2 # `vtkModuleWrapClientServer` 4 This module includes logic necessary in
order to wrap VTK modules
using 5 ParaView
's ClientServer "language". This allows for classes in the module to be 6 used as proxies between ParaView client and server programs. 10 ## Wrapping a single module 12 This function generates the wrapped sources for a module. It places the list of 13 generated source files and classes in variables named in the second and third 14 arguments, respectively. 17 _vtk_module_wrap_client_server_sources(<module> <sources> <classes>) 22 cmake_policy(SET CMP0053 NEW) 25 cmake_policy(SET CMP0116 NEW) 28 function (_vtk_module_wrap_client_server_sources module sources classes) 29 _vtk_module_get_module_property("${module}" 30 PROPERTY "exclude_wrap" 31 VARIABLE _vtk_client_server_exclude_wrap) 32 if (_vtk_client_server_exclude_wrap) 35 _vtk_module_get_module_property("${module}" 36 PROPERTY "client_server_exclude" 37 VARIABLE _vtk_client_server_exclude) 38 if (_vtk_client_server_exclude) 42 set(_vtk_client_server_args_file "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${_vtk_client_server_library_name}-client-server.$<CONFIGURATION>.args") 44 set(_vtk_client_server_genex_allowed 1) 45 if (CMAKE_VERSION VERSION_LESS "3.19") 46 get_property(_vtk_client_server_target_type 47 TARGET "${_vtk_client_server_target_name}" 49 if (_vtk_client_server_target_type STREQUAL "INTERFACE_LIBRARY") 50 set(_vtk_client_server_genex_allowed 0) 54 set(_vtk_client_server_genex_compile_definitions "") 55 set(_vtk_client_server_genex_include_directories "") 56 if (_vtk_client_server_genex_allowed) 57 set(_vtk_client_server_genex_compile_definitions 58 "$<TARGET_PROPERTY:${_vtk_client_server_target_name},COMPILE_DEFINITIONS>") 59 set(_vtk_client_server_genex_include_directories 60 "$<TARGET_PROPERTY:${_vtk_client_server_target_name},INCLUDE_DIRECTORIES>") 61 set(_vtk_client_server_genex_interface_compile_definitions 62 "$<TARGET_PROPERTY:${_vtk_client_server_target_name},INTERFACE_COMPILE_DEFINITIONS>") 63 set(_vtk_client_server_genex_interface_include_directories 64 "$<TARGET_PROPERTY:${_vtk_client_server_target_name},INTERFACE_INCLUDE_DIRECTORIES>") 65 set(_vtk_client_server_genex_compile_definitions_all 66 "$<IF:$<BOOL:${_vtk_client_server_genex_compile_definitions}>,${_vtk_client_server_genex_compile_definitions},${_vtk_client_server_genex_interface_compile_definitions}>") 67 set(_vtk_client_server_genex_include_directories_all 68 "$<IF:$<BOOL:${_vtk_client_server_genex_include_directories}>,${_vtk_client_server_genex_include_directories},${_vtk_client_server_genex_interface_include_directories}>") 71 if (NOT DEFINED ENV{CI}) 72 message(AUTHOR_WARNING 73 "ClientServer wrapping is not using target-local compile definitions " 74 "or include directories. This may affect generation of the Client " 75 "Server wrapper sources for the ${module} module. Use CMake 3.19+ to " 76 "guarantee intended behavior.") 