive fails to iterate the call over each time step. To replicate, do the following. 1. Load can.ex2. Apply. 2. Add the Extract Block filter. Select a block. Apply. 3. Add the Temporal Interpolator filter to Extract Block. Apply. When you hit apply for the Temporal Interpolator filter, you get a lot of the following error and no data. ERROR: In /Users/kmorel/src/ParaView3/VTK/Filtering/vtkDemandDrivenPipeline.cxx, line 828 vtkCompositeDataPipeline (0x28e25960): Input for connection index 0 on input port index 0 for algorithm vtkExtractBlock(0x28e25270) is of type vtkTemporalDataSet, but a vtkMultiBlockDataSet is required. | |||||||||
| Steps To Reproduce | ||||||||||
| Additional Information | ||||||||||
| Tags | No tags attached. | |||||||||
| Relationships |
| Attached Files | ||||||||||
| Issue History | ||||||||||
| Date Modified | Username | Field | Change | |||||||
| 2009-06-01 12:38 | Ken Moreland | New Issue | ||||||||
| 2009-06-02 02:56 | John Biddiscombe | Relationship added | child of 0006662 | |||||||
| 2016-08-12 09:57 | Kitware Robot | Note Added: 0037650 | ||||||||
| 2016-08-12 09:57 | Kitware Robot | Status | expired => closed | |||||||
| 2016-08-12 09:57 | Kitware Robot | Resolution | open => moved | |||||||
| 2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot | |||||||
| Notes | |||||
