/builds/gitlab-kitware-sciviz-ci/build/CMakeDoxygenDefaults.cmake
1 #
2 # DO NOT EDIT! THIS FILE WAS GENERATED BY CMAKE!
3 #
4
5 if(NOT DEFINED DOXYGEN_DOXYFILE_ENCODING)
6  set(DOXYGEN_DOXYFILE_ENCODING UTF-8)
7 endif()
8 if(NOT DEFINED DOXYGEN_PROJECT_NAME)
9  set(DOXYGEN_PROJECT_NAME "My Project")
10 endif()
11 if(NOT DEFINED DOXYGEN_CREATE_SUBDIRS)
12  set(DOXYGEN_CREATE_SUBDIRS NO)
13 endif()
14 if(NOT DEFINED DOXYGEN_ALLOW_UNICODE_NAMES)
15  set(DOXYGEN_ALLOW_UNICODE_NAMES NO)
16 endif()
17 if(NOT DEFINED DOXYGEN_OUTPUT_LANGUAGE)
18  set(DOXYGEN_OUTPUT_LANGUAGE English)
19 endif()
20 if(NOT DEFINED DOXYGEN_BRIEF_MEMBER_DESC)
21  set(DOXYGEN_BRIEF_MEMBER_DESC YES)
22 endif()
23 if(NOT DEFINED DOXYGEN_REPEAT_BRIEF)
24  set(DOXYGEN_REPEAT_BRIEF YES)
25 endif()
26 if(NOT DEFINED DOXYGEN_ABBREVIATE_BRIEF)
27  set(DOXYGEN_ABBREVIATE_BRIEF "The $name class"
28  "The $name widget"
29  "The $name file"
30  is
31  provides
32  specifies
33  contains
34  represents
35  a
36  an
37  the)
39 if(NOT DEFINED DOXYGEN_ALWAYS_DETAILED_SEC)
40  set(DOXYGEN_ALWAYS_DETAILED_SEC NO)
41 endif()
42 if(NOT DEFINED DOXYGEN_INLINE_INHERITED_MEMB)
43  set(DOXYGEN_INLINE_INHERITED_MEMB NO)
44 endif()
45 if(NOT DEFINED DOXYGEN_FULL_PATH_NAMES)
46  set(DOXYGEN_FULL_PATH_NAMES YES)
47 endif()
48 if(NOT DEFINED DOXYGEN_SHORT_NAMES)
49  set(DOXYGEN_SHORT_NAMES NO)
50 endif()
51 if(NOT DEFINED DOXYGEN_JAVADOC_AUTOBRIEF)
52  set(DOXYGEN_JAVADOC_AUTOBRIEF NO)
53 endif()
54 if(NOT DEFINED DOXYGEN_QT_AUTOBRIEF)
55  set(DOXYGEN_QT_AUTOBRIEF NO)
56 endif()
57 if(NOT DEFINED DOXYGEN_MULTILINE_CPP_IS_BRIEF)
58  set(DOXYGEN_MULTILINE_CPP_IS_BRIEF NO)
59 endif()
60 if(NOT DEFINED DOXYGEN_INHERIT_DOCS)
61  set(DOXYGEN_INHERIT_DOCS YES)
62 endif()
63 if(NOT DEFINED DOXYGEN_SEPARATE_MEMBER_PAGES)
64  set(DOXYGEN_SEPARATE_MEMBER_PAGES NO)
65 endif()
66 if(NOT DEFINED DOXYGEN_TAB_SIZE)
67  set(DOXYGEN_TAB_SIZE 4)
68 endif()
69 if(NOT DEFINED DOXYGEN_OPTIMIZE_OUTPUT_FOR_C)
70  set(DOXYGEN_OPTIMIZE_OUTPUT_FOR_C NO)
71 endif()
72 if(NOT DEFINED DOXYGEN_OPTIMIZE_OUTPUT_JAVA)
73  set(DOXYGEN_OPTIMIZE_OUTPUT_JAVA NO)
74 endif()
75 if(NOT DEFINED DOXYGEN_OPTIMIZE_FOR_FORTRAN)
76  set(DOXYGEN_OPTIMIZE_FOR_FORTRAN NO)
77 endif()
78 if(NOT DEFINED DOXYGEN_OPTIMIZE_OUTPUT_VHDL)
79  set(DOXYGEN_OPTIMIZE_OUTPUT_VHDL NO)
80 endif()
81 if(NOT DEFINED DOXYGEN_MARKDOWN_SUPPORT)
82  set(DOXYGEN_MARKDOWN_SUPPORT YES)
83 endif()
84 if(NOT DEFINED DOXYGEN_TOC_INCLUDE_HEADINGS)
