ParaViewPython-targets.cmake
1 # Generated by CMake
5 endif()
6 cmake_policy(PUSH)
11
14
16 set(_targetsDefined)
17 set(_targetsNotDefined)
18 set(_expectedTargets)
19 foreach(_expectedTarget ParaView::vtkRemotingClientServerStreamPython ParaView::vtkPVVersioningPython ParaView::vtkPVVTKExtensionsCorePython ParaView::vtkRemotingCorePython ParaView::vtkRemotingServerManagerPython ParaView::vtkRemotingViewsPython ParaView::vtkRemotingViewsPythonPython ParaView::vtkRemotingServerManagerPythonPython ParaView::vtkPVVTKExtensionsPointsPython ParaView::vtkPVVTKExtensionsIOCorePython ParaView::vtkPVVTKExtensionsIOSPCTHPython ParaView::vtkPVVTKExtensionsIOCGNSWriterPython ParaView::vtkPVVTKExtensionsIOParallelCGNSWriterPython ParaView::vtkPVVTKExtensionsIOImagePython ParaView::vtkPVVTKExtensionsIOExodusPython ParaView::vtkPVVTKExtensionsIOEnSightPython ParaView::vtkPVVTKExtensionsIOAMRPython ParaView::vtkPVVTKExtensionsFiltersStatisticsPython ParaView::vtkPVVTKExtensionsFiltersPythonPython ParaView::vtkPVVTKExtensionsFiltersGeneralPython ParaView::vtkPVVTKExtensionsFiltersParallelDIY2Python ParaView::vtkPVVTKExtensionsFiltersParallelPython ParaView::vtkPVVTKExtensionsFiltersMaterialInterfacePython ParaView::vtkPVVTKExtensionsFiltersGeneralMPIPython ParaView::vtkPVVTKExtensionsFiltersFlowPathsPython ParaView::vtkPVVTKExtensionsExtractionPythonPython ParaView::vtkRemotingImportPython ParaView::vtkPVVTKExtensionsIOImportPython ParaView::vtkRemotingExportPython ParaView::vtkPVVTKExtensionsExtractionPython ParaView::vtkRemotingLivePython ParaView::vtkRemotingMiscPython ParaView::vtkPVVTKExtensionsIOGeneralPython ParaView::vtkPVVTKExtensionsAMRPython ParaView::vtkRemotingApplicationPython ParaView::vtkRemotingSettingsPython ParaView::vtkRemotingAnimationPython ParaView::vtkPVVTKExtensionsInteractionStylePython ParaView::vtkPVVTKExtensionsFiltersRenderingPython ParaView::vtkPVVTKExtensionsMiscPython ParaView::vtkPVCatalystPython ParaView::vtkPVPythonCatalystPython ParaView::vtkPVClientWebPython ParaView::vtkPVInSituPython ParaView::pvpythonmodules)
23  endif()
26  endif()
27 endforeach()
29  unset(_targetsDefined)
30  unset(_targetsNotDefined)
31  unset(_expectedTargets)
33  cmake_policy(POP)
34  return()
35 endif()
39 unset(_targetsDefined)
40 unset(_targetsNotDefined)
41 unset(_expectedTargets)
42
43
44 # Compute the installation prefix relative to this file.
45 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}" PATH)
46 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
47 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
48 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
49 if(_IMPORT_PREFIX STREQUAL "/")
50  set(_IMPORT_PREFIX "")
51 endif()
52
53 # Create imported target ParaView::vtkRemotingClientServerStreamPython
54 add_library(ParaView::vtkRemotingClientServerStreamPython MODULE IMPORTED)
55
56 # Create imported target ParaView::vtkPVVersioningPython
57 add_library(ParaView::vtkPVVersioningPython MODULE IMPORTED)
58
59 # Create imported target ParaView::vtkPVVTKExtensionsCorePython
60 add_library(ParaView::vtkPVVTKExtensionsCorePython MODULE IMPORTED)
61
62 # Create imported target ParaView::vtkRemotingCorePython
63 add_library(ParaView::vtkRemotingCorePython MODULE IMPORTED)
64
65 # Create imported target ParaView::vtkRemotingServerManagerPython
66 add_library(ParaView::vtkRemotingServerManagerPython MODULE IMPORTED)
67
68 # Create imported target ParaView::vtkRemotingViewsPython
69 add_library(ParaView::vtkRemotingViewsPython MODULE IMPORTED)
70
71 # Create imported target ParaView::vtkRemotingViewsPythonPython
72 add_library(ParaView::vtkRemotingViewsPythonPython MODULE IMPORTED)
73
74 # Create imported target ParaView::vtkRemotingServerManagerPythonPython
75 add_library(ParaView::vtkRemotingServerManagerPythonPython MODULE IMPORTED)
76
77 # Create imported target ParaView::vtkPVVTKExtensionsPointsPython
