ParaViewPythonIncubator-targets.cmake
1 # Generated by CMake
5 endif()
6 cmake_policy(PUSH)
11
14
16 set(_targetsDefined)
17 set(_targetsNotDefined)
18 set(_expectedTargets)
19 foreach(_expectedTarget ParaView::vtkPVIncubatorCorePython ParaView::pvincubatorpythonmodules)
23  endif()
26  endif()
27 endforeach()
29  unset(_targetsDefined)
30  unset(_targetsNotDefined)
31  unset(_expectedTargets)
33  cmake_policy(POP)
34  return()
35 endif()
39 unset(_targetsDefined)
40 unset(_targetsNotDefined)
41 unset(_expectedTargets)
42
43
44 # Compute the installation prefix relative to this file.
45 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}" PATH)
46 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
47 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
48 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}" PATH)
49 if(_IMPORT_PREFIX STREQUAL "/")
50  set(_IMPORT_PREFIX "")
51 endif()
52
53 # Create imported target ParaView::vtkPVIncubatorCorePython
54 add_library(ParaView::vtkPVIncubatorCorePython MODULE IMPORTED)
55
56 # Create imported target ParaView::pvincubatorpythonmodules
57 add_library(ParaView::pvincubatorpythonmodules INTERFACE IMPORTED)
58
59 set_target_properties(ParaView::pvincubatorpythonmodules PROPERTIES
60  INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-5.13/pvincubatorpythonmodules"
61  INTERFACE_LINK_LIBRARIES "VTK::vtkpythonmodules"
62 )
63
64 if(CMAKE_VERSION VERSION_LESS 3.0.0)
65  message(FATAL_ERROR "This file relies on consumers using CMake 3.0.0 or greater.")
66 endif()
67
68 # Load information for each installed configuration.
69 get_filename_component(_DIR "${CMAKE_CURRENT_LIST_FILE}" PATH)
70 file(GLOB CONFIG_FILES "${_DIR}/ParaViewPythonIncubator-targets-*.cmake")
71 foreach(f ${CONFIG_FILES})
72  include(${f})
73 endforeach()
74
75 # Cleanup temporary variables.
76 set(_IMPORT_PREFIX)
77
78 # Loop over all imported files and verify that they actually exist
79 foreach(target ${_IMPORT_CHECK_TARGETS} )
80  foreach(file ${_IMPORT_CHECK_FILES_FOR_${target}} )
81  if(NOT EXISTS "${file}" )
82  message(FATAL_ERROR "The imported target \"${target}\" references the file
83  \"${file}\"
84 but this file does not exist. Possible reasons include:
85 * The file was deleted, renamed, or moved to another location.
86 * An install or uninstall procedure did not complete successfully.
87 * The installation package was faulty and contained
88  \"${CMAKE_CURRENT_LIST_FILE}\"
89 but not all the files it references.
90 ")
91  endif()
92  endforeach()
93  unset(_IMPORT_CHECK_FILES_FOR_${target})
94 endforeach()
95 unset(_IMPORT_CHECK_TARGETS)
96
97 # Make sure the targets which have been exported in some other
98 # export set exist.
99 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
100 foreach(_target "VTK::vtkpythonmodules" )
101  if(NOT TARGET "${_target}" )
102  set(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets "${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets} ${_target}")
103  endif()
104 endforeach()
105
106 if(DEFINED ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
107  if(CMAKE_FIND_PACKAGE_NAME)
108  set( ${CMAKE_FIND_PACKAGE_NAME}_FOUND FALSE)
109  set( ${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
110  else()
111  message(FATAL_ERROR "The following imported targets are referenced, but are missing: ${${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets}")
112  endif()
113 endif()
114 unset(${CMAKE_FIND_PACKAGE_NAME}_NOT_FOUND_MESSAGE_targets)
115
116 # Commands beyond this point should not need to know the version.
117 set(CMAKE_IMPORT_FILE_VERSION)
118 cmake_policy(POP)
on
version
#define VERSION
Definition: jconfigint.h:17