85  set(DOXYGEN_TOC_INCLUDE_HEADINGS 0)
86 endif()
87 if(NOT DEFINED DOXYGEN_AUTOLINK_SUPPORT)
88  set(DOXYGEN_AUTOLINK_SUPPORT YES)
89 endif()
90 if(NOT DEFINED DOXYGEN_BUILTIN_STL_SUPPORT)
91  set(DOXYGEN_BUILTIN_STL_SUPPORT NO)
92 endif()
93 if(NOT DEFINED DOXYGEN_CPP_CLI_SUPPORT)
94  set(DOXYGEN_CPP_CLI_SUPPORT NO)
95 endif()
96 if(NOT DEFINED DOXYGEN_SIP_SUPPORT)
97  set(DOXYGEN_SIP_SUPPORT NO)
98 endif()
99 if(NOT DEFINED DOXYGEN_IDL_PROPERTY_SUPPORT)
100  set(DOXYGEN_IDL_PROPERTY_SUPPORT YES)
101 endif()
102 if(NOT DEFINED DOXYGEN_DISTRIBUTE_GROUP_DOC)
103  set(DOXYGEN_DISTRIBUTE_GROUP_DOC NO)
104 endif()
105 if(NOT DEFINED DOXYGEN_GROUP_NESTED_COMPOUNDS)
106  set(DOXYGEN_GROUP_NESTED_COMPOUNDS NO)
107 endif()
108 if(NOT DEFINED DOXYGEN_SUBGROUPING)
109  set(DOXYGEN_SUBGROUPING YES)
110 endif()
111 if(NOT DEFINED DOXYGEN_INLINE_GROUPED_CLASSES)
112  set(DOXYGEN_INLINE_GROUPED_CLASSES NO)
113 endif()
114 if(NOT DEFINED DOXYGEN_INLINE_SIMPLE_STRUCTS)
115  set(DOXYGEN_INLINE_SIMPLE_STRUCTS NO)
116 endif()
117 if(NOT DEFINED DOXYGEN_TYPEDEF_HIDES_STRUCT)
118  set(DOXYGEN_TYPEDEF_HIDES_STRUCT NO)
119 endif()
120 if(NOT DEFINED DOXYGEN_LOOKUP_CACHE_SIZE)
121  set(DOXYGEN_LOOKUP_CACHE_SIZE 0)
122 endif()
123 if(NOT DEFINED DOXYGEN_EXTRACT_ALL)
124  set(DOXYGEN_EXTRACT_ALL NO)
125 endif()
126 if(NOT DEFINED DOXYGEN_EXTRACT_PRIVATE)
127  set(DOXYGEN_EXTRACT_PRIVATE NO)
128 endif()
129 if(NOT DEFINED DOXYGEN_EXTRACT_PACKAGE)
130  set(DOXYGEN_EXTRACT_PACKAGE NO)
131 endif()
132 if(NOT DEFINED DOXYGEN_EXTRACT_STATIC)
133  set(DOXYGEN_EXTRACT_STATIC NO)
134 endif()
135 if(NOT DEFINED DOXYGEN_EXTRACT_LOCAL_CLASSES)
136  set(DOXYGEN_EXTRACT_LOCAL_CLASSES YES)
137 endif()
138 if(NOT DEFINED DOXYGEN_EXTRACT_LOCAL_METHODS)
139  set(DOXYGEN_EXTRACT_LOCAL_METHODS NO)
140 endif()
141 if(NOT DEFINED DOXYGEN_EXTRACT_ANON_NSPACES)
142  set(DOXYGEN_EXTRACT_ANON_NSPACES NO)
143 endif()
144 if(NOT DEFINED DOXYGEN_HIDE_UNDOC_MEMBERS)
145  set(DOXYGEN_HIDE_UNDOC_MEMBERS NO)
146 endif()
147 if(NOT DEFINED DOXYGEN_HIDE_UNDOC_CLASSES)
148  set(DOXYGEN_HIDE_UNDOC_CLASSES NO)
149 endif()
150 if(NOT DEFINED DOXYGEN_HIDE_FRIEND_COMPOUNDS)
151  set(DOXYGEN_HIDE_FRIEND_COMPOUNDS NO)
152 endif()
153 if(NOT DEFINED DOXYGEN_HIDE_IN_BODY_DOCS)
154  set(DOXYGEN_HIDE_IN_BODY_DOCS NO)
155 endif()
156 if(NOT DEFINED DOXYGEN_INTERNAL_DOCS)
157  set(DOXYGEN_INTERNAL_DOCS NO)
158 endif()
159 if(NOT DEFINED DOXYGEN_CASE_SENSE_NAMES)
160  set(DOXYGEN_CASE_SENSE_NAMES YES)
161 endif()
