1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Qt/Python
47  "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonUtils.h"
48  "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqTextLinkerPython.h"
49  "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqLinkedObjectPythonTextArea.h"
50  "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonCalculatorCompleter.h"
51  "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonCompleter.h"
52  "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonDebugLeaksView.h"
53  "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonEditorActions.h"
54  "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonFileIO.h"
55  "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonLineNumberArea.h"
56  "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonMacroSettings.h"
57  "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonMacroSupervisor.h"
58  "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonManager.h"
59  "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonScriptEditor.h"
60  "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonShell.h"
61  "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonShellCompleter.h"
62  "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonSyntaxHighlighter.h"
63  "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonTabWidget.h"
64  "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonTextArea.h"
65  "/builds/gitlab-kitware-sciviz-ci/Qt/Python/pqPythonUndoCommand.h"
66  "/builds/gitlab-kitware-sciviz-ci/build/Qt/Python/pqPythonModule.h"
67  )
68 endif()
69
70 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
71  foreach(file
72  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so.5.13"
73  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so.1"
74  )
75  if(EXISTS "${file}" AND
76  NOT IS_SYMLINK "${file}")
77  file(RPATH_CHECK
78  FILE "${file}"
79  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
80  endif()
81  endforeach()
82  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
83  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libpqPython-pv5.13.so.5.13"
84  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libpqPython-pv5.13.so.1"
85  )
86  foreach(file
87  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so.5.13"
88  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so.1"
89  )
90  if(EXISTS "${file}" AND
91  NOT IS_SYMLINK "${file}")
92  file(RPATH_CHANGE
93  FILE "${file}"
94  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
95  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
96  if(CMAKE_INSTALL_DO_STRIP)
97  execute_process(COMMAND "/usr/bin/strip" "${file}")
98  endif()
99  endif()
100  endforeach()
101 endif()
102
103 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
104  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so" AND
105  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so")
106  file(RPATH_CHECK
107  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so"
108  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
109  endif()
110  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libpqPython-pv5.13.so")
111  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so" AND
112  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so")
113  file(RPATH_CHANGE
114  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so"
115  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
116  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
117  if(CMAKE_INSTALL_DO_STRIP)
118  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqPython-pv5.13.so")
119  endif()
120  endif()
121 endif()
122
