1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Remoting/Views
47  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkStreamingPriorityQueue.h"
48  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtk2DWidgetRepresentation.h"
49  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtk3DWidgetRepresentation.h"
50  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkProtractorRepresentation.h"
51  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkAMROutlineRepresentation.h"
52  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkAMRStreamingPriorityQueue.h"
53  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkAMRStreamingVolumeRepresentation.h"
54  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkBoundingRectContextDevice2D.h"
55  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkCaveSynchronizedRenderers.h"
56  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkCellGridRepresentation.h"
57  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkChartRepresentation.h"
58  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkChartSelectionRepresentation.h"
59  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkChartTextRepresentation.h"
60  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkChartLogoRepresentation.h"
61  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkChartWarning.h"
62  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkCompositeRepresentation.h"
63  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkContext2DScalarBarActor.h"
64  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkDataLabelRepresentation.h"
65  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkFeatureEdgesRepresentation.h"
66  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkGeometryRepresentation.h"
67  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkGeometryRepresentationWithFaces.h"
68  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkGeometrySliceRepresentation.h"
69  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkGlyph3DRepresentation.h"
70  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkGridAxes2DActor.h"
71  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkGridAxes3DActor.h"
72  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkGridAxesHelper.h"
73  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkGridAxesPlane2DActor.h"
74  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkHyperTreeGridRepresentation.h"
75  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkImageSliceRepresentation.h"
76  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkImageVolumeRepresentation.h"
77  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkLogoSourceRepresentation.h"
78  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkMoleculeRepresentation.h"
79  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkMultiSliceContextItem.h"
80  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkOrderedCompositingHelper.h"
81  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkOutlineRepresentation.h"
82  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVAxesActor.h"
83  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVAxesWidget.h"
84  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVBoxChartRepresentation.h"
85  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVCameraCollection.h"
86  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVCenterAxesActor.h"
87  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVClientServerSynchronizedRenderers.h"
88  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVComparativeAnimationCue.h"
89  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVComparativeView.h"
90  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVCompositeOrthographicSliceRepresentation.h"
91  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVCompositeRepresentation.h"
92  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVContextInteractorStyle.h"
93  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVContextView.h"
94  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVContextViewDataDeliveryManager.h"
95  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVDataDeliveryManager.h"
96  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVDataRepresentation.h"
97  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVDataRepresentationPipeline.h"
98  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVDefaultPass.h"
99  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVDiscretizableColorTransferFunction.h"
100  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVDisplaySizedImplicitPlaneRepresentation.h"
101  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVEncodeSelectionForServer.h"
102  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVFrustumActor.h"
103  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVGridAxes3DActor.h"
104  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVGridAxes3DRepresentation.h"
105  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVHardwareSelector.h"
106  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVHistogramChartRepresentation.h"
107  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVImageChartRepresentation.h"
108  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVImageSliceMapper.h"
109  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVImplicitCylinderRepresentation.h"
110  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVImplicitPlaneRepresentation.h"
111  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVInteractiveViewLinkRepresentation.h"
112  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVIOSettings.h"
113  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVLODActor.h"
114  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVLODVolume.h"
115  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVLastSelectionInformation.h"
116  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVLight.h"
117  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVLogoSource.h"
118  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVMaterialLibrary.h"
119  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVMultiSliceView.h"
120  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVOpenGLInformation.h"
121  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVOrthographicSliceView.h"
122  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVParallelCoordinatesRepresentation.h"
123  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVPlotMatrixRepresentation.h"
124  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVPlotMatrixView.h"
125  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVPlotTime.h"
126  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVProcessWindow.h"
127  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVProminentValuesInformation.h"
128  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVRayCastPickingHelper.h"
129  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVRenderView.h"
130  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVRenderViewDataDeliveryManager.h"
131  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVRenderViewSettings.h"
132  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVRenderViewWithEDL.h"
133  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVRenderingCapabilitiesInformation.h"
134  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVRepresentedArrayListSettings.h"
135  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVRepresentedDataInformation.h"
136  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVScalarBarActor.h"
137  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVScalarBarRepresentation.h"
138  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVSelectionInformation.h"
139  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVStreamingPiecesInformation.h"
140  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVSynchronizedRenderer.h"
141  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVTransferFunction2D.h"
142  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVTransferFunction2DBox.h"
143  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVView.h"
144  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPVXYChartView.h"
145  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPointGaussianRepresentation.h"
146  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkPolarAxesRepresentation.h"
147  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkProgressBarSourceRepresentation.h"
148  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkQuartileChartRepresentation.h"
149  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkRulerSourceRepresentation.h"
150  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSIImageTextureProxy.h"
151  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSIPVRepresentationProxy.h"
152  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSIUnstructuredGridVolumeRepresentationProxy.h"
153  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMBoxRepresentationProxy.h"