162 if(NOT DEFINED DOXYGEN_HIDE_SCOPE_NAMES)
163  set(DOXYGEN_HIDE_SCOPE_NAMES NO)
164 endif()
165 if(NOT DEFINED DOXYGEN_HIDE_COMPOUND_REFERENCE)
166  set(DOXYGEN_HIDE_COMPOUND_REFERENCE NO)
167 endif()
168 if(NOT DEFINED DOXYGEN_SHOW_INCLUDE_FILES)
169  set(DOXYGEN_SHOW_INCLUDE_FILES YES)
170 endif()
171 if(NOT DEFINED DOXYGEN_SHOW_GROUPED_MEMB_INC)
172  set(DOXYGEN_SHOW_GROUPED_MEMB_INC NO)
173 endif()
174 if(NOT DEFINED DOXYGEN_FORCE_LOCAL_INCLUDES)
175  set(DOXYGEN_FORCE_LOCAL_INCLUDES NO)
176 endif()
177 if(NOT DEFINED DOXYGEN_INLINE_INFO)
178  set(DOXYGEN_INLINE_INFO YES)
179 endif()
180 if(NOT DEFINED DOXYGEN_SORT_MEMBER_DOCS)
181  set(DOXYGEN_SORT_MEMBER_DOCS YES)
182 endif()
183 if(NOT DEFINED DOXYGEN_SORT_BRIEF_DOCS)
184  set(DOXYGEN_SORT_BRIEF_DOCS NO)
185 endif()
186 if(NOT DEFINED DOXYGEN_SORT_MEMBERS_CTORS_1ST)
187  set(DOXYGEN_SORT_MEMBERS_CTORS_1ST NO)
188 endif()
189 if(NOT DEFINED DOXYGEN_SORT_GROUP_NAMES)
190  set(DOXYGEN_SORT_GROUP_NAMES NO)
191 endif()
192 if(NOT DEFINED DOXYGEN_SORT_BY_SCOPE_NAME)
193  set(DOXYGEN_SORT_BY_SCOPE_NAME NO)
194 endif()
195 if(NOT DEFINED DOXYGEN_STRICT_PROTO_MATCHING)
196  set(DOXYGEN_STRICT_PROTO_MATCHING NO)
197 endif()
198 if(NOT DEFINED DOXYGEN_GENERATE_TODOLIST)
199  set(DOXYGEN_GENERATE_TODOLIST YES)
200 endif()
201 if(NOT DEFINED DOXYGEN_GENERATE_TESTLIST)
202  set(DOXYGEN_GENERATE_TESTLIST YES)
203 endif()
204 if(NOT DEFINED DOXYGEN_GENERATE_BUGLIST)
205  set(DOXYGEN_GENERATE_BUGLIST YES)
206 endif()
207 if(NOT DEFINED DOXYGEN_GENERATE_DEPRECATEDLIST)
208  set(DOXYGEN_GENERATE_DEPRECATEDLIST YES)
209 endif()
210 if(NOT DEFINED DOXYGEN_MAX_INITIALIZER_LINES)
211  set(DOXYGEN_MAX_INITIALIZER_LINES 30)
212 endif()
213 if(NOT DEFINED DOXYGEN_SHOW_USED_FILES)
214  set(DOXYGEN_SHOW_USED_FILES YES)
215 endif()
216 if(NOT DEFINED DOXYGEN_SHOW_FILES)
217  set(DOXYGEN_SHOW_FILES YES)
218 endif()
219 if(NOT DEFINED DOXYGEN_SHOW_NAMESPACES)
220  set(DOXYGEN_SHOW_NAMESPACES YES)
221 endif()
222 if(NOT DEFINED DOXYGEN_QUIET)
223  set(DOXYGEN_QUIET NO)
224 endif()
225 if(NOT DEFINED DOXYGEN_WARNINGS)
226  set(DOXYGEN_WARNINGS YES)
227 endif()
228 if(NOT DEFINED DOXYGEN_WARN_IF_UNDOCUMENTED)
229  set(DOXYGEN_WARN_IF_UNDOCUMENTED YES)
230 endif()
231 if(NOT DEFINED DOXYGEN_WARN_IF_DOC_ERROR)
232  set(DOXYGEN_WARN_IF_DOC_ERROR YES)
233 endif()
234 if(NOT DEFINED DOXYGEN_WARN_NO_PARAMDOC)
235  set(DOXYGEN_WARN_NO_PARAMDOC NO)
236 endif()
237 if(NOT DEFINED DOXYGEN_WARN_AS_ERROR)