80 OUTPUT "${_vtk_client_server_args_file}" 81 CONTENT "$<$<BOOL:${_vtk_client_server_genex_compile_definitions_all}>:\n-D\'$<JOIN:${_vtk_client_server_genex_compile_definitions_all},\'\n-D\'>\'>\n 82 $<$<BOOL:${_vtk_client_server_genex_include_directories_all}>:\n-I\'$<JOIN:${_vtk_client_server_genex_include_directories_all},\'\n-I\'>\'>\n") 84 _vtk_module_get_module_property("${module}" 86 VARIABLE _vtk_client_server_hierarchy_file) 88 get_property(_vtk_client_server_is_imported 89 TARGET "${_vtk_client_server_target_name}" 91 if (_vtk_client_server_is_imported OR CMAKE_GENERATOR MATCHES "Ninja") 92 set(_vtk_client_server_command_depend "${_vtk_client_server_hierarchy_file}") 94 if (TARGET "${_vtk_client_server_library_name}-hierarchy") 95 set(_vtk_client_server_command_depend "${_vtk_client_server_library_name}-hierarchy") 98 "The ${module} hierarchy file is attached to a non-imported target " 99 "and a hierarchy target " 100 "(${_vtk_client_server_library_name}-hierarchy) is missing.") 104 # create directory for wrapped source files 105 file(MAKE_DIRECTORY "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${_vtk_client_server_library_name}CS") 107 set(_vtk_client_server_sources) 109 _vtk_module_get_module_property("${module}" 111 VARIABLE _vtk_client_server_headers) 112 set(_vtk_client_server_classes) 113 foreach (_vtk_client_server_header IN LISTS _vtk_client_server_headers) 114 get_filename_component(_vtk_client_server_basename "${_vtk_client_server_header}" NAME_WE) 115 list(APPEND _vtk_client_server_classes 116 "${_vtk_client_server_basename}") 118 set(_vtk_client_server_source_output 119 "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${_vtk_client_server_library_name}CS/${_vtk_client_server_basename}ClientServer.cxx") 120 set(_vtk_client_server_depfile_genex 121 "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${_vtk_client_server_library_name}CS/${_vtk_client_server_basename}ClientServer.cxx.$<CONFIG>.d") 122 set(_vtk_client_server_depfile_nogenex 123 "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${_vtk_client_server_library_name}CS/${_vtk_client_server_basename}ClientServer.cxx.d") 124 list(APPEND _vtk_client_server_sources 125 "${_vtk_client_server_source_output}") 127 _vtk_module_depfile_args( 128 MULTI_CONFIG_NEEDS_GENEX 129 TOOL_ARGS _vtk_client_server_depfile_flags 130 CUSTOM_COMMAND_ARGS _vtk_client_server_depfile_args 131 SOURCE "${_vtk_client_server_header}" 132 DEPFILE_PATH "${_vtk_client_server_depfile_genex}" 133 DEPFILE_NO_GENEX_PATH "${_vtk_client_server_depfile_nogenex}" 137 OUTPUT "${_vtk_client_server_source_output}" 138 COMMAND ${CMAKE_CROSSCOMPILING_EMULATOR} 139 "$<TARGET_FILE:ParaView::WrapClientServer>" 140 ${_vtk_client_server_depfile_flags} 141 "@${_vtk_client_server_args_file}" 142 -o "${_vtk_client_server_source_output}" 143 "${_vtk_client_server_header}" 144 ${_vtk_client_server_warning_args} 145 --types "${_vtk_client_server_hierarchy_file}" 146 ${_vtk_client_server_depfile_args} 147 COMMENT "Generating client_server wrapper sources for ${_vtk_client_server_basename}" 149 "$<TARGET_FILE:ParaView::WrapClientServer>" 150 "${_vtk_client_server_header}" 151 "${_vtk_client_server_args_file}" 152 "${_vtk_client_server_command_depend}") 156 "${_vtk_client_server_sources}" 159 "${_vtk_client_server_classes}" 164 ## Generating a client server library 166 A client server library may consist of the wrappings of multiple VTK modules. 167 This is useful for kit-based builds where the modules part of the same kit 168 belong to the same client server library as well. 171 _vtk_module_wrap_client_server_library(<name> <module>...) 174 The first argument is the name of the client server library. The remaining 175 arguments are VTK modules to include in the library. 177 The remaining information it uses is assumed to be provided by the 178 `vtk_module_wrap_client_server` function. 