MantisBT - ParaView | |||||
| View Issue Details | |||||
| 0009147 | ParaView | Bug | public | 2009-06-12 16:21 | 2009-12-02 20:38 |
| Reporter | Ken Moreland | ||||
| Assigned To | Ken Moreland | ||||
| Priority | normal | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | fixed | ||
| Product Version | |||||
| Target Version | 3.8 | Fixed in Version | |||
| Project | |||||
| Topic Name | |||||
| Type | |||||
| Summary | 0009147: (SLAC) When saving animation, adjust padding to maintain aspect ratio | ||||
| Description | When you request to save an animation, the save animation dialog box defaults to a resolution different from the actual view size, which is what the user would expect. Instead, there is a 16 pixel buffer removed from the horizontal and vertical directions. Generally, that is not a big issue as there is no direct way to set the view size anyway. Where this can become most noticeable is when it changes the aspect ratio of the screen, which in turn causes the view to appear to zoom in or out for the saved files. The aspect ratio can change if it starts out at a very high ratio. If, for example, the image is much wider than it is high, then subtracting 16 pixels from the width will have a much smaller effect than subtracting it from the height. Rather than subtract a constant 16 pixels from the width and height, it should subtract 16 from the smaller of the two and adjust the amount from the other to maintain a constant aspect ratio. | ||||
| Steps To Reproduce | |||||
| Additional Information | The resolution adjustment occurs in pqAnimationManager::saveAnimation when it subtracts PADDING_COMPENSATION from the size of the view. This should be fixed to maintain a constant aspect ratio. What should NOT be "fixed" is the adjustment later on in pqViewManager::prepareForCapture. This is where the end resolution the user picked is compared against the available pixel case. The padding is used here too, but here it should be maximal to minimize the chance magnification is needed. | ||||
| Relationships | |||||
| Attached Files | |||||
| Issue History | |||||
| 2009-06-12 16:21 | Ken Moreland | New Issue | |||
| 2009-06-12 16:21 | Ken Moreland | Status | backlog => tabled | ||
| 2009-06-12 16:21 | Ken Moreland | Assigned To | => Ken Moreland | ||
| 2009-11-09 15:49 | Ken Moreland | Note Added: 0018378 | |||
| 2009-11-09 15:49 | Ken Moreland | Status | tabled => @80@ | ||
| 2009-11-09 15:49 | Ken Moreland | Resolution | open => fixed | ||
| 2009-12-02 20:38 | Alan Scott | Note Added: 0018680 | |||
| 2009-12-02 20:38 | Alan Scott | Status | @80@ => closed | ||
| Notes | |||||
