1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Adaptors/CTH 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH/CTHAdaptor.h" 48 "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH/vtkCTHSource.h" 49 "/builds/gitlab-kitware-sciviz-ci/Adaptors/CTH/vtkCTHDataArray.h" 50 "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/CTH/vtkPVAdaptorsCTHModule.h" 54 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 56 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCTH-pv5.13.so.5.13
" 57 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCTH-pv5.13.so.1
" 59 if(EXISTS "${file}
" AND 60 NOT IS_SYMLINK "${file}
") 63 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 66 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES 67 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsCTH-pv5.13.so.5.13
" 68 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsCTH-pv5.13.so.1
" 71 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCTH-pv5.13.so.5.13
" 72 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCTH-pv5.13.so.1
" 74 if(EXISTS "${file}
" AND 75 NOT IS_SYMLINK "${file}
") 78 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 79 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 80 if(CMAKE_INSTALL_DO_STRIP) 81 execute_process(COMMAND "/usr/bin/strip
" "${file}
") 87 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 88 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCTH-pv5.13.so
" AND 89 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCTH-pv5.13.so
") 91 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCTH-pv5.13.so
" 92 RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 94 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsCTH-pv5.13.so
") 95 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCTH-pv5.13.so
" AND 96 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCTH-pv5.13.so
") 98 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCTH-pv5.13.so
" 99 OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:
" 100 NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib
") 101 if(CMAKE_INSTALL_DO_STRIP) 102 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCTH-pv5.13.so
