1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins" TYPE FILE FILES
47 "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel/vtkPUnstructuredGridGhostCellsGenerator.h" 48 "/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Parallel/LegacyGhostCellsGeneratorParallelModule.h" 52 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 53 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/LegacyGhostCellsGenerator/
vtk/hierarchy/LegacyGhostCellsGenerator
" TYPE FILE RENAME "LegacyGhostCellsGeneratorParallel-hierarchy.txt
" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/LegacyGhostCellsGenerator/
vtk/hierarchy/LegacyGhostCellsGenerator/LegacyGhostCellsGeneratorParallel-hierarchy.txt
") 56 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xpluginsx
" OR NOT CMAKE_INSTALL_COMPONENT) 57 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/LegacyGhostCellsGenerator/libLegacyGhostCellsGeneratorParallel.so
" AND 58 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/LegacyGhostCellsGenerator/libLegacyGhostCellsGeneratorParallel.so
") 60 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/LegacyGhostCellsGenerator/libLegacyGhostCellsGeneratorParallel.so
" 61 RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib
") 63 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/LegacyGhostCellsGenerator
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/LegacyGhostCellsGenerator/libLegacyGhostCellsGeneratorParallel.so
") 64 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/LegacyGhostCellsGenerator/libLegacyGhostCellsGeneratorParallel.so
" AND 65 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/LegacyGhostCellsGenerator/libLegacyGhostCellsGeneratorParallel.so
") 67 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/LegacyGhostCellsGenerator/libLegacyGhostCellsGeneratorParallel.so
" 68 OLD_RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib:
" 69 NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib
") 70 if(CMAKE_INSTALL_DO_STRIP) 71 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/LegacyGhostCellsGenerator/libLegacyGhostCellsGeneratorParallel.so
") 76 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 79 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xlicensesx
" OR NOT CMAKE_INSTALL_COMPONENT) 80 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/LegacyGhostCellsGeneratorParallel
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Plugins/LegacyGhostCellsGenerator/Parallel/LICENSE
") 83 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xspdxx
" OR NOT CMAKE_INSTALL_COMPONENT) 84 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/LegacyGhostCellsGenerator/Parallel/LegacyGhostCellsGeneratorParallel.spdx
