MantisBT - ParaView
View Issue Details
0009718ParaViewBugpublic2009-10-15 04:352012-02-20 10:43
Sven Buijssen
Karthik Krishnan
normalminoralways
closedfixed
3.6
3.14
0009718: Sphere preview in Clip by sphere filter depends on coordinates of center if radius < 1
Load bluntfin.vts
Set View direction to +X
Apply Clip filter, Clip type Sphere
Reduce Opacity to < 1
Check "Inside Out" and "Show Sphere"
Set Radius < 1, e.g. 0.5
z-coordinate of center is by default 2.86212563514709
change it to 2.2 and then to 4 and compare size of preview sphere.
Leave z-coodinate at 4 and change x- or y-coordinate, preview sphere will change its size again (not the clipped dataset, though)
Issue is not related to whether or not parallel projection is used.
Tested with PV 3.6.1 (Linux 32-bit) and CVS HEAD (Linux 32-bit)
No tags attached.
related to 0012912closed Kyle Lutz extract cells by region (using sphere) controls
? repro.pvsm (131,865) 2010-04-22 05:28
https://www.vtk.org/Bug/file/8050/repro.pvsm
patch 0001-BUG-Fix-for-BUG-9718.-Fixes-sphere-representation-in.patch (1,572) 2010-12-06 03:46
https://www.vtk.org/Bug/file/8546/0001-BUG-Fix-for-BUG-9718.-Fixes-sphere-representation-in.patch
Issue History
2009-10-15 04:35Sven BuijssenNew Issue
2010-04-22 05:28Sven BuijssenFile Added: repro.pvsm
2010-04-22 05:29Sven BuijssenNote Added: 0020347
2010-12-06 03:46Sven BuijssenFile Added: 0001-BUG-Fix-for-BUG-9718.-Fixes-sphere-representation-in.patch
2010-12-06 03:47Sven BuijssenNote Added: 0023726
2010-12-07 08:11Utkarsh AyachitNote Added: 0023748
2010-12-07 08:11Utkarsh AyachitAssigned To => Karthik Krishnan
2010-12-07 08:11Utkarsh AyachitStatusbacklog => tabled
2012-02-03 15:48Sven BuijssenNote Added: 0028051
2012-02-06 15:22Kyle LutzRelationship addedrelated to 0012912
2012-02-20 10:43Utkarsh AyachitStatusexpired => closed
2012-02-20 10:43Utkarsh AyachitResolutionopen => fixed
2012-02-20 10:43Utkarsh AyachitFixed in Version => 3.14
Notes
(0020347)
Sven Buijssen
2010-04-22 05:29
I've attached a state file to easier reproduce the issue. Change the coordinates of the center of the clip sphere and observe how the sphere size changes beyond what one would expect from its changed distance to the camera position.
Tested with PV 3.8 RC1
(0023726)
Sven Buijssen
2010-12-06 03:47
Actually, the bug presents itself for all radii.
Attached is a patch that resolves the issue by disabling some seemingly
superfluous lines of code. There might be side effects, though,
because, frankly, I don't get the intention of why having those lines added at
all in the first place.
(0023748)
Utkarsh Ayachit
2010-12-07 08:11
Karthik, can you check if the patch look correct? Like Sven says, why would one change the radius as a side effect of setting the center? That doesn't seem right.
(0028051)
Sven Buijssen
2012-02-03 15:48
Any chance the provided patch can get a review? Or do I need to push it to gerrit for that?
