1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/ParaView_paraview_plugins" TYPE FILE FILES
47  "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/vtkBivariateNoiseMapper.h"
48  "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/vtkBivariateNoiseRepresentation.h"
49  "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/vtkBivariateTextureRepresentation.h"
50  "/builds/gitlab-kitware-sciviz-ci/Plugins/BivariateRepresentations/Representations/vtkOpenGLBivariateNoiseMapperDelegator.h"
51  "/builds/gitlab-kitware-sciviz-ci/build/Plugins/BivariateRepresentations/Representations/vtkBivariateRepresentationsModule.h"
52  )
53 endif()
54
55 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
56  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/BivariateRepresentations/vtk/hierarchy/BivariateRepresentations" TYPE FILE RENAME "vtkBivariateRepresentations-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/BivariateRepresentations/vtk/hierarchy/BivariateRepresentations/vtkBivariateRepresentations-hierarchy.txt")
57 endif()
58
59 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpluginsx" OR NOT CMAKE_INSTALL_COMPONENT)
60  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/BivariateRepresentations" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/BivariateRepresentations/libvtkBivariateRepresentations.a")
61 endif()
62
