1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Remoting/Core
47  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkReservedRemoteObjectIds.h"
48  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkCompositeMultiProcessController.h"
49  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkDisplayConfiguration.h"
50  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkMPIMToNSocketConnection.h"
51  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkMPIMToNSocketConnectionPortInformation.h"
52  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkNetworkAccessManager.h"
53  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPResourceFileLocator.h"
54  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkProcessModule.h"
55  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkProcessModuleConfiguration.h"
56  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVAlgorithmPortsInformation.h"
57  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVArrayInformation.h"
58  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVClassNameInformation.h"
59  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVDataAssemblyInformation.h"
60  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVDataInformation.h"
61  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVDataSetAttributesInformation.h"
62  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVDataSizeInformation.h"
63  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVDisableStackTraceSignalHandler.h"
64  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVDynamicInitializerPluginInterface.h"
65  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVEnableStackTraceSignalHandler.h"
66  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVEnvironmentInformation.h"
67  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVEnvironmentInformationHelper.h"
68  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVFileInformation.h"
69  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVFileInformationHelper.h"
70  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVInformation.h"
71  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVLogInformation.h"
72  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVMemoryUseInformation.h"
73  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVPlugin.h"
74  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVPluginLoader.h"
75  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVPluginsInformation.h"
76  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVPluginTracker.h"
77  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVProgressHandler.h"
78  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVPythonInformation.h"
79  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVPythonModule.h"
80  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVPythonPluginInterface.h"
81  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVServerInformation.h"
82  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVServerManagerPluginInterface.h"
83  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVSession.h"
84  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVSystemConfigInformation.h"
85  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVSystemInformation.h"
86  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVTemporalDataInformation.h"
87  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkPVTimerInformation.h"
88  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkRemotingCoreConfiguration.h"
89  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkSession.h"
90  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkSessionIterator.h"
91  "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/vtkTCPNetworkAccessManager.h"
92  "/builds/gitlab-kitware-sciviz-ci/build/Remoting/Core/vtkPVConfig.h"
93  "/builds/gitlab-kitware-sciviz-ci/build/Remoting/Core/vtkRemotingCoreModule.h"
94  )
95 endif()
96
97 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
98  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkRemotingCore-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkRemotingCore-hierarchy.txt")
99 endif()
100
101 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
102  foreach(file
103  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingCore-pv5.13.so.5.13"
104  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingCore-pv5.13.so.1"
105  )
106  if(EXISTS "${file}" AND
107  NOT IS_SYMLINK "${file}")
108  file(RPATH_CHECK
109  FILE "${file}"
110  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
111  endif()
112  endforeach()
113  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
114  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingCore-pv5.13.so.5.13"
115  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingCore-pv5.13.so.1"
116  )
117  foreach(file
118  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingCore-pv5.13.so.5.13"
119  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingCore-pv5.13.so.1"
120  )
121  if(EXISTS "${file}" AND
122  NOT IS_SYMLINK "${file}")
123  file(RPATH_CHANGE
124  FILE "${file}"
125  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
126  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
127  if(CMAKE_INSTALL_DO_STRIP)
128  execute_process(COMMAND "/usr/bin/strip" "${file}")
129  endif()
130  endif()
131  endforeach()
132 endif()
133
134 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
135  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingCore-pv5.13.so" AND
136  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingCore-pv5.13.so")
137  file(RPATH_CHECK
138  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingCore-pv5.13.so"
139  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
140  endif()
141  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingCore-pv5.13.so")
142  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingCore-pv5.13.so" AND
143  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingCore-pv5.13.so")
144  file(RPATH_CHANGE
145  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingCore-pv5.13.so"
146  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
147  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
148  if(CMAKE_INSTALL_DO_STRIP)
149  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingCore-pv5.13.so")
150  endif()
151  endif()
152 endif()
153
154 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xlicensesx" OR NOT CMAKE_INSTALL_COMPONENT)
155  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkRemotingCore" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Remoting/Core/LICENSE")
156 endif()
157
