3 if(
4 message(FATAL_ERROR
"CMake >= 2.6.0 required")
15 # Protect against multiple inclusion, which would fail when already imported targets are added once more.
17 set(_targetsNotDefined)
19 foreach(_expectedTarget qttesting)
20 list(APPEND _expectedTargets ${_expectedTarget})
21 if(NOT TARGET ${_expectedTarget})
22 list(APPEND _targetsNotDefined ${_expectedTarget})
24 if(TARGET ${_expectedTarget})
25 list(APPEND _targetsDefined ${_expectedTarget})
28 if("${_targetsDefined}
") 29 unset(_targetsDefined) 30 unset(_targetsNotDefined) 31 unset(_expectedTargets) 32 set(CMAKE_IMPORT_FILE_VERSION) 36 if(NOT "${_targetsDefined}
" STREQUAL "") 37 message(FATAL_ERROR "Some (but not all) targets in
this export
") 39 unset(_targetsDefined) 40 unset(_targetsNotDefined) 41 unset(_expectedTargets) 44 # Create imported target qttesting 45 add_library(qttesting SHARED IMPORTED) 47 set_target_properties(qttesting PROPERTIES 48 INTERFACE_INCLUDE_DIRECTORIES "/builds/gitlab-kitware-sciviz-ci/build/ThirdParty/QtTesting/vtkqttesting;/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting;/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting;/builds/gitlab-kitware-sciviz-ci/build/ThirdParty/QtTesting/vtkqttesting
" 51 # Import target "qttesting
" for configuration "Debug
" 52 set_property(TARGET qttesting APPEND PROPERTY IMPORTED_CONFIGURATIONS DEBUG) 53 set_target_properties(qttesting PROPERTIES 54 IMPORTED_LINK_DEPENDENT_LIBRARIES_DEBUG "Qt5::Core;Qt5::Widgets;Qt5::Gui
" 55 IMPORTED_LOCATION_DEBUG "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkqttesting-pv5.13.so.5.13
" 56 IMPORTED_SONAME_DEBUG "libvtkqttesting-pv5.13.so.1
" 59 # This file does not depend on other imported targets which have 60 # been exported from the same project but in a separate export set. 62 # Commands beyond this point should not need to know the version. 63 set(CMAKE_IMPORT_FILE_VERSION)
