MantisBT - ParaView |
| View Issue Details |
| 0009252 | ParaView | Bug | public | 2009-07-10 10:27 | 2011-01-13 17:00 |
| Reporter | Ken Moreland | |
| Assigned To | Utkarsh Ayachit | |
| Priority | high | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | fixed | |
| Platform | | OS | | OS Version | |
| Product Version | | |
| Target Version | 3.6.2 | Fixed in Version | 3.6.2 | |
| Project | |
| Topic Name | |
| Type | |
| Summary | 0009252: Plot over line drops partial arrays |
| Description | The plot over line filter drops partial arrays of multiblock datasets. Instead, it should have them all and turn off the valid index if not in a block that defines the array. To replicate, do the following:
1. Open can.ex2. All variables on. Apply.
2. Open disk_out_ref.ex2. All variables on. Apply.
3. Group Datasets with both readers as input.
4. Plot Over Line.
Notice that the plot only contains variables that are common to both data sets (ObjectId and FileId). Missing are all the important field variables because they are partial in the grouped dataset. |
| Steps To Reproduce | |
| Additional Information | |
| Tags | No tags attached. |
| Relationships | | has duplicate | 0009257 | closed | Ken Moreland | plots don't handle partial arrays | | related to | 0009253 | closed | Julien Finet | Plot On Intersection Curves misbehaving for partial arrays |
| Attached Files | Partial.BUG.9252.patch (15,219) 2009-09-28 09:24 https://www.vtk.org/Bug/file/7491/Partial.BUG.9252.patch |
| Issue History |
| 2009-07-10 10:27 | Ken Moreland | New Issue | |
| 2009-07-10 10:32 | Ken Moreland | Relationship added | related to 0009253 |
| 2009-07-10 10:35 | Ken Moreland | Status | backlog => tabled |
| 2009-07-10 10:35 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
| 2009-07-10 14:33 | Ken Moreland | Relationship added | has duplicate 0009257 |
| 2009-07-15 11:43 | Utkarsh Ayachit | Note Added: 0016875 | |
| 2009-07-15 12:01 | Ken Moreland | Note Added: 0016877 | |
| 2009-09-08 17:00 | Alan Scott | Priority | normal => high |
| 2009-09-28 09:24 | Utkarsh Ayachit | File Added: Partial.BUG.9252.patch | |
| 2009-09-28 09:26 | Utkarsh Ayachit | Note Added: 0017783 | |
| 2009-09-28 09:26 | Utkarsh Ayachit | Target Version | 3.6.2 => 3.8 |
| 2009-09-29 17:13 | Utkarsh Ayachit | Note Added: 0017835 | |
| 2009-09-29 17:13 | Utkarsh Ayachit | Target Version | 3.8 => 3.6.2 |
| 2009-09-29 17:14 | Utkarsh Ayachit | Note Edited: 0017783 | |
| 2009-10-01 10:45 | Utkarsh Ayachit | Note Added: 0017865 | |
| 2009-10-01 10:46 | Utkarsh Ayachit | Note Edited: 0017865 | |
| 2009-10-01 14:25 | Utkarsh Ayachit | Note Added: 0017877 | |
| 2009-10-01 14:25 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2009-10-01 14:25 | Utkarsh Ayachit | Fixed in Version | => 3.6.2 |
| 2009-10-01 14:25 | Utkarsh Ayachit | Resolution | open => fixed |
| 2009-10-02 16:31 | Alan Scott | Note Added: 0017915 | |
| 2009-10-02 16:31 | Alan Scott | Status | @80@ => closed |
| 2011-01-13 17:00 | | Source_changeset_attached | => VTK master a2bd8391 |
| 2011-01-13 17:00 | | Source_changeset_attached | => VTK master 020ef709 |
(0016875)
Utkarsh Ayachit
2009-07-15 11:43
I am not sure we can use the Valid-index. Are you saying we have a valid-index for every data array in the input? |
(0016877)
Ken Moreland
2009-07-15 12:01
You're right. I hadn't thought that through. In that case, I don't know what the right solution is. I guess you'll have to pad the arrays with something. Perhaps NAN if its float or double and 0 otherwise. |
(0017783)
Utkarsh Ayachit
2009-09-28 09:26
(edited on: 2009-09-29 17:14) |
Contrary to what we had thought before, plots don't support NaNs faithfully on all platforms. Consequently, we cannot simply use NaNs in probing for the charting to work as expected for partial arrays.
Given the future of the charts, I am hesitant to spend any time adding any new functionality to the charts.
Hence deferring it until 3.8, unless there are any objections.
(0017835)
Utkarsh Ayachit
2009-09-29 17:13
Dave added support to plot NaNs, this bug is now back ON! :) |
(0017865)
Utkarsh Ayachit
2009-10-01 10:45
(edited on: 2009-10-01 10:46) |
Fixed BUG 0009252 making it possible for vtkCompositeDataProbeFilter to not
remove partial array but instead fill them up with NaNs (or 0) for locations
where those arrays are not present. Default behavior remains unchanged. One has
to turn on a flag for this new behavior to come into play (defaults to ON in
ParaView).
ENH: Added API to vtkDataSetAttributes::FieldList to build a union list of
array. Taking union and intersection on the same instance of FieldList is not
supported.
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- Servers/ServerManager/Resources/filters.xml
new revision: 1.374; previous revision: 1.373
/cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkDataSetAttributes.cxx,v <-- VTK/Filtering/vtkDataSetAttributes.cxx
new revision: 1.31; previous revision: 1.30
/cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkDataSetAttributes.h,v <-- VTK/Filtering/vtkDataSetAttributes.h
new revision: 1.14; previous revision: 1.13
/cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkCompositeDataProbeFilter.cxx,v <-- VTK/Graphics/vtkCompositeDataProbeFilter.cxx
new revision: 1.3; previous revision: 1.2
/cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkCompositeDataProbeFilter.h,v <-- VTK/Graphics/vtkCompositeDataProbeFilter.h
/cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkProbeFilter.cxx,v <-- VTK/Graphics/vtkProbeFilter.cxx
new revision: 1.97; previous revision: 1.96
/cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkProbeFilter.h,v <-- VTK/Graphics/vtkProbeFilter.h
new revision: 1.57; previous revision: 1.56
Pending 3.6.2 commit.
(0017877)
Utkarsh Ayachit
2009-10-01 14:25
new revision: 1.345.2.8; previous revision: 1.345.2.7
new revision: 1.30.6.1; previous revision: 1.30
new revision: 1.12.6.2; previous revision: 1.12.6.1
new revision: 1.2.8.1; previous revision: 1.2
new revision: 1.96.6.1; previous revision: 1.96
new revision: 1.56.8.1; previous revision: 1.56
new revision: 1.2.8.2; previous revision: 1.2.8.1 |
(0017915)
Alan Scott
2009-10-02 16:31
Tested local server, XP, 3.6.2. |
