CAdaptorAPI.h
3 #ifndef CAdaptorAPI_h
4 #define CAdaptorAPI_h
5
6 #include "vtkPVCatalystModule.h"
7
8 // This code is meant to be used as an API for C simulation
9 // codes. To use with C codes, include this header file. Call the
10 // 'extern "C"' functions as named below for both Fortran and C.
11 // C code should include this header file to get the properly
12 // mangled function names.
13
14 #ifdef __cplusplus
15 extern "C"
16 {
17 #endif
18
19  // call at the start of the simulation
21
22  // call at the end of the simulation
24
25  // this is the function that determines whether or not there
26  // is anything to coprocess this time step
28  int* timeStep, double* time, int* coprocessThisTimeStep);
30  // this function sets needgrid to 1 if it does not have a copy of the grid
31  // it sets needgrid to 0 if it does have a copy of the grid but does not
32  // check if the grid is modified or needs to be updated
33  void VTKPVCATALYST_EXPORT needtocreategrid(int* needGrid);
35  // do the actual coprocessing. it is assumed that the vtkCPDataDescription
36  // has been filled in elsewhere.
38
39 #ifdef __cplusplus
40 } /* extern "C" */
41 #endif
42
43 #endif
void VTKPVCATALYST_EXPORT needtocreategrid(int *needGrid)
void VTKPVCATALYST_EXPORT coprocessorfinalize()
void VTKPVCATALYST_EXPORT coprocess()
#define VTKPVCATALYST_EXPORT
void VTKPVCATALYST_EXPORT coprocessorinitialize()
void VTKPVCATALYST_EXPORT requestdatadescription(int *timeStep, double *time, int *coprocessThisTimeStep)
