1 set(CMAKE_C_COMPILER
"/usr/bin/cc")
2 set(CMAKE_C_COMPILER_ARG1
3 set(CMAKE_C_COMPILER_ID
"GNU")
4 set(CMAKE_C_COMPILER_VERSION
"11.3.1")
5 set(CMAKE_C_COMPILER_VERSION_INTERNAL
6 set(CMAKE_C_COMPILER_WRAPPER
7 set(CMAKE_C_STANDARD_COMPUTED_DEFAULT
"17")
8 set(CMAKE_C_COMPILE_FEATURES
"c_std_90;c_function_prototypes;c_std_99;c_restrict;c_variadic_macros;c_std_11;c_static_assert;c_std_17;c_std_23")
9 set(CMAKE_C90_COMPILE_FEATURES
"c_std_90;c_function_prototypes")
10 set(CMAKE_C99_COMPILE_FEATURES
"c_std_99;c_restrict;c_variadic_macros")
11 set(CMAKE_C11_COMPILE_FEATURES
"c_std_11;c_static_assert")
12 set(CMAKE_C17_COMPILE_FEATURES
"c_std_17")
13 set(CMAKE_C23_COMPILE_FEATURES
"c_std_23")
15 set(CMAKE_C_PLATFORM_ID
"Linux")
16 set(CMAKE_C_SIMULATE_ID
17 set(CMAKE_C_COMPILER_FRONTEND_VARIANT
18 set(CMAKE_C_SIMULATE_VERSION
23 set(CMAKE_AR
"/usr/bin/ar")
24 set(CMAKE_C_COMPILER_AR
"/usr/bin/gcc-ar")
25 set(CMAKE_RANLIB
"/usr/bin/ranlib")
26 set(CMAKE_C_COMPILER_RANLIB
"/usr/bin/gcc-ranlib")
27 set(CMAKE_LINKER
"/usr/bin/ld")
29 set(CMAKE_COMPILER_IS_GNUCC 1)
30 set(CMAKE_C_COMPILER_LOADED 1)
31 set(CMAKE_C_COMPILER_WORKS TRUE)
32 set(CMAKE_C_ABI_COMPILED TRUE)
33 set(CMAKE_COMPILER_IS_MINGW )
34 set(CMAKE_COMPILER_IS_CYGWIN )
35 if(CMAKE_COMPILER_IS_CYGWIN)
40 set(CMAKE_C_COMPILER_ENV_VAR "CC")
42 if(CMAKE_COMPILER_IS_MINGW)
45 set(CMAKE_C_COMPILER_ID_RUN 1)
46 set(CMAKE_C_SOURCE_FILE_EXTENSIONS c;m)
47 set(CMAKE_C_IGNORE_EXTENSIONS h;H;o;O;obj;OBJ;def;DEF;rc;RC)
48 set(CMAKE_C_LINKER_PREFERENCE 10)
50 # Save compiler ABI information. 51 set(CMAKE_C_SIZEOF_DATA_PTR
"8")
52 set(CMAKE_C_COMPILER_ABI
"ELF")
53 set(CMAKE_C_BYTE_ORDER
"LITTLE_ENDIAN")
54 set(CMAKE_C_LIBRARY_ARCHITECTURE
56 if(CMAKE_C_SIZEOF_DATA_PTR)
57 set(CMAKE_SIZEOF_VOID_P
"${CMAKE_C_SIZEOF_DATA_PTR}")
60 if(CMAKE_C_COMPILER_ABI)
61 set(CMAKE_INTERNAL_PLATFORM_ABI
"${CMAKE_C_COMPILER_ABI}")
64 if(CMAKE_C_LIBRARY_ARCHITECTURE)
65 set(CMAKE_LIBRARY_ARCHITECTURE
68 set(CMAKE_C_CL_SHOWINCLUDES_PREFIX
69 if(CMAKE_C_CL_SHOWINCLUDES_PREFIX)
70 set(CMAKE_CL_SHOWINCLUDES_PREFIX
"${CMAKE_C_CL_SHOWINCLUDES_PREFIX}")
77 set(CMAKE_C_IMPLICIT_INCLUDE_DIRECTORIES
"/usr/lib/gcc/x86_64-redhat-linux/11/include;/usr/local/include;/usr/include")
78 set(CMAKE_C_IMPLICIT_LINK_LIBRARIES
"gcc;gcc_s;c;gcc;gcc_s")
79 set(CMAKE_C_IMPLICIT_LINK_DIRECTORIES
"/usr/lib/gcc/x86_64-redhat-linux/11;/usr/lib64;/lib64;/usr/lib")
80 set(CMAKE_C_IMPLICIT_LINK_FRAMEWORK_DIRECTORIES