238  set(DOXYGEN_WARN_AS_ERROR NO)
239 endif()
240 if(NOT DEFINED DOXYGEN_WARN_FORMAT)
241  set(DOXYGEN_WARN_FORMAT "$file:$line: $text")
242 endif()
243 if(NOT DEFINED DOXYGEN_INPUT_ENCODING)
244  set(DOXYGEN_INPUT_ENCODING UTF-8)
245 endif()
246 if(NOT DEFINED DOXYGEN_FILE_PATTERNS)
247  set(DOXYGEN_FILE_PATTERNS *.c
248  *.cc
249  *.cxx
250  *.cpp
251  *.c++
252  *.java
253  *.ii
254  *.ixx
255  *.ipp
256  *.i++
257  *.inl
258  *.idl
259  *.ddl
260  *.odl
261  *.h
262  *.hh
263  *.hxx
264  *.hpp
265  *.h++
266  *.cs
267  *.d
268  *.php
269  *.php4
270  *.php5
271  *.phtml
272  *.inc
273  *.m
274  *.markdown
275  *.md
276  *.mm
277  *.dox
278  *.py
279  *.pyw
280  *.f90
281  *.f95
282  *.f03
283  *.f08
284  *.f
285  *.for
286  *.tcl
287  *.vhd
288  *.vhdl
289  *.ucf
290  *.qsf)
291 endif()
292 if(NOT DEFINED DOXYGEN_RECURSIVE)
293  set(DOXYGEN_RECURSIVE NO)
294 endif()
295 if(NOT DEFINED DOXYGEN_EXCLUDE_SYMLINKS)
296  set(DOXYGEN_EXCLUDE_SYMLINKS NO)
297 endif()
298 if(NOT DEFINED DOXYGEN_EXAMPLE_PATTERNS)
299  set(DOXYGEN_EXAMPLE_PATTERNS *)
300 endif()
301 if(NOT DEFINED DOXYGEN_EXAMPLE_RECURSIVE)
302  set(DOXYGEN_EXAMPLE_RECURSIVE NO)
303 endif()
304 if(NOT DEFINED DOXYGEN_FILTER_SOURCE_FILES)
305  set(DOXYGEN_FILTER_SOURCE_FILES NO)
306 endif()
307 if(NOT DEFINED DOXYGEN_SOURCE_BROWSER)
308  set(DOXYGEN_SOURCE_BROWSER NO)
309 endif()
310 if(NOT DEFINED DOXYGEN_INLINE_SOURCES)
311  set(DOXYGEN_INLINE_SOURCES NO)
312 endif()
313 if(NOT DEFINED DOXYGEN_STRIP_CODE_COMMENTS)
314  set(DOXYGEN_STRIP_CODE_COMMENTS YES)
315 endif()
316 if(NOT DEFINED DOXYGEN_REFERENCED_BY_RELATION)
317  set(DOXYGEN_REFERENCED_BY_RELATION NO)
318 endif()
319 if(NOT DEFINED DOXYGEN_REFERENCES_RELATION)
320  set(DOXYGEN_REFERENCES_RELATION NO)
321 endif()
322 if(NOT DEFINED DOXYGEN_REFERENCES_LINK_SOURCE)
323  set(DOXYGEN_REFERENCES_LINK_SOURCE YES)
324 endif()
325 if(NOT DEFINED DOXYGEN_SOURCE_TOOLTIPS)
326  set(DOXYGEN_SOURCE_TOOLTIPS YES)
327 endif()
328 if(NOT DEFINED DOXYGEN_USE_HTAGS)
329  set(DOXYGEN_USE_HTAGS NO)
330 endif()
331 if(NOT DEFINED DOXYGEN_VERBATIM_HEADERS)
332  set(DOXYGEN_VERBATIM_HEADERS YES)
333 endif()
334 if(NOT DEFINED DOXYGEN_CLANG_ASSISTED_PARSING)
335  set(DOXYGEN_CLANG_ASSISTED_PARSING NO)
336 endif()
337 if(NOT DEFINED DOXYGEN_ALPHABETICAL_INDEX)
338  set(DOXYGEN_ALPHABETICAL_INDEX YES)
339 endif()
340 if(NOT DEFINED DOXYGEN_COLS_IN_ALPHA_INDEX)
341  set(DOXYGEN_COLS_IN_ALPHA_INDEX 5)
342 endif()
