1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Clients/CommandLineExecutables
45 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
46  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver" AND
47  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver")
48  file(RPATH_CHECK
49  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver"
50  RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
51  endif()
52  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/pvserver")
53  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver" AND
54  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver")
55  file(RPATH_CHANGE
56  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver"
57  OLD_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib:"
58  NEW_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
59  if(CMAKE_INSTALL_DO_STRIP)
60  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvserver")
61  endif()
62  endif()
63 endif()
64
65 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
66  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver" AND
67  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver")
68  file(RPATH_CHECK
69  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver"
70  RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
71  endif()
72  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/pvdataserver")
73  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver" AND
74  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver")
75  file(RPATH_CHANGE
76  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver"
77  OLD_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib:"
78  NEW_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
79  if(CMAKE_INSTALL_DO_STRIP)
80  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvdataserver")
81  endif()
82  endif()
83 endif()
84
85 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
86  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver" AND
87  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver")
88  file(RPATH_CHECK
89  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver"
90  RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
91  endif()
92  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/pvrenderserver")
93  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver" AND
94  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver")
95  file(RPATH_CHANGE
96  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver"
97  OLD_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib:"
98  NEW_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
99  if(CMAKE_INSTALL_DO_STRIP)
100  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvrenderserver")
101  endif()
102  endif()
103 endif()
104
105 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
106  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch" AND
107  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch")
108  file(RPATH_CHECK
109  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch"
110  RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
111  endif()
112  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/pvbatch")
113  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch" AND
114  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch")
115  file(RPATH_CHANGE
116  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch"
117  OLD_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib:"
118  NEW_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
119  if(CMAKE_INSTALL_DO_STRIP)
120  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvbatch")
121  endif()
122  endif()
123 endif()
124
125 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
126  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython" AND
127  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython")
128  file(RPATH_CHECK
129  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython"
130  RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
131  endif()
132  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/pvpython")
133  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython" AND
134  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython")
135  file(RPATH_CHANGE
136  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython"
137  OLD_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib:"
138  NEW_RPATH "\$ORIGIN/../lib64:/usr/lib64/openmpi/lib")
139  if(CMAKE_INSTALL_DO_STRIP)
140  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/pvpython")
141  endif()
142  endif()
143 endif()
144
145 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
146  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE PROGRAM FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/paraview-config")
147 endif()
148
149 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
150  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/ParaViewTools-targets.cmake")
151  file(DIFFERENT EXPORT_FILE_CHANGED FILES
152  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/ParaViewTools-targets.cmake"
153  "/builds/gitlab-kitware-sciviz-ci/build/Clients/CommandLineExecutables/CMakeFiles/Export/lib64/cmake/paraview-5.13/ParaViewTools-targets.cmake")
154  if(EXPORT_FILE_CHANGED)
155  file(GLOB OLD_CONFIG_FILES "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/ParaViewTools-targets-*.cmake")
156  if(OLD_CONFIG_FILES)
157  message(STATUS "Old export file \"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/ParaViewTools-targets.cmake\" will be replaced. Removing files [${OLD_CONFIG_FILES}].")
158  file(REMOVE ${OLD_CONFIG_FILES})
159  endif()
160  endif()
161  endif()
162  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/CommandLineExecutables/CMakeFiles/Export/lib64/cmake/paraview-5.13/ParaViewTools-targets.cmake")
163  if("${CMAKE_INSTALL_CONFIG_NAME}" MATCHES "^([Dd][Ee][Bb][Uu][Gg])$")
164  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/CommandLineExecutables/CMakeFiles/Export/lib64/cmake/paraview-5.13/ParaViewTools-targets-debug.cmake")
165  endif()
166 endif()
167
