MantisBT - ParaView |
View Issue Details |
0009867 | ParaView | Bug | public | 2009-11-09 10:50 | 2010-03-03 21:36 |
Reporter | Stephane P | |
Assigned To | David Partyka | |
Priority | normal | Severity | minor | Reproducibility | always |
Status | closed | Resolution | fixed | |
Product Version | Development | |
Target Version | | Fixed in Version | 3.8 | |
Project | ParaViS |
Topic Name | |
Type | |
Summary | 0009867: building server side plugin against install tree (with PARAVIEW_INSTALL_DEVELOPMENT ON) create unloadable plugins |
Description | when building a plugin (a reader for instance) against the install tree of ParaView, the created plugins fails to load in ParaView with the message :
"MyPlugin.so is not a valid Qt Plugin"
ParaView must have been built with the option PARAVIEW_INSTALL_DEVELOPMENT set to ON
The same plugin loads correctly if built against the build tree of ParaView. |
Steps To Reproduce | |
Additional Information | During the configuration process, cmake complains (warnings) that it cannot find safe path for the Qt libraries, which are availbale both from the system and from the ParaView install tree, it might be related. |
Tags | No tags attached. |
Relationships | child of | 0009998 | closed | David Partyka | Installation Issues |
Attached Files | |
2009-11-09 10:50 | Stephane P | New Issue | |
2009-12-05 11:48 | Utkarsh Ayachit | Relationship added | child of 0009998 |
2010-03-03 16:42 | Utkarsh Ayachit | Status | backlog => tabled |
2010-03-03 16:42 | Utkarsh Ayachit | Assigned To | => David Partyka |
2010-03-03 16:42 | Utkarsh Ayachit | Note Added: 0019702 | |
2010-03-03 16:42 | Utkarsh Ayachit | Status | tabled => @80@ |
2010-03-03 16:42 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
2010-03-03 16:42 | Utkarsh Ayachit | Resolution | open => fixed |
2010-03-03 21:36 | Alan Scott | Note Added: 0019705 | |
2010-03-03 21:36 | Alan Scott | Status | @80@ => closed |
2011-06-23 11:44 | Utkarsh Ayachit | Project | => ParaViS |