154  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMCameraLink.h"
155  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMCameraProxy.h"
156  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMChartRepresentationProxy.h"
157  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMChartSeriesListDomain.h"
158  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMChartSeriesSelectionDomain.h"
159  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMChartUseIndexForAxisDomain.h"
160  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMCinemaVolumetricImageExtractWriterProxy.h"
161  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMColorMapEditorHelper.h"
162  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMComparativeAnimationCueProxy.h"
163  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMComparativeAnimationCueUndoElement.h"
164  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMComparativeViewProxy.h"
165  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMContextViewProxy.h"
166  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMContextItemWidgetProxy.h"
167  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMDataDeliveryManagerProxy.h"
168  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMDisplaySizedImplicitPlaneRepresentationProxy.h"
169  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMImageExtractWriterProxy.h"
170  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMImplicitPlaneRepresentationProxy.h"
171  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMLightProxy.h"
172  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMMaterialDomain.h"
173  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMMaterialLibraryProxy.h"
174  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMMultiSliceViewProxy.h"
175  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMNew2DWidgetRepresentationProxy.h"
176  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMNewWidgetRepresentationProxy.h"
177  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMNewWidgetRepresentationProxyAbstract.h"
178  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMOrthographicSliceViewProxy.h"
179  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMPVMoleculeRepresentationProxy.h"
180  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMPVRepresentationProxy.h"
181  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMParaViewPipelineControllerWithRendering.h"
182  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMPlotMatrixViewProxy.h"
183  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMPlotlyJsonExtractWriterProxy.h"
184  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMRangedTransferFunctionDomain.h"
185  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMRecolorableImageExtractWriterProxy.h"
186  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMRenderViewProxy.h"
187  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMRendererDomain.h"
188  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMRepresentationProxy.h"
189  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMRepresentationTypeDomain.h"
190  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMRepresentedArrayListDomain.h"
191  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMSaveScreenshotProxy.h"
192  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMScalarBarWidgetRepresentationProxy.h"
193  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMSelectionHelper.h"
194  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMSelectionLink.h"
195  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMSpreadSheetRepresentationProxy.h"
196  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMSpreadSheetViewProxy.h"
197  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMTextWidgetRepresentationProxy.h"
198  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMTransferFunction2DProxy.h"
199  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMTransferFunctionManager.h"
200  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMTransferFunctionPresets.h"
201  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMTransferFunctionProxy.h"
202  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMUtilities.h"
203  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMViewLayoutProxy.h"
204  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMViewLink.h"
205  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMViewProxy.h"
206  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMViewProxyInteractorHelper.h"
207  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMViewResolutionDomain.h"
208  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMWidgetRepresentationProxy.h"
209  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSMXYChartRepresentationInitializationHelper.h"
210  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSelectionRepresentation.h"
211  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSpreadSheetRepresentation.h"
212  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSpreadSheetView.h"
213  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkStructuredGridVolumeRepresentation.h"
214  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkSurfaceLICRepresentation.h"
215  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkTextSourceRepresentation.h"
216  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkThreeSliceFilter.h"
217  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkTilesHelper.h"
218  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkTransferFunctionBoxItem.h"
219  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkTransferFunctionChartHistogram2D.h"
220  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkUnstructuredGridVolumeRepresentation.h"
221  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkViewLayout.h"
222  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkVolumeRepresentation.h"
223  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkXYChartRepresentation.h"
224  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkIceTCompositePass.h"
225  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkIceTContext.h"
226  "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/vtkIceTSynchronizedRenderers.h"
227  "/builds/gitlab-kitware-sciviz-ci/build/Remoting/Views/vtkRemotingViewsModule.h"
228  )
229 endif()
230
231 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
232  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkRemotingViews-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkRemotingViews-hierarchy.txt")
233 endif()
234
235 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
236  foreach(file
237  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingViews-pv5.13.so.5.13"
238  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingViews-pv5.13.so.1"
239  )
240  if(EXISTS "${file}" AND
241  NOT IS_SYMLINK "${file}")
242  file(RPATH_CHECK
243  FILE "${file}"
244  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
245  endif()
246  endforeach()
247  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
248  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingViews-pv5.13.so.5.13"
249  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingViews-pv5.13.so.1"
250  )
251  foreach(file
252  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingViews-pv5.13.so.5.13"
253  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingViews-pv5.13.so.1"
254  )
255  if(EXISTS "${file}" AND
256  NOT IS_SYMLINK "${file}")
257  file(RPATH_CHANGE
258  FILE "${file}"
259  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
260  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
261  if(CMAKE_INSTALL_DO_STRIP)
262  execute_process(COMMAND "/usr/bin/strip" "${file}")
263  endif()
264  endif()
265  endforeach()
266 endif()
267
268 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
269  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingViews-pv5.13.so" AND
270  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingViews-pv5.13.so")
271  file(RPATH_CHECK
272  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingViews-pv5.13.so"
273  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
274  endif()
275  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingViews-pv5.13.so")
276  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingViews-pv5.13.so" AND
277  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingViews-pv5.13.so")
278  file(RPATH_CHANGE
279  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingViews-pv5.13.so"
280  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
281  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
282  if(CMAKE_INSTALL_DO_STRIP)
283  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingViews-pv5.13.so")
284  endif()
285  endif()
286 endif()
287
288 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xlicensesx" OR NOT CMAKE_INSTALL_COMPONENT)
289  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkRemotingViews" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Remoting/Views/LICENSE")
290 endif()
291
