1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Adaptors/Cam
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.0" TYPE FILE FILES
47  "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam/fv_create_data.h"
48  "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam/se_create_data.h"
49  "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam/Grid.h"
50  "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Cam/vtkPVAdaptorsCamModule.h"
51  "/builds/gitlab-kitware-sciviz-ci/Adaptors/Cam/Grid.txx"
52  )
53 endif()
54
55 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
56  foreach(file
57  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv6.0.so.6.0"
58  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv6.0.so.1"
59  )
60  if(EXISTS "${file}" AND
61  NOT IS_SYMLINK "${file}")
62  file(RPATH_CHECK
63  FILE "${file}"
64  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
65  endif()
66  endforeach()
67  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
68  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsCam-pv6.0.so.6.0"
69  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsCam-pv6.0.so.1"
70  )
71  foreach(file
72  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv6.0.so.6.0"
73  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv6.0.so.1"
74  )
75  if(EXISTS "${file}" AND
76  NOT IS_SYMLINK "${file}")
77  file(RPATH_CHANGE
78  FILE "${file}"
79  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
80  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
81  if(CMAKE_INSTALL_DO_STRIP)
82  execute_process(COMMAND "/usr/bin/strip" "${file}")
83  endif()
84  endif()
85  endforeach()
86 endif()
87
88 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
89  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv6.0.so" AND
90  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv6.0.so")
91  file(RPATH_CHECK
92  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv6.0.so"
93  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
94  endif()
95  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsCam-pv6.0.so")
96  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv6.0.so" AND
97  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv6.0.so")
98  file(RPATH_CHANGE
99  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv6.0.so"
100  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
101  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
102  if(CMAKE_INSTALL_DO_STRIP)
103  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsCam-pv6.0.so")
104  endif()
105  endif()
106 endif()
107
108 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xspdxx" OR NOT CMAKE_INSTALL_COMPONENT)
109  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Cam/vtkPVAdaptorsCam.spdx")
110 endif()
111
