1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Plugins/StreamingParticles/Particles 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Release")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"${CMAKE_INSTALL_PREFIX}/include/paraview-6.0/ParaView_paraview_plugins" TYPE FILE FILES
47 "/builds/gitlab-kitware-sciviz-ci/Plugins/StreamingParticles/Particles/vtkPVRandomPointsStreamingSource.h" 48 "/builds/gitlab-kitware-sciviz-ci/Plugins/StreamingParticles/Particles/vtkStreamingParticlesPriorityQueue.h" 49 "/builds/gitlab-kitware-sciviz-ci/Plugins/StreamingParticles/Particles/vtkStreamingParticlesRepresentation.h" 50 "/builds/gitlab-kitware-sciviz-ci/build/Plugins/StreamingParticles/Particles/vtkStreamingParticlesModule.h" 54 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 55 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/StreamingParticles/
vtk/hierarchy/StreamingParticles
" TYPE FILE RENAME "vtkStreamingParticles-hierarchy.txt
" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/StreamingParticles/
vtk/hierarchy/StreamingParticles/vtkStreamingParticles-hierarchy.txt
") 58 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xpluginsx
" OR NOT CMAKE_INSTALL_COMPONENT) 59 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/StreamingParticles/libvtkStreamingParticles.so
" AND 60 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/StreamingParticles/libvtkStreamingParticles.so
") 62 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/StreamingParticles/libvtkStreamingParticles.so
" 63 RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib
") 65 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/StreamingParticles
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/paraview-6.0/plugins/StreamingParticles/libvtkStreamingParticles.so
") 66 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/StreamingParticles/libvtkStreamingParticles.so
" AND 67 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/StreamingParticles/libvtkStreamingParticles.so
") 69 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/StreamingParticles/libvtkStreamingParticles.so
" 70 OLD_RPATH "\$ORIGIN/../../../:/usr/lib64/openmpi/lib::::::::
" 71 NEW_RPATH "\$ORIGIN:\$ORIGIN/../../../:/usr/lib64/openmpi/lib
") 72 if(CMAKE_INSTALL_DO_STRIP) 73 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/paraview-6.0/plugins/StreamingParticles/libvtkStreamingParticles.so
") 78 if("x${CMAKE_INSTALL_COMPONENT}x
" OR NOT CMAKE_INSTALL_COMPONENT) 81 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xspdxx
" OR NOT CMAKE_INSTALL_COMPONENT) 82 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Plugins/StreamingParticles/Particles/vtkStreamingParticles.spdx
