1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkqttesting" TYPE FILE FILES
47  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/QtTestingExport.h"
48  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pq3DViewEventPlayer.h"
49  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pq3DViewEventTranslator.h"
50  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqAbstractActivateEventPlayer.h"
51  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqAbstractBooleanEventPlayer.h"
52  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqAbstractButtonEventTranslator.h"
53  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqAbstractDoubleEventPlayer.h"
54  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqAbstractIntEventPlayer.h"
55  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqAbstractItemViewEventPlayer.h"
56  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqAbstractItemViewEventPlayerBase.h"
57  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqAbstractItemViewEventTranslator.h"
58  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqAbstractItemViewEventTranslatorBase.h"
59  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqAbstractMiscellaneousEventPlayer.h"
60  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqAbstractSliderEventTranslator.h"
61  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqAbstractStringEventPlayer.h"
62  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqBasicWidgetEventPlayer.h"
63  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqBasicWidgetEventTranslator.h"
64  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqCheckEventOverlay.h"
65  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqComboBoxEventTranslator.h"
66  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqComboBoxEventPlayer.h"
67  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqCommentEventPlayer.h"
68  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqDoubleSpinBoxEventTranslator.h"
69  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqEventComment.h"
70  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqEventDispatcher.h"
71  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqEventObserver.h"
72  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqEventPlayer.h"
73  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqEventRecorder.h"
74  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqEventSource.h"
75  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqEventTranslator.h"
76  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqEventTypes.h"
77  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqLineEditEventTranslator.h"
78  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqListViewEventPlayer.h"
79  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqListViewEventTranslator.h"
80  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqMenuEventTranslator.h"
81  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqNativeFileDialogEventPlayer.h"
82  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqNativeFileDialogEventTranslator.h"
83  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqObjectNaming.h"
84  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqPlayBackEventsDialog.h"
85  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqRecordEventsDialog.h"
86  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqSpinBoxEventTranslator.h"
87  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqStdoutEventObserver.h"
88  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqTabBarEventPlayer.h"
89  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqTabBarEventTranslator.h"
90  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqTableViewEventPlayer.h"
91  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqTableViewEventTranslator.h"
92  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqTestUtility.h"
93  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqThreadedEventSource.h"
94  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqTimer.h"
95  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqTreeViewEventPlayer.h"
96  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqTreeViewEventTranslator.h"
97  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqWidgetEventPlayer.h"
98  "/builds/gitlab-kitware-sciviz-ci/ThirdParty/QtTesting/vtkqttesting/pqWidgetEventTranslator.h"
99  "/builds/gitlab-kitware-sciviz-ci/build/ThirdParty/QtTesting/vtkqttesting/QtTestingConfigure.h"
100  )
101 endif()
102
103 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
104  foreach(file
105  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkqttesting-pv5.13.so.5.13"
106  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkqttesting-pv5.13.so.1"
107  )
108  if(EXISTS "${file}" AND
109  NOT IS_SYMLINK "${file}")
110  file(RPATH_CHECK
111  FILE "${file}"
112  RPATH "\$ORIGIN")
113  endif()
114  endforeach()
115  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
116  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkqttesting-pv5.13.so.5.13"
117  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkqttesting-pv5.13.so.1"
118  )
119  foreach(file
120  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkqttesting-pv5.13.so.5.13"
121  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkqttesting-pv5.13.so.1"
122  )
123  if(EXISTS "${file}" AND
124  NOT IS_SYMLINK "${file}")
125  file(RPATH_CHANGE
126  FILE "${file}"
127  OLD_RPATH ":::::::"
128  NEW_RPATH "\$ORIGIN")
129  if(CMAKE_INSTALL_DO_STRIP)
130  execute_process(COMMAND "/usr/bin/strip" "${file}")
131  endif()
132  endif()
133  endforeach()
134 endif()
135
136 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
137  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkqttesting-pv5.13.so" AND
138  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkqttesting-pv5.13.so")
139  file(RPATH_CHECK
140  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkqttesting-pv5.13.so"
141  RPATH "\$ORIGIN")
142  endif()
143  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkqttesting-pv5.13.so")
144  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkqttesting-pv5.13.so" AND
145  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkqttesting-pv5.13.so")
146  file(RPATH_CHANGE
147  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkqttesting-pv5.13.so"
148  OLD_RPATH ":::::::"
149  NEW_RPATH "\$ORIGIN")
150  if(CMAKE_INSTALL_DO_STRIP)
151  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkqttesting-pv5.13.so")
152  endif()
153  endif()
154 endif()
155
