1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Qt/Widgets
47  "/builds/gitlab-kitware-sciviz-ci/build/Qt/Widgets/pqQtWidgetsConfig.h"
48  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqQtDeprecated.h"
49  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqCheckBoxPixMaps.h"
50  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqCheckBoxPixMaps.h"
51  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqCheckableHeaderView.h"
52  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqClickableLabel.h"
53  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqCollapsedGroup.h"
54  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqColorButtonEventPlayer.h"
55  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqColorButtonEventTranslator.h"
56  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqColorChooserButton.h"
57  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqColorDialogEventPlayer.h"
58  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqColorDialogEventTranslator.h"
59  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqConnect.h"
60  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqConsoleWidget.h"
61  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqConsoleWidgetEventPlayer.h"
62  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqConsoleWidgetEventTranslator.h"
63  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqDelimitedTextParser.h"
64  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqDiscreteDoubleWidget.h"
65  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqDoubleLineEdit.h"
66  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqDoubleRangeDialog.h"
67  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqDoubleRangeWidget.h"
68  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqDoubleSliderWidget.h"
69  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqDoubleSpinBox.h"
70  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqExpandableTableView.h"
71  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqExpanderButton.h"
72  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqExtendedSortFilterProxyModel.h"
73  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqFlatTreeView.h"
74  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqHeaderView.h"
75  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqHierarchicalGridLayout.h"
76  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqHierarchicalGridWidget.h"
77  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqHighlightablePushButton.h"
78  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqHighlightableToolButton.h"
79  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqLineEdit.h"
80  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqLineEditEventPlayer.h"
81  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqListWidgetCheckHelper.h"
82  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqListWidgetItemObject.h"
83  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqMultiColumnHeaderView.h"
84  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqProgressWidget.h"
85  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqQuickLaunchDialog.h"
86  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqScaleByButton.h"
87  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqScaledSpinBox.h"
88  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqScopedOverrideCursor.h"
89  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqSectionVisibilityContextMenu.h"
90  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqSeriesGeneratorDialog.h"
91  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqSetData.h"
92  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqSetName.h"
93  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqSignalAdaptors.h"
94  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqSpinBox.h"
95  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqTableView.h"
96  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqTextEdit.h"
97  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqTreeView.h"
98  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqTreeViewExpandState.h"
99  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqTreeViewSelectionHelper.h"
100  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqTreeWidget.h"
101  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqTreeWidgetCheckHelper.h"
102  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqTreeWidgetItem.h"
103  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqTreeWidgetItemObject.h"
104  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqTreeWidgetSelectionHelper.h"
105  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqVectorWidget.h"
106  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqWaitCursor.h"
107  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqWidgetCompleter.h"
108  "/builds/gitlab-kitware-sciviz-ci/Qt/Widgets/pqWidgetsInit.h"
109  "/builds/gitlab-kitware-sciviz-ci/build/Qt/Widgets/pqWidgetsModule.h"
110  )
111 endif()
112
113 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
114  foreach(file
115  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqWidgets-pv5.13.so.5.13"
116  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqWidgets-pv5.13.so.1"
117  )
118  if(EXISTS "${file}" AND
119  NOT IS_SYMLINK "${file}")
120  file(RPATH_CHECK
121  FILE "${file}"
122  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
123  endif()
124  endforeach()
125  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
126  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libpqWidgets-pv5.13.so.5.13"
127  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libpqWidgets-pv5.13.so.1"
128  )
129  foreach(file
130  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqWidgets-pv5.13.so.5.13"
131  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqWidgets-pv5.13.so.1"
132  )
133  if(EXISTS "${file}" AND
134  NOT IS_SYMLINK "${file}")
135  file(RPATH_CHANGE
136  FILE "${file}"
137  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
138  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
139  if(CMAKE_INSTALL_DO_STRIP)
140  execute_process(COMMAND "/usr/bin/strip" "${file}")
141  endif()
142  endif()
143  endforeach()
144 endif()
145
146 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
147  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqWidgets-pv5.13.so" AND
148  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqWidgets-pv5.13.so")
149  file(RPATH_CHECK
150  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqWidgets-pv5.13.so"
151  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
152  endif()
153  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libpqWidgets-pv5.13.so")
154  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqWidgets-pv5.13.so" AND
155  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqWidgets-pv5.13.so")
156  file(RPATH_CHANGE
157  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqWidgets-pv5.13.so"
158  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
159  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
160  if(CMAKE_INSTALL_DO_STRIP)
161  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libpqWidgets-pv5.13.so")
162  endif()
163  endif()
164 endif()
165