180 function (_vtk_module_wrap_client_server_library name) 181 set(_vtk_client_server_library_sources) 182 set(_vtk_client_server_library_classes) 183 foreach (_vtk_client_server_module IN LISTS ARGN) 184 _vtk_module_get_module_property("${_vtk_client_server_module}" 185 PROPERTY "exclude_wrap" 186 VARIABLE _vtk_client_server_exclude_wrap) 187 if (_vtk_client_server_exclude_wrap) 190 _vtk_module_get_module_property("${_vtk_client_server_module}" 191 PROPERTY "client_server_exclude" 192 VARIABLE _vtk_client_server_exclude) 193 if (_vtk_client_server_exclude) 197 _vtk_module_wrap_client_server_sources("${_vtk_client_server_module}" _vtk_client_server_sources _vtk_client_server_classes) 198 list(APPEND _vtk_client_server_library_sources 199 ${_vtk_client_server_sources}) 200 list(APPEND _vtk_client_server_library_classes 201 ${_vtk_client_server_classes}) 204 if (NOT _vtk_client_server_library_sources) 208 set(_vtk_client_server_declarations) 209 set(_vtk_client_server_calls) 210 foreach (_vtk_client_server_class IN LISTS _vtk_client_server_library_classes) 211 string(APPEND _vtk_client_server_declarations 212 "extern \"C\" { void ${_vtk_client_server_class}_Init(vtkClientServerInterpreter*); }\n") 213 string(APPEND _vtk_client_server_calls 214 " ${_vtk_client_server_class}_Init(csi);\n") 216 set(_vtk_client_server_init_content 217 "#include \"vtkABI.h\" 218 #include \"vtkClientServerInterpreter.h\" 220 ${_vtk_client_server_declarations} 221 extern \"C\" VTK_ABI_EXPORT void ${name}_Initialize(vtkClientServerInterpreter* csi) 224 ${_vtk_client_server_calls}}\n") 226 set(_vtk_client_server_init_file 227 "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${name}Init.cxx") 229 OUTPUT "${_vtk_client_server_init_file}" 230 CONTENT "${_vtk_client_server_init_content}") 231 # XXX(cmake): Why is this necessary? One would expect that `file(GENERATE)` 232 # would do this automatically. 233 set_property(SOURCE "${_vtk_client_server_init_file}" 237 add_library("${name}" STATIC) 238 target_sources("${name}" 240 ${_vtk_client_server_library_sources} 241 "${_vtk_client_server_init_file}") 242 # Add a dummy file set to optimize dependencies. See CMP0154. 243 _vtk_module_add_file_set("${name}" 244 BASE_DIRS "${CMAKE_CURRENT_BINARY_DIR}" 246 if (BUILD_SHARED_LIBS) 247 set_property(TARGET "${name}" 249 POSITION_INDEPENDENT_CODE 1) 251 set(_vtk_build_LIBRARY_NAME_SUFFIX "${_vtk_client_server_LIBRARY_NAME_SUFFIX}") 252 set(_vtk_build_ARCHIVE_DESTINATION "${_vtk_client_server_DESTINATION}") 253 _vtk_module_apply_properties("${name}") 259 target_link_libraries("${name}" 262 ParaView::RemotingClientServerStream 265 set(_vtk_client_server_export) 266 if (_vtk_client_server_INSTALL_EXPORT) 267 list(APPEND _vtk_client_server_export 268 EXPORT "${_vtk_client_server_INSTALL_EXPORT}") 273 ${_vtk_client_server_export} 274 COMPONENT "${_vtk_client_server_COMPONENT}" 275 ARCHIVE DESTINATION "${_vtk_client_server_DESTINATION}") 279 ## Wrapping a set of VTK modules for ClientServer 282 vtk_module_wrap_client_server( 285 [WRAPPED_MODULES <varname>] 287 [FUNCTION_NAME <function>] 288 [DESTINATION <destination>] 290 [INSTALL_EXPORT <export>] 291 [COMPONENT <component>] 293 [WARNINGS <warning>...] 297 * `MODULES`: (Required) The list of modules to wrap. 298 * `TARGET`: (Required) The target to create which represents all wrapped 299 ClientServer modules. This is used to provide the function used to 300 initialize the bindings. 