343 if(NOT DEFINED DOXYGEN_GENERATE_HTML)
344  set(DOXYGEN_GENERATE_HTML YES)
345 endif()
346 if(NOT DEFINED DOXYGEN_HTML_OUTPUT)
347  set(DOXYGEN_HTML_OUTPUT html)
348 endif()
349 if(NOT DEFINED DOXYGEN_HTML_FILE_EXTENSION)
350  set(DOXYGEN_HTML_FILE_EXTENSION .html)
351 endif()
352 if(NOT DEFINED DOXYGEN_HTML_COLORSTYLE_HUE)
353  set(DOXYGEN_HTML_COLORSTYLE_HUE 220)
354 endif()
355 if(NOT DEFINED DOXYGEN_HTML_COLORSTYLE_SAT)
356  set(DOXYGEN_HTML_COLORSTYLE_SAT 100)
357 endif()
358 if(NOT DEFINED DOXYGEN_HTML_COLORSTYLE_GAMMA)
359  set(DOXYGEN_HTML_COLORSTYLE_GAMMA 80)
360 endif()
361 if(NOT DEFINED DOXYGEN_HTML_TIMESTAMP)
362  set(DOXYGEN_HTML_TIMESTAMP NO)
363 endif()
364 if(NOT DEFINED DOXYGEN_HTML_DYNAMIC_SECTIONS)
365  set(DOXYGEN_HTML_DYNAMIC_SECTIONS NO)
366 endif()
367 if(NOT DEFINED DOXYGEN_HTML_INDEX_NUM_ENTRIES)
368  set(DOXYGEN_HTML_INDEX_NUM_ENTRIES 100)
369 endif()
370 if(NOT DEFINED DOXYGEN_GENERATE_DOCSET)
371  set(DOXYGEN_GENERATE_DOCSET NO)
372 endif()
373 if(NOT DEFINED DOXYGEN_DOCSET_FEEDNAME)
374  set(DOXYGEN_DOCSET_FEEDNAME "Doxygen generated docs")
375 endif()
376 if(NOT DEFINED DOXYGEN_DOCSET_BUNDLE_ID)
377  set(DOXYGEN_DOCSET_BUNDLE_ID org.doxygen.Project)
378 endif()
379 if(NOT DEFINED DOXYGEN_DOCSET_PUBLISHER_ID)
380  set(DOXYGEN_DOCSET_PUBLISHER_ID org.doxygen.Publisher)
381 endif()
382 if(NOT DEFINED DOXYGEN_DOCSET_PUBLISHER_NAME)
383  set(DOXYGEN_DOCSET_PUBLISHER_NAME Publisher)
384 endif()
385 if(NOT DEFINED DOXYGEN_GENERATE_HTMLHELP)
386  set(DOXYGEN_GENERATE_HTMLHELP NO)
387 endif()
388 if(NOT DEFINED DOXYGEN_GENERATE_CHI)
389  set(DOXYGEN_GENERATE_CHI NO)
390 endif()
391 if(NOT DEFINED DOXYGEN_BINARY_TOC)
392  set(DOXYGEN_BINARY_TOC NO)
393 endif()
394 if(NOT DEFINED DOXYGEN_TOC_EXPAND)
395  set(DOXYGEN_TOC_EXPAND NO)
396 endif()
397 if(NOT DEFINED DOXYGEN_GENERATE_QHP)
398  set(DOXYGEN_GENERATE_QHP NO)
399 endif()
400 if(NOT DEFINED DOXYGEN_QHP_NAMESPACE)
401  set(DOXYGEN_QHP_NAMESPACE org.doxygen.Project)
402 endif()
403 if(NOT DEFINED DOXYGEN_QHP_VIRTUAL_FOLDER)
404  set(DOXYGEN_QHP_VIRTUAL_FOLDER doc)
405 endif()
406 if(NOT DEFINED DOXYGEN_GENERATE_ECLIPSEHELP)
407  set(DOXYGEN_GENERATE_ECLIPSEHELP NO)
408 endif()
409 if(NOT DEFINED DOXYGEN_ECLIPSE_DOC_ID)
410  set(DOXYGEN_ECLIPSE_DOC_ID org.doxygen.Project)
411 endif()
412 if(NOT DEFINED DOXYGEN_DISABLE_INDEX)
413  set(DOXYGEN_DISABLE_INDEX NO)
414 endif()
415 if(NOT DEFINED DOXYGEN_GENERATE_TREEVIEW)
416  set(DOXYGEN_GENERATE_TREEVIEW NO)
417 endif()
