1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Clients/ParaView/Documentation
45 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdocx" OR NOT CMAKE_INSTALL_COMPONENT)
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Clients/ParaView/Documentation/paraview.qch")
47 endif()
48