301 * `WRAPPED_MODULES`: (Recommended) Not all modules are wrappable. This 302 variable will be set to contain the list of modules which were wrapped. 303 * `FUNCTION_NAME`: (Recommended) (Defaults to `<TARGET>_initialize`) The 304 function name to generate in order to initialize the client server 305 bindings.A header with the name `<TARGET>.h` should be included in order to 306 access the initialization function. 307 * `DESTINATION`: (Defaults to `${CMAKE_INSTALL_LIBDIR}`) Where to install the 309 * `INSTALL_EXPORT`: If provided, installs will add the installed 310 libraries and generated interface target to the provided export set. 311 * `COMPONENT`: (Defaults to `development`) All install rules created by this 312 function will use this installation component. 313 * ``WARNINGS``: Warnings to enable. Supported warnings: ``empty``. 315 function (vtk_module_wrap_client_server) 316 cmake_parse_arguments(_vtk_client_server 318 "DESTINATION;INSTALL_EXPORT;TARGET;COMPONENT;FUNCTION_NAME;WRAPPED_MODULES" 322 if (_vtk_client_server_UNPARSED_ARGUMENTS) 324 "Unparsed arguments for vtk_module_wrap_client_server: " 325 "${_vtk_client_server_UNPARSED_ARGUMENTS}") 328 if (NOT _vtk_client_server_MODULES) 330 "No modules were requested for client server wrapping.") 334 if (NOT _vtk_client_server_TARGET) 336 "The `TARGET` argument is required.") 339 set(_vtk_client_server_known_warnings 341 set(_vtk_client_server_warning_args) 342 foreach (_vtk_client_server_warning IN LISTS _vtk_client_server_WARNINGS) 343 if (NOT _vtk_client_server_warning IN_LIST _vtk_client_server_known_warnings) 345 "Unrecognized warning: ${_vtk_client_server_warning}") 347 list(APPEND _vtk_client_server_warning_args 348 "-W${_vtk_client_server_warning}") 351 if (NOT DEFINED _vtk_client_server_DESTINATION) 352 set(_vtk_client_server_DESTINATION "${CMAKE_INSTALL_LIBDIR}") 355 if (NOT DEFINED _vtk_client_server_COMPONENT) 356 set(_vtk_client_server_COMPONENT "development") 359 if (NOT DEFINED _vtk_client_server_FUNCTION_NAME) 360 set(_vtk_client_server_FUNCTION_NAME "${_vtk_client_server_TARGET}_initialize") 363 # Disable CMake's automoc support
for these targets.
368 # TODO: Install cmake properties?
370 set(_vtk_client_server_all_modules)
371 set(_vtk_client_server_all_wrapped_modules)
372 foreach (_vtk_client_server_module IN LISTS _vtk_client_server_MODULES)
373 _vtk_module_get_module_property(
"${_vtk_client_server_module}" 374 PROPERTY
"exclude_wrap" 375 VARIABLE _vtk_client_server_exclude_wrap)
376 if (_vtk_client_server_exclude_wrap)
379 _vtk_module_get_module_property("${_vtk_client_server_module}
" 380 PROPERTY "client_server_exclude
" 381 VARIABLE _vtk_client_server_exclude) 382 if (_vtk_client_server_exclude) 385 _vtk_module_real_target(_vtk_client_server_target_name "${_vtk_client_server_module}
") 386 _vtk_module_get_module_property("${_vtk_client_server_module}
" 387 PROPERTY "library_name
" 388 VARIABLE _vtk_client_server_library_name) 389 _vtk_module_wrap_client_server_library("${_vtk_client_server_library_name}CS
" "${_vtk_client_server_module}
") 391 if (TARGET "${_vtk_client_server_library_name}CS
") 392 list(APPEND _vtk_client_server_all_modules 393 "${_vtk_client_server_library_name}CS
") 394 list(APPEND _vtk_client_server_all_wrapped_modules 395 "${_vtk_client_server_module}
") 399 if (NOT _vtk_client_server_all_modules) 401 "No modules given could be wrapped.