418 if(NOT DEFINED DOXYGEN_ENUM_VALUES_PER_LINE)
419  set(DOXYGEN_ENUM_VALUES_PER_LINE 4)
420 endif()
421 if(NOT DEFINED DOXYGEN_TREEVIEW_WIDTH)
422  set(DOXYGEN_TREEVIEW_WIDTH 250)
423 endif()
424 if(NOT DEFINED DOXYGEN_EXT_LINKS_IN_WINDOW)
425  set(DOXYGEN_EXT_LINKS_IN_WINDOW NO)
426 endif()
427 if(NOT DEFINED DOXYGEN_FORMULA_FONTSIZE)
428  set(DOXYGEN_FORMULA_FONTSIZE 10)
429 endif()
430 if(NOT DEFINED DOXYGEN_FORMULA_TRANSPARENT)
431  set(DOXYGEN_FORMULA_TRANSPARENT YES)
432 endif()
433 if(NOT DEFINED DOXYGEN_USE_MATHJAX)
434  set(DOXYGEN_USE_MATHJAX NO)
435 endif()
436 if(NOT DEFINED DOXYGEN_MATHJAX_FORMAT)
437  set(DOXYGEN_MATHJAX_FORMAT HTML-CSS)
438 endif()
439 if(NOT DEFINED DOXYGEN_MATHJAX_RELPATH)
440  set(DOXYGEN_MATHJAX_RELPATH http://cdn.mathjax.org/mathjax/latest)
441 endif()
442 if(NOT DEFINED DOXYGEN_SEARCHENGINE)
443  set(DOXYGEN_SEARCHENGINE YES)
444 endif()
445 if(NOT DEFINED DOXYGEN_SERVER_BASED_SEARCH)
446  set(DOXYGEN_SERVER_BASED_SEARCH NO)
447 endif()
448 if(NOT DEFINED DOXYGEN_EXTERNAL_SEARCH)
449  set(DOXYGEN_EXTERNAL_SEARCH NO)
450 endif()
451 if(NOT DEFINED DOXYGEN_SEARCHDATA_FILE)
452  set(DOXYGEN_SEARCHDATA_FILE searchdata.xml)
453 endif()
454 if(NOT DEFINED DOXYGEN_GENERATE_LATEX)
455  set(DOXYGEN_GENERATE_LATEX YES)
456 endif()
457 if(NOT DEFINED DOXYGEN_LATEX_OUTPUT)
458  set(DOXYGEN_LATEX_OUTPUT latex)
459 endif()
460 if(NOT DEFINED DOXYGEN_LATEX_CMD_NAME)
461  set(DOXYGEN_LATEX_CMD_NAME latex)
462 endif()
463 if(NOT DEFINED DOXYGEN_MAKEINDEX_CMD_NAME)
464  set(DOXYGEN_MAKEINDEX_CMD_NAME makeindex)
465 endif()
466 if(NOT DEFINED DOXYGEN_COMPACT_LATEX)
467  set(DOXYGEN_COMPACT_LATEX NO)
468 endif()
469 if(NOT DEFINED DOXYGEN_PAPER_TYPE)
470  set(DOXYGEN_PAPER_TYPE a4)
471 endif()
472 if(NOT DEFINED DOXYGEN_PDF_HYPERLINKS)
473  set(DOXYGEN_PDF_HYPERLINKS YES)
474 endif()
475 if(NOT DEFINED DOXYGEN_USE_PDFLATEX)
476  set(DOXYGEN_USE_PDFLATEX YES)
477 endif()
478 if(NOT DEFINED DOXYGEN_LATEX_BATCHMODE)
479  set(DOXYGEN_LATEX_BATCHMODE NO)
480 endif()
481 if(NOT DEFINED DOXYGEN_LATEX_HIDE_INDICES)
482  set(DOXYGEN_LATEX_HIDE_INDICES NO)
483 endif()
484 if(NOT DEFINED DOXYGEN_LATEX_SOURCE_CODE)
485  set(DOXYGEN_LATEX_SOURCE_CODE NO)
486 endif()
487 if(NOT DEFINED DOXYGEN_LATEX_BIB_STYLE)
488  set(DOXYGEN_LATEX_BIB_STYLE plain)
489 endif()
490 if(NOT DEFINED DOXYGEN_LATEX_TIMESTAMP)
491  set(DOXYGEN_LATEX_TIMESTAMP NO)
492 endif()
493 if(NOT DEFINED DOXYGEN_GENERATE_RTF)
494  set(DOXYGEN_GENERATE_RTF NO)
