MantisBT - ParaView
View Issue Details
0009829ParaViewBugpublic2009-11-03 13:122010-01-21 17:25
Utkarsh Ayachit
Utkarsh Ayachit
normalminorhave not tried
closedfixed
3.83.8
0009829: Extract selection - Save State doesn't work
1) Add a cone source
2) Use "Select Points Through" to select a point of the cone
3) Apply the ExtractSelection filter. The ExtractSelection1 object now has 1
 Point and 1 Cell on the Information tab of the Object Inspector.
4) File->Save State. Save the state as test.pvsm
5) close paraview
6) open paraview
7) load test.pvsm through File->Load State
No tags attached.
related to 0009702closed Utkarsh Ayachit Python trace error - plot selection
Issue History
2009-11-03 13:12Utkarsh AyachitNew Issue
2010-01-21 11:02Utkarsh AyachitRelationship addedrelated to 0009702
2010-01-21 11:06Utkarsh AyachitNote Added: 0019240
2010-01-21 11:06Utkarsh AyachitStatusbacklog => @80@
2010-01-21 11:06Utkarsh AyachitFixed in Version => 3.8
2010-01-21 11:06Utkarsh AyachitResolutionopen => fixed
2010-01-21 11:06Utkarsh AyachitAssigned To => Utkarsh Ayachit
2010-01-21 11:06Utkarsh AyachitNote Edited: 0019240
2010-01-21 17:25Alan ScottNote Added: 0019250
2010-01-21 17:25Alan ScottStatus@80@ => closed
Notes
(0019240)
Utkarsh Ayachit
2010-01-21 11:06
Fixed pqSelectionInputWidget so that extract selection
filters now work well with state saving and undo-redo.
The solution was to add a slot to pqSelectionInputWidget to be called on accept().
In this slot, it registers the accepted selection source as well as cleans up any obsolete sources.
/cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInputWidget.h,v <-- Qt/Components/pqSelectionInputWidget.h
new revision: 1.4; previous revision: 1.3
/cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInputWidget.cxx,v <-- Qt/Components/pqSelectionInputWidget.cxx
new revision: 1.2; previous revision: 1.1
/cvsroot/ParaView3/ParaView3/Qt/Components/pqNamedWidgets.cxx,v <-- Qt/Components/pqNamedWidgets.cxx
new revision: 1.57; previous revision: 1.56
(0019250)
Alan Scott
2010-01-21 17:25
Tested local server, XP, trunk.