78 add_library(ParaView::vtkPVVTKExtensionsPointsPython MODULE IMPORTED)
79
80 # Create imported target ParaView::vtkPVVTKExtensionsIOCorePython
81 add_library(ParaView::vtkPVVTKExtensionsIOCorePython MODULE IMPORTED)
82
83 # Create imported target ParaView::vtkPVVTKExtensionsIOSPCTHPython
84 add_library(ParaView::vtkPVVTKExtensionsIOSPCTHPython MODULE IMPORTED)
85
86 # Create imported target ParaView::vtkPVVTKExtensionsIOCGNSWriterPython
87 add_library(ParaView::vtkPVVTKExtensionsIOCGNSWriterPython MODULE IMPORTED)
88
89 # Create imported target ParaView::vtkPVVTKExtensionsIOParallelCGNSWriterPython
90 add_library(ParaView::vtkPVVTKExtensionsIOParallelCGNSWriterPython MODULE IMPORTED)
91
92 # Create imported target ParaView::vtkPVVTKExtensionsIOImagePython
93 add_library(ParaView::vtkPVVTKExtensionsIOImagePython MODULE IMPORTED)
94
95 # Create imported target ParaView::vtkPVVTKExtensionsIOExodusPython
96 add_library(ParaView::vtkPVVTKExtensionsIOExodusPython MODULE IMPORTED)
97
98 # Create imported target ParaView::vtkPVVTKExtensionsIOEnSightPython
99 add_library(ParaView::vtkPVVTKExtensionsIOEnSightPython MODULE IMPORTED)
100
101 # Create imported target ParaView::vtkPVVTKExtensionsIOAMRPython
102 add_library(ParaView::vtkPVVTKExtensionsIOAMRPython MODULE IMPORTED)
103
104 # Create imported target ParaView::vtkPVVTKExtensionsFiltersStatisticsPython
105 add_library(ParaView::vtkPVVTKExtensionsFiltersStatisticsPython MODULE IMPORTED)
106
107 # Create imported target ParaView::vtkPVVTKExtensionsFiltersPythonPython
108 add_library(ParaView::vtkPVVTKExtensionsFiltersPythonPython MODULE IMPORTED)
109
110 # Create imported target ParaView::vtkPVVTKExtensionsFiltersGeneralPython
111 add_library(ParaView::vtkPVVTKExtensionsFiltersGeneralPython MODULE IMPORTED)
112
113 # Create imported target ParaView::vtkPVVTKExtensionsFiltersParallelDIY2Python
114 add_library(ParaView::vtkPVVTKExtensionsFiltersParallelDIY2Python MODULE IMPORTED)
115
116 # Create imported target ParaView::vtkPVVTKExtensionsFiltersParallelPython
117 add_library(ParaView::vtkPVVTKExtensionsFiltersParallelPython MODULE IMPORTED)
118
119 # Create imported target ParaView::vtkPVVTKExtensionsFiltersMaterialInterfacePython
120 add_library(ParaView::vtkPVVTKExtensionsFiltersMaterialInterfacePython MODULE IMPORTED)
121
122 # Create imported target ParaView::vtkPVVTKExtensionsFiltersGeneralMPIPython
123 add_library(ParaView::vtkPVVTKExtensionsFiltersGeneralMPIPython MODULE IMPORTED)
124
125 # Create imported target ParaView::vtkPVVTKExtensionsFiltersFlowPathsPython
126 add_library(ParaView::vtkPVVTKExtensionsFiltersFlowPathsPython MODULE IMPORTED)
127
128 # Create imported target ParaView::vtkPVVTKExtensionsExtractionPythonPython
129 add_library(ParaView::vtkPVVTKExtensionsExtractionPythonPython MODULE IMPORTED)
130
131 # Create imported target ParaView::vtkRemotingImportPython
132 add_library(ParaView::vtkRemotingImportPython MODULE IMPORTED)
133
134 # Create imported target ParaView::vtkPVVTKExtensionsIOImportPython
135 add_library(ParaView::vtkPVVTKExtensionsIOImportPython MODULE IMPORTED)
136
137 # Create imported target ParaView::vtkRemotingExportPython
138 add_library(ParaView::vtkRemotingExportPython MODULE IMPORTED)
139
140 # Create imported target ParaView::vtkPVVTKExtensionsExtractionPython
141 add_library(ParaView::vtkPVVTKExtensionsExtractionPython MODULE IMPORTED)
142
143 # Create imported target ParaView::vtkRemotingLivePython
144 add_library(ParaView::vtkRemotingLivePython MODULE IMPORTED)
145
146 # Create imported target ParaView::vtkRemotingMiscPython
147 add_library(ParaView::vtkRemotingMiscPython MODULE IMPORTED)
148
149 # Create imported target ParaView::vtkPVVTKExtensionsIOGeneralPython
150 add_library(ParaView::vtkPVVTKExtensionsIOGeneralPython MODULE IMPORTED)
151
152 # Create imported target ParaView::vtkPVVTKExtensionsAMRPython