495 endif()
496 if(NOT DEFINED DOXYGEN_RTF_OUTPUT)
497  set(DOXYGEN_RTF_OUTPUT rtf)
498 endif()
499 if(NOT DEFINED DOXYGEN_COMPACT_RTF)
500  set(DOXYGEN_COMPACT_RTF NO)
501 endif()
502 if(NOT DEFINED DOXYGEN_RTF_HYPERLINKS)
503  set(DOXYGEN_RTF_HYPERLINKS NO)
504 endif()
505 if(NOT DEFINED DOXYGEN_RTF_SOURCE_CODE)
506  set(DOXYGEN_RTF_SOURCE_CODE NO)
507 endif()
508 if(NOT DEFINED DOXYGEN_GENERATE_MAN)
509  set(DOXYGEN_GENERATE_MAN NO)
510 endif()
511 if(NOT DEFINED DOXYGEN_MAN_OUTPUT)
512  set(DOXYGEN_MAN_OUTPUT man)
513 endif()
514 if(NOT DEFINED DOXYGEN_MAN_EXTENSION)
515  set(DOXYGEN_MAN_EXTENSION .3)
516 endif()
517 if(NOT DEFINED DOXYGEN_MAN_LINKS)
518  set(DOXYGEN_MAN_LINKS NO)
519 endif()
520 if(NOT DEFINED DOXYGEN_GENERATE_XML)
521  set(DOXYGEN_GENERATE_XML NO)
522 endif()
523 if(NOT DEFINED DOXYGEN_XML_OUTPUT)
524  set(DOXYGEN_XML_OUTPUT xml)
525 endif()
526 if(NOT DEFINED DOXYGEN_XML_PROGRAMLISTING)
527  set(DOXYGEN_XML_PROGRAMLISTING YES)
528 endif()
529 if(NOT DEFINED DOXYGEN_GENERATE_DOCBOOK)
530  set(DOXYGEN_GENERATE_DOCBOOK NO)
531 endif()
532 if(NOT DEFINED DOXYGEN_DOCBOOK_OUTPUT)
533  set(DOXYGEN_DOCBOOK_OUTPUT docbook)
534 endif()
535 if(NOT DEFINED DOXYGEN_DOCBOOK_PROGRAMLISTING)
536  set(DOXYGEN_DOCBOOK_PROGRAMLISTING NO)
537 endif()
538 if(NOT DEFINED DOXYGEN_GENERATE_AUTOGEN_DEF)
539  set(DOXYGEN_GENERATE_AUTOGEN_DEF NO)
540 endif()
541 if(NOT DEFINED DOXYGEN_GENERATE_PERLMOD)
542  set(DOXYGEN_GENERATE_PERLMOD NO)
543 endif()
544 if(NOT DEFINED DOXYGEN_PERLMOD_LATEX)
545  set(DOXYGEN_PERLMOD_LATEX NO)
546 endif()
547 if(NOT DEFINED DOXYGEN_PERLMOD_PRETTY)
548  set(DOXYGEN_PERLMOD_PRETTY YES)
549 endif()
550 if(NOT DEFINED DOXYGEN_ENABLE_PREPROCESSING)
551  set(DOXYGEN_ENABLE_PREPROCESSING YES)
552 endif()
553 if(NOT DEFINED DOXYGEN_MACRO_EXPANSION)
554  set(DOXYGEN_MACRO_EXPANSION NO)
555 endif()
556 if(NOT DEFINED DOXYGEN_EXPAND_ONLY_PREDEF)
557  set(DOXYGEN_EXPAND_ONLY_PREDEF NO)
558 endif()
559 if(NOT DEFINED DOXYGEN_SEARCH_INCLUDES)
560  set(DOXYGEN_SEARCH_INCLUDES YES)
561 endif()
562 if(NOT DEFINED DOXYGEN_SKIP_FUNCTION_MACROS)
563  set(DOXYGEN_SKIP_FUNCTION_MACROS YES)
564 endif()
565 if(NOT DEFINED DOXYGEN_ALLEXTERNALS)
566  set(DOXYGEN_ALLEXTERNALS NO)
567 endif()
568 if(NOT DEFINED DOXYGEN_EXTERNAL_GROUPS)
569  set(DOXYGEN_EXTERNAL_GROUPS YES)
570 endif()
571 if(NOT DEFINED DOXYGEN_EXTERNAL_PAGES)
572  set(DOXYGEN_EXTERNAL_PAGES YES)
573 endif()
574 if(NOT DEFINED DOXYGEN_PERL_PATH)
