1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Qt/Core
47  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqQVTKWidgetBase.h"
48  "/builds/gitlab-kitware-sciviz-ci/build/Qt/Core/pqQtConfig.h"
49  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqAnimationCue.h"
50  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqAnimationScene.h"
51  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqAnnotationsModel.h"
52  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqApplicationCore.h"
53  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqAutoStartInterface.h"
54  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqBoxChartView.h"
55  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqCameraWidgetViewLink.h"
56  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqCheckBoxDelegate.h"
57  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqCollaborationEventPlayer.h"
58  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqCollaborationManager.h"
59  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqComparativeContextView.h"
60  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqComparativeRenderView.h"
61  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqComparativeXYBarChartView.h"
62  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqComparativeXYChartView.h"
63  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqContextView.h"
64  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqCoreConfiguration.h"
65  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqCoreInit.h"
66  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqCoreTestUtility.h"
67  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqCoreUtilities.h"
68  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqDataRepresentation.h"
69  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqExtractor.h"
70  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqFileDialog.h"
71  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqFileDialogEventPlayer.h"
72  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqFileDialogEventTranslator.h"
73  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqFileDialogFavoriteModel.h"
74  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqFileDialogFilter.h"
75  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqFileDialogLocationModel.h"
76  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqFileDialogModel.h"
77  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqFileDialogRecentDirsModel.h"
78  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqFileUtilitiesEventPlayer.h"
79  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqFlatTreeViewEventPlayer.h"
80  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqFlatTreeViewEventTranslator.h"
81  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqGraphLayoutStrategyInterface.h"
82  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqIconListModel.h"
83  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqIconSettings.h"
84  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqImageUtil.h"
85  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqInteractiveViewLink.h"
86  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqInterfaceTracker.h"
87  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqKeyEventFilter.h"
88  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqKeySequences.h"
89  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqLinkedObjectInterface.h"
90  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqLinkedObjectQTextEdit.h"
91  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqLinkViewWidget.h"
92  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqLinksModel.h"
93  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqLogViewerWidget.h"
94  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqMainWindowEventManager.h"
95  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqMenuReactionUtils.h"
96  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqModalShortcut.h"
97  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqMultiSliceAxisWidget.h"
98  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqMultiSliceView.h"
99  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqNonEditableStyledItemDelegate.h"
100  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqObjectBuilder.h"
101  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqOutputPort.h"
102  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqOutputWidget.h"
103  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqParallelCoordinatesChartView.h"
104  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqPipelineFilter.h"
105  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqPipelineRepresentation.h"
106  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqPipelineSource.h"
107  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqPlotMatrixView.h"
108  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqPluginLocationInterface.h"
109  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqPluginManager.h"
110  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqProgressManager.h"
111  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqPropertyLinks.h"
112  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqPropertyLinksConnection.h"
113  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqPropertyManager.h"
114  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqProxy.h"
115  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqProxyModifiedStateUndoElement.h"
116  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqProxySelection.h"
117  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqQVTKWidget.h"
118  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqQVTKWidgetEventPlayer.h"
119  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqQVTKWidgetEventTranslator.h"
120  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqRecentlyUsedResourceLoaderInterface.h"
121  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqRecentlyUsedResourcesList.h"
122  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqRenderView.h"
123  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqRenderViewBase.h"
124  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqRepresentation.h"
125  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqSMAdaptor.h"
126  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqSMProxy.h"
127  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqScalarBarRepresentation.h"
128  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqScalarsToColors.h"
129  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqServer.h"
130  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqServerConfiguration.h"
131  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqServerConfigurationCollection.h"
132  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqServerManagerModel.h"
133  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqServerManagerModelInterface.h"
134  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqServerManagerModelItem.h"
135  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqServerManagerObserver.h"
136  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqServerResource.h"
137  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqSettings.h"
138  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqSignalsBlocker.h"
139  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqSpreadSheetView.h"
140  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqSpreadSheetViewModel.h"
141  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqSpreadSheetViewSelectionModel.h"
142  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqSpreadSheetViewWidget.h"
143  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqStandardServerManagerModelInterface.h"
144  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqTextLinker.h"
145  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqTimeKeeper.h"
146  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqTreeLayoutStrategyInterface.h"
147  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqUndoStack.h"
148  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqView.h"
149  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqXMLEventObserver.h"
150  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqXMLEventSource.h"
151  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqXMLUtil.h"
152  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqXYBarChartView.h"
153  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqXYChartView.h"
154  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqXYHistogramChartView.h"
155  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/vtkPVGUIPluginInterface.h"
156  "/builds/gitlab-kitware-sciviz-ci/Qt/Core/pqPythonView.h"
157  "/builds/gitlab-kitware-sciviz-ci/build/Qt/Core/pqCoreModule.h"
158  )
159 endif()
160
161 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
162  foreach(file
163  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqCore-pv5.13.so.5.13"
164  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqCore-pv5.13.so.1"
165  )
166  if(EXISTS "${file}" AND
167  NOT IS_SYMLINK "${file}")
168  file(RPATH_CHECK
169  FILE "${file}"
170  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
171  endif()
172  endforeach()
173  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
174  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libpqCore-pv5.13.so.5.13"
175  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libpqCore-pv5.13.so.1"
176  )
177  foreach(file
178  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqCore-pv5.13.so.5.13"
179  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqCore-pv5.13.so.1"
180  )
181  if(EXISTS "${file}" AND
182  NOT IS_SYMLINK "${file}")
183  file(RPATH_CHANGE
184  FILE "${file}"
185  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
186  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
187  if(CMAKE_INSTALL_DO_STRIP)
188  execute_process(COMMAND "/usr/bin/strip" "${file}")
189  endif()
190  endif()
191  endforeach()
192 endif()
193
194 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
195  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqCore-pv5.13.so" AND
196  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqCore-pv5.13.so")
197  file(RPATH_CHECK
198  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqCore-pv5.13.so"
199  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
200  endif()
201  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libpqCore-pv5.13.so")
202  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqCore-pv5.13.so" AND
203  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqCore-pv5.13.so")
204  file(RPATH_CHANGE
205  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqCore-pv5.13.so"
206  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
207  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
208  if(CMAKE_INSTALL_DO_STRIP)
209  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqCore-pv5.13.so")
210  endif()
211  endif()
212 endif()
213