153 add_library(ParaView::vtkPVVTKExtensionsAMRPython MODULE IMPORTED)
154
155 # Create imported target ParaView::vtkRemotingApplicationPython
156 add_library(ParaView::vtkRemotingApplicationPython MODULE IMPORTED)
157
158 # Create imported target ParaView::vtkRemotingSettingsPython
159 add_library(ParaView::vtkRemotingSettingsPython MODULE IMPORTED)
160
161 # Create imported target ParaView::vtkRemotingAnimationPython
162 add_library(ParaView::vtkRemotingAnimationPython MODULE IMPORTED)
163
164 # Create imported target ParaView::vtkPVVTKExtensionsInteractionStylePython
165 add_library(ParaView::vtkPVVTKExtensionsInteractionStylePython MODULE IMPORTED)
166
167 # Create imported target ParaView::vtkPVVTKExtensionsFiltersRenderingPython
168 add_library(ParaView::vtkPVVTKExtensionsFiltersRenderingPython MODULE IMPORTED)
169
170 # Create imported target ParaView::vtkPVVTKExtensionsMiscPython
171 add_library(ParaView::vtkPVVTKExtensionsMiscPython MODULE IMPORTED)
172
173 # Create imported target ParaView::vtkPVCatalystPython
174 add_library(ParaView::vtkPVCatalystPython MODULE IMPORTED)
175
176 # Create imported target ParaView::vtkPVPythonCatalystPython
177 add_library(ParaView::vtkPVPythonCatalystPython MODULE IMPORTED)
178
179 # Create imported target ParaView::vtkPVClientWebPython
180 add_library(ParaView::vtkPVClientWebPython MODULE IMPORTED)
181
182 # Create imported target ParaView::vtkPVInSituPython
183 add_library(ParaView::vtkPVInSituPython MODULE IMPORTED)
184
185 # Create imported target ParaView::pvpythonmodules
186 add_library(ParaView::pvpythonmodules INTERFACE IMPORTED)
187
188 set_target_properties(ParaView::pvpythonmodules PROPERTIES
189  INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-5.13/pvpythonmodules"
190  INTERFACE_LINK_LIBRARIES "VTK::vtkpythonmodules"
191 )
192
193 if(CMAKE_VERSION VERSION_LESS 3.0.0)
194  message(FATAL_ERROR "This file relies on consumers using CMake 3.0.0 or greater.")
195 endif()
196
197 # Load information for each installed configuration.
198 get_filename_component(_DIR "${CMAKE_CURRENT_LIST_FILE}" PATH)
199 file(GLOB CONFIG_FILES "${_DIR}/ParaViewPython-targets-*.cmake")
200 foreach(f ${CONFIG_FILES})
201  include(${f})
202 endforeach()
203
204 # Cleanup temporary variables.
205 set(_IMPORT_PREFIX)
206
207 # Loop over all imported files and verify that they actually exist
208 foreach(target ${_IMPORT_CHECK_TARGETS} )
209  foreach(file ${_IMPORT_CHECK_FILES_FOR_${target}} )
210  if(NOT EXISTS "${file}" )
211  message(FATAL_ERROR "The imported target \"${target}\" references the file
212  \"${file}\"
213 but this file does not exist. Possible reasons include:
214 * The file was deleted, renamed, or moved to another location.
215 * An install or uninstall procedure did not complete successfully.
216 * The installation package was faulty and contained
217  \"${CMAKE_CURRENT_LIST_FILE}\"
218 but not all the files it references.
219 ")
220  endif()
221  endforeach()
222  unset(_IMPORT_CHECK_FILES_FOR_${target})
223 endforeach()
224 unset(_IMPORT_CHECK_TARGETS)
225
226 # Make sure the targets which have been exported in some other
227 # export set exist.
228 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
229 foreach(_target "VTK::vtkpythonmodules" )
230  if(NOT TARGET "${_target}" )
231  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
232  endif()
233 endforeach()
234
235 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
236  if(CMAKE_FIND_PACKAGE_NAME)
237  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
238  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
239  else()
240  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
241  endif()
242 endif()
243 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
244
245 # Commands beyond this point should not need to know the version.
246 set(CMAKE_IMPORT_FILE_VERSION)
247 cmake_policy(POP)
on
version
#define VERSION
Definition: jconfigint.h:17