575  set(DOXYGEN_PERL_PATH /usr/bin/perl)
576 endif()
577 if(NOT DEFINED DOXYGEN_CLASS_DIAGRAMS)
578  set(DOXYGEN_CLASS_DIAGRAMS YES)
579 endif()
580 if(NOT DEFINED DOXYGEN_HIDE_UNDOC_RELATIONS)
581  set(DOXYGEN_HIDE_UNDOC_RELATIONS YES)
582 endif()
583 if(NOT DEFINED DOXYGEN_HAVE_DOT)
584  set(DOXYGEN_HAVE_DOT NO)
585 endif()
586 if(NOT DEFINED DOXYGEN_DOT_NUM_THREADS)
587  set(DOXYGEN_DOT_NUM_THREADS 0)
588 endif()
589 if(NOT DEFINED DOXYGEN_DOT_FONTNAME)
590  set(DOXYGEN_DOT_FONTNAME Helvetica)
591 endif()
592 if(NOT DEFINED DOXYGEN_DOT_FONTSIZE)
593  set(DOXYGEN_DOT_FONTSIZE 10)
594 endif()
595 if(NOT DEFINED DOXYGEN_CLASS_GRAPH)
596  set(DOXYGEN_CLASS_GRAPH YES)
597 endif()
598 if(NOT DEFINED DOXYGEN_COLLABORATION_GRAPH)
599  set(DOXYGEN_COLLABORATION_GRAPH YES)
600 endif()
601 if(NOT DEFINED DOXYGEN_GROUP_GRAPHS)
602  set(DOXYGEN_GROUP_GRAPHS YES)
603 endif()
604 if(NOT DEFINED DOXYGEN_UML_LOOK)
605  set(DOXYGEN_UML_LOOK NO)
606 endif()
607 if(NOT DEFINED DOXYGEN_UML_LIMIT_NUM_FIELDS)
608  set(DOXYGEN_UML_LIMIT_NUM_FIELDS 10)
609 endif()
610 if(NOT DEFINED DOXYGEN_TEMPLATE_RELATIONS)
611  set(DOXYGEN_TEMPLATE_RELATIONS NO)
612 endif()
613 if(NOT DEFINED DOXYGEN_INCLUDE_GRAPH)
614  set(DOXYGEN_INCLUDE_GRAPH YES)
615 endif()
616 if(NOT DEFINED DOXYGEN_INCLUDED_BY_GRAPH)
617  set(DOXYGEN_INCLUDED_BY_GRAPH YES)
618 endif()
619 if(NOT DEFINED DOXYGEN_CALL_GRAPH)
620  set(DOXYGEN_CALL_GRAPH NO)
621 endif()
622 if(NOT DEFINED DOXYGEN_CALLER_GRAPH)
623  set(DOXYGEN_CALLER_GRAPH NO)
624 endif()
625 if(NOT DEFINED DOXYGEN_GRAPHICAL_HIERARCHY)
626  set(DOXYGEN_GRAPHICAL_HIERARCHY YES)
627 endif()
628 if(NOT DEFINED DOXYGEN_DIRECTORY_GRAPH)
629  set(DOXYGEN_DIRECTORY_GRAPH YES)
630 endif()
631 if(NOT DEFINED DOXYGEN_DOT_IMAGE_FORMAT)
632  set(DOXYGEN_DOT_IMAGE_FORMAT png)
633 endif()
634 if(NOT DEFINED DOXYGEN_INTERACTIVE_SVG)
635  set(DOXYGEN_INTERACTIVE_SVG NO)
636 endif()
637 if(NOT DEFINED DOXYGEN_DOT_GRAPH_MAX_NODES)
638  set(DOXYGEN_DOT_GRAPH_MAX_NODES 50)
639 endif()
640 if(NOT DEFINED DOXYGEN_MAX_DOT_GRAPH_DEPTH)
641  set(DOXYGEN_MAX_DOT_GRAPH_DEPTH 0)
642 endif()
643 if(NOT DEFINED DOXYGEN_DOT_TRANSPARENT)
644  set(DOXYGEN_DOT_TRANSPARENT NO)
645 endif()
646 if(NOT DEFINED DOXYGEN_DOT_MULTI_TARGETS)
647  set(DOXYGEN_DOT_MULTI_TARGETS NO)
648 endif()
649 if(NOT DEFINED DOXYGEN_GENERATE_LEGEND)
650  set(DOXYGEN_GENERATE_LEGEND YES)
651 endif()
652 if(NOT DEFINED DOXYGEN_DOT_CLEANUP)
653  set(DOXYGEN_DOT_CLEANUP YES)
654 endif()
