1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Adaptors/Pagosa
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Adaptors/Pagosa/vtkPVAdaptorsPagosaModule.h")
47 endif()
48
49 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
50  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkPVAdaptorsPagosa-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkPVAdaptorsPagosa-hierarchy.txt")
51 endif()
52
53 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
54  foreach(file
55  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.13.so.5.13"
56  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.13.so.1"
57  )
58  if(EXISTS "${file}" AND
59  NOT IS_SYMLINK "${file}")
60  file(RPATH_CHECK
61  FILE "${file}"
62  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
63  endif()
64  endforeach()
65  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
66  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsPagosa-pv5.13.so.5.13"
67  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsPagosa-pv5.13.so.1"
68  )
69  foreach(file
70  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.13.so.5.13"
71  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.13.so.1"
72  )
73  if(EXISTS "${file}" AND
74  NOT IS_SYMLINK "${file}")
75  file(RPATH_CHANGE
76  FILE "${file}"
77  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
78  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
79  if(CMAKE_INSTALL_DO_STRIP)
80  execute_process(COMMAND "/usr/bin/strip" "${file}")
81  endif()
82  endif()
83  endforeach()
84 endif()
85
86 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
87  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.13.so" AND
88  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.13.so")
89  file(RPATH_CHECK
90  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.13.so"
91  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
92  endif()
93  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVAdaptorsPagosa-pv5.13.so")
94  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.13.so" AND
95  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.13.so")
96  file(RPATH_CHANGE
97  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.13.so"
98  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
99  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
100  if(CMAKE_INSTALL_DO_STRIP)
101  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVAdaptorsPagosa-pv5.13.so")
102  endif()
103  endif()
104 endif()
105
