MantisBT - ParaView
View Issue Details
0009591ParaViewBugpublic2009-09-24 15:092009-12-02 19:44
Alan Scott
Utkarsh Ayachit
highminoralways
closedduplicate
3.8
0009591: Clip bounding box is in wrong location.
Open attached file speed.inp. I used ParaView 3.6.0, local server.
Clip.
Notice that the clip bounding box widget is in the wrong location. It should be around our object, and slightly larger.
Now, delete the clip.
In the Display tab, at the bottom, change scale X, Y, Z to 1.0001.
Clip.
Notice that the clip bounding box is correct.
Since this makes clip and slice unusable unless you know the trick, I am marking as major, for 3.8.0.
No tags attached.
duplicate of 0009984closed Utkarsh Ayachit Issue with Implicit Plane Widget
? speed.inp (45,449) 2009-09-24 15:10
https://www.vtk.org/Bug/file/7485/speed.inp
Issue History
2009-09-24 15:09Alan ScottNew Issue
2009-09-24 15:10Alan ScottPrioritynormal => high
2009-09-24 15:10Alan ScottSeveritymajor => minor
2009-09-24 15:10Alan ScottFile Added: speed.inp
2009-12-02 14:14Utkarsh AyachitStatusbacklog => tabled
2009-12-02 14:14Utkarsh AyachitAssigned To => Utkarsh Ayachit
2009-12-02 14:15Utkarsh AyachitRelationship addedduplicate of 0009984
2009-12-02 14:15Utkarsh AyachitDuplicate ID0 => 9984
2009-12-02 14:15Utkarsh AyachitStatustabled => @80@
2009-12-02 14:15Utkarsh AyachitResolutionopen => duplicate
2009-12-02 19:44Alan ScottNote Added: 0018670
2009-12-02 19:44Alan ScottStatus@80@ => closed
Notes
(0018670)
Alan Scott
2009-12-02 19:44
Duplicate.
