1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/DSP
47  include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/DataModel/cmake_install.cmake")
48 endif()
49
50 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
51  # Include the install script for the subdirectory.
52  include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/Filters/cmake_install.cmake")
53 endif()
54
55 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
56  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/DigitalSignalProcessing-targets.cmake")
57  file(DIFFERENT EXPORT_FILE_CHANGED FILES
58  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/DigitalSignalProcessing-targets.cmake"
59  "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/CMakeFiles/Export/lib64/cmake/paraview-5.13/DigitalSignalProcessing-targets.cmake")
60  if(EXPORT_FILE_CHANGED)
61  file(GLOB OLD_CONFIG_FILES "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/DigitalSignalProcessing-targets-*.cmake")
62  if(OLD_CONFIG_FILES)
63  message(STATUS "Old export file \"$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13/DigitalSignalProcessing-targets.cmake\" will be replaced. Removing files [${OLD_CONFIG_FILES}].")
64  file(REMOVE ${OLD_CONFIG_FILES})
65  endif()
66  endif()
67  endif()
68  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/CMakeFiles/Export/lib64/cmake/paraview-5.13/DigitalSignalProcessing-targets.cmake")
69  if("${CMAKE_INSTALL_CONFIG_NAME}" MATCHES "^([Dd][Ee][Bb][Uu][Gg])$")
70  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/CMakeFiles/Export/lib64/cmake/paraview-5.13/DigitalSignalProcessing-targets-debug.cmake")
71  endif()
72 endif()
73
74 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
75  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/cmake/paraview-5.13" TYPE FILE RENAME "DigitalSignalProcessing-vtk-module-properties.cmake" FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/CMakeFiles/DigitalSignalProcessing-vtk-module-properties.cmake.install")
76 endif()
77
78 if(NOT CMAKE_INSTALL_LOCAL_ONLY)
79  # Include the install script for the subdirectory.
80  include("/builds/gitlab-kitware-sciviz-ci/build/Plugins/DSP/DataModel/Testing/cmake_install.cmake")
81 endif()
82
83 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
84  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE STATIC_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkDSPFiltersPluginCS.a")
85 endif()
86
87 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xpluginsx" OR NOT CMAKE_INSTALL_COMPONENT)
88  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/DigitalSignalProcessing/DigitalSignalProcessing.so" AND
89  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/DigitalSignalProcessing/DigitalSignalProcessing.so")
90  file(RPATH_CHECK
91  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/DigitalSignalProcessing/DigitalSignalProcessing.so"
92  RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib")
93  endif()
94  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/DigitalSignalProcessing" TYPE MODULE FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-5.13/plugins/DigitalSignalProcessing/DigitalSignalProcessing.so")
95  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/DigitalSignalProcessing/DigitalSignalProcessing.so" AND
96  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/DigitalSignalProcessing/DigitalSignalProcessing.so")
97  file(RPATH_CHANGE
98  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/DigitalSignalProcessing/DigitalSignalProcessing.so"
99  OLD_RPATH "/builds/gitlab-kitware-sciviz-ci/build/lib64:/usr/lib64/openmpi/lib:"
100  NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib")
101  if(CMAKE_INSTALL_DO_STRIP)
102  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-5.13/plugins/DigitalSignalProcessing/DigitalSignalProcessing.so")
103  endif()
104  endif()
105 endif()
106
