MantisBT - ParaView |
| View Issue Details |
| 0009408 | ParaView | Feature | public | 2009-08-12 13:02 | 2010-01-22 15:50 |
| Reporter | Ken Moreland | |
| Assigned To | Utkarsh Ayachit | |
| Priority | urgent | Severity | minor | Reproducibility | have not tried |
| Status | closed | Resolution | fixed | |
| Platform | | OS | | OS Version | |
| Product Version | | |
| Target Version | 3.8 | Fixed in Version | 3.8 | |
| Project | |
| Topic Name | |
| Type | |
| Summary | 0009408: Enable zlib compression for image delivery |
| Description | Burlen Loring recently sent an email to the ParaView developer mailing list about comparisons of image transfer rate between using the current SQUIRT algorithm and then using zlib instead. He found that zlib outperformed SQUIRT in both compression rate and overall rendering rate. Thus, we should add zlib as an option (probably the default) for image delivery compression. If it really outperforms SQUIRT in all cases (including higher speed network connections), then perhaps it should replace SQUIRT altogether.
Burlen also noted that performing the SQUIRT-type color reductions also helped zlib be more effective. It may be worthwhile to do the same bit masking before the zlib compression.
A document detailing Burlen's performance measurements is attached. |
| Steps To Reproduce | |
| Additional Information | Efficient remote interactivity is paramount to the near-term needs for large scale visualization at Sandia. Thus, I place a high priority for implementing this for ParaView 3.8. |
| Tags | No tags attached. |
| Relationships | |
| Attached Files | PV3_remote_interactivity.pdf (277,407) 2009-08-12 13:02 https://www.vtk.org/Bug/file/7403/PV3_remote_interactivity.pdf |
| Issue History |
| 2009-08-12 13:02 | Ken Moreland | New Issue | |
| 2009-08-12 13:02 | Ken Moreland | File Added: PV3_remote_interactivity.pdf | |
| 2010-01-19 10:40 | Utkarsh Ayachit | Note Added: 0019191 | |
| 2010-01-19 10:40 | Utkarsh Ayachit | Status | backlog => @80@ |
| 2010-01-19 10:40 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
| 2010-01-19 10:40 | Utkarsh Ayachit | Resolution | open => fixed |
| 2010-01-19 10:40 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2010-01-22 15:50 | Alan Scott | Note Added: 0019278 | |
| 2010-01-22 15:50 | Alan Scott | Status | @80@ => closed |
| 2011-06-16 13:10 | Zack Galbreath | Category | Feature Request => Feature |
