1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Clients/Catalyst
47  "/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst/vtkCPConfig.h"
48  "/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst/FortranAdaptorAPIMangling.h"
49  "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/CAdaptorAPI.h"
50  "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/vtkCPAdaptorAPI.h"
51  "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/vtkCPCxxHelper.h"
52  "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/vtkCPDataDescription.h"
53  "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/vtkCPInputDataDescription.h"
54  "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/vtkCPPipeline.h"
55  "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/vtkCPProcessor.h"
56  "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/vtkCPXMLPWriterPipeline.h"
57  "/builds/gitlab-kitware-sciviz-ci/Clients/Catalyst/FortranAdaptorAPI.h"
58  "/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst/vtkPVCatalystModule.h"
59  )
60 endif()
61
62 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
63  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkPVCatalyst-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkPVCatalyst-hierarchy.txt")
64 endif()
65
66 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
67  foreach(file
68  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.13.so.5.13"
69  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.13.so.1"
70  )
71  if(EXISTS "${file}" AND
72  NOT IS_SYMLINK "${file}")
73  file(RPATH_CHECK
74  FILE "${file}"
75  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
76  endif()
77  endforeach()
78  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
79  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVCatalyst-pv5.13.so.5.13"
80  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVCatalyst-pv5.13.so.1"
81  )
82  foreach(file
83  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.13.so.5.13"
84  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.13.so.1"
85  )
86  if(EXISTS "${file}" AND
87  NOT IS_SYMLINK "${file}")
88  file(RPATH_CHANGE
89  FILE "${file}"
90  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
91  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
92  if(CMAKE_INSTALL_DO_STRIP)
93  execute_process(COMMAND "/usr/bin/strip" "${file}")
94  endif()
95  endif()
96  endforeach()
97 endif()
98
99 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
100  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.13.so" AND
101  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.13.so")
102  file(RPATH_CHECK
103  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.13.so"
104  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
105  endif()
106  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVCatalyst-pv5.13.so")
107  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.13.so" AND
108  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.13.so")
109  file(RPATH_CHANGE
110  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.13.so"
111  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
112  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
113  if(CMAKE_INSTALL_DO_STRIP)
114  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVCatalyst-pv5.13.so")
115  endif()
116  endif()
117 endif()
118
119 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
120  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13" TYPE DIRECTORY FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/Catalyst/Fortran/")
121 endif()
122