") 404 if (DEFINED _vtk_client_server_WRAPPED_MODULES) 405 set("${_vtk_client_server_WRAPPED_MODULES}
" 406 "${_vtk_client_server_all_wrapped_modules}
" 410 if (_vtk_client_server_TARGET) 411 add_library("${_vtk_client_server_TARGET}
" INTERFACE) 412 target_include_directories("${_vtk_client_server_TARGET}
" 414 "$<BUILD_INTERFACE:${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${_vtk_client_server_TARGET}>
") 416 set(_vtk_client_server_all_modules_include_file 417 "${CMAKE_CURRENT_BINARY_DIR}/CMakeFiles/${_vtk_client_server_TARGET}/${_vtk_client_server_TARGET}.h
") 419 set(_vtk_client_server_declarations) 420 set(_vtk_client_server_calls) 421 foreach (_vtk_client_server_module IN LISTS _vtk_client_server_all_modules) 422 string(APPEND _vtk_client_server_declarations 423 "extern \
"C\" void ${_vtk_client_server_module}_Initialize(vtkClientServerInterpreter*);\n")
424 string(APPEND _vtk_client_server_calls
425 " ${_vtk_client_server_module}_Initialize(csi);\n")
428 set(_vtk_client_server_all_modules_include_content
429 "#ifndef ${_vtk_client_server_TARGET}_h 430 #define ${_vtk_client_server_TARGET}_h 432 #include \"vtkClientServerInterpreter.h\" 434 ${_vtk_client_server_declarations} 435 inline void ${_vtk_client_server_FUNCTION_NAME}(vtkClientServerInterpreter* csi) 438 ${_vtk_client_server_calls}} 443 OUTPUT
"${_vtk_client_server_all_modules_include_file}" 444 CONTENT
"${_vtk_client_server_all_modules_include_content}")
446 target_link_libraries(
"${_vtk_client_server_TARGET}" 448 ${_vtk_client_server_all_modules})
450 set(_vtk_client_server_export)
451 if (_vtk_client_server_INSTALL_EXPORT)
452 list(APPEND _vtk_client_server_export
453 EXPORT "${_vtk_client_server_INSTALL_EXPORT}")
457 TARGETS
"${_vtk_client_server_TARGET}" 458 ${_vtk_client_server_export}
459 COMPONENT
"${_vtk_client_server_COMPONENT}" 460 ARCHIVE DESTINATION
465 ## Excluding a module from wrapping 467 Some modules should not be wrapped
using client server bindings. Since
this is
468 independent of general wrapping facilities, an additional
property is used to
476 The `MODULE` defaults to the module currently being built. If a module is not
477 being built when
this function is called, it must be provided.
480 cmake_parse_arguments(_vtk_client_server_exclude
486 if (_vtk_client_server_exclude_UNPARSED_ARGUMENTS)
488 "Unparsed arguments for vtk_module_wrap_client_server_exclude: " 489 "${_vtk_client_server_exclude_UNPARSED_ARGUMENTS}")
492 if (NOT DEFINED _vtk_client_server_exclude_MODULE)
493 if (NOT DEFINED _vtk_build_module)
495 "The `MODULE` argument must be provided outside of a module build.")
497 set(_vtk_client_server_exclude_MODULE
"${_vtk_build_module}")
500 _vtk_module_set_module_property(
"${_vtk_client_server_exclude_MODULE}" 501 PROPERTY
function vtk_module_client_server_exclude()
.md Excluding a module from wrapping
