Go to the documentation of this file. 10 #ifndef vtk_m_internal_Configure_h 11 #define vtk_m_internal_Configure_h 20 #define VTKM_CUDA_DEVICE_PASS 33 #elif defined(__INTEL_COMPILER) 43 #elif defined(__ibmxl__) 47 #elif defined(__clang__) 52 #elif defined(__MINGW32__) 57 #elif defined(__GNUC__) 64 #if defined(unix) || defined(__unix) || defined(__unix__) || (defined(__APPLE__) && defined(__MACH__)) 66 # ifdef _POSIX_VERSION 67 # define VTKM_POSIX _POSIX_VERSION 75 #if !defined(VTKM_NO_ASSERT) 76 #define VTKM_NO_ASSERT 79 #if !defined(VTKM_NO_ASSERT_CUDA) 80 #define VTKM_NO_ASSERT_CUDA 83 #if !defined(VTKM_NO_ASSERT_HIP) 84 #define VTKM_NO_ASSERT_HIP 87 #if !defined(VTKM_USE_DOUBLE_PRECISION) && !defined(VTKM_NO_DOUBLE_PRECISION) 91 #if defined(VTKM_USE_DOUBLE_PRECISION) && defined(VTKM_NO_DOUBLE_PRECISION) 92 # error Both VTKM_USE_DOUBLE_PRECISION and VTKM_NO_DOUBLE_PRECISION defined. Do not know what to do. 95 #if !defined(VTKM_USE_64BIT_IDS) && !defined(VTKM_NO_64BIT_IDS) 96 #define VTKM_USE_64BIT_IDS 99 #if defined(VTKM_USE_64BIT_IDS) && defined(VTKM_NO_64BIT_IDS) 100 # error Both VTKM_USE_64BIT_IDS and VTKM_NO_64BIT_IDS defined. Do not know what to do. 103 #define VTKM_SIZE_LONG 8 104 #define VTKM_SIZE_LONG_LONG 8 107 #ifndef VTKM_ALLOCATION_ALIGNMENT 108 #define VTKM_ALLOCATION_ALIGNMENT 64 115 #if (defined(VTKM_GCC) || defined(VTKM_CLANG)) 117 #define VTK_M_THIRDPARTY_GENERAL_WARNING_PRAGMAS \ 118 _Pragma("GCC diagnostic ignored \"-Wconversion\"") \ 119 _Pragma("GCC diagnostic ignored \"-Wshadow\"") \ 120 _Pragma("GCC diagnostic ignored \"-Wunused-parameter\"") 123 #if defined(VTKM_GCC) 124 #define VTK_M_THIRDPARTY_GCC_WARNING_PRAGMAS \ 125 _Pragma("GCC diagnostic ignored \"-Wunused-but-set-variable\"") \ 126 _Pragma("GCC diagnostic ignored \"-Wunused-variable\"") 128 #define VTK_M_THIRDPARTY_GCC_WARNING_PRAGMAS 132 #if defined(VTKM_CLANG) && (__apple_build_version__ >= 7000072) 138 #define VTK_M_THIRDPARTY_CLANG_WARNING_PRAGMAS \ 139 _Pragma("GCC diagnostic ignored \"-Wunused-local-typedef\"") \ 140 _Pragma("GCC diagnostic ignored \"-Wnon-virtual-dtor\"") \ 141 _Pragma("GCC diagnostic ignored \"-Wdeprecated\"") 142 _Pragma(
"GCC diagnostic ignored \"-Wunused-template\"")
143 #elif defined(VTKM_CLANG) && defined(__ibmxl__) 144 #define VTK_M_THIRDPARTY_CLANG_WARNING_PRAGMAS \ 145 _Pragma("GCC diagnostic ignored \"-Wnon-virtual-dtor\"") \ 146 _Pragma("GCC diagnostic ignored \"-Wdeprecated\"") 147 #elif defined(VTKM_CLANG) 148 #define VTK_M_THIRDPARTY_CLANG_WARNING_PRAGMAS \ 149 _Pragma("GCC diagnostic ignored \"-Wnon-virtual-dtor\"") \ 150 _Pragma("GCC diagnostic ignored \"-Wdeprecated\"") 151 _Pragma(
153 #define VTK_M_THIRDPARTY_CLANG_WARNING_PRAGMAS 158 #if defined(VTKM_GCC) && (__GNUC__ == 4 && __GNUC_MINOR__ < 6) 159 #define VTK_M_THIRDPARTY_WARNINGS_PUSH 160 #define VTK_M_THRIDPARTY_WARNINGS_POP 162 #define VTK_M_THIRDPARTY_WARNINGS_PUSH _Pragma("GCC diagnostic push") 163 #define VTK_M_THRIDPARTY_WARNINGS_POP _Pragma("GCC diagnostic pop") 166 #define VTKM_THIRDPARTY_PRE_INCLUDE \ 167 VTK_M_THIRDPARTY_WARNINGS_PUSH \ 168 VTK_M_THIRDPARTY_GENERAL_WARNING_PRAGMAS \ 169 VTK_M_THIRDPARTY_GCC_WARNING_PRAGMAS \ 170 VTK_M_THIRDPARTY_CLANG_WARNING_PRAGMAS 171 #define VTKM_THIRDPARTY_POST_INCLUDE \ 172 VTK_M_THRIDPARTY_WARNINGS_POP 174 #elif (defined(VTKM_MSVC)) 175 #define VTKM_THIRDPARTY_PRE_INCLUDE \ 176 __pragma(warning(push)) \ 177 __pragma(warning(disable:4100)) \ 178 __pragma(warning(disable:4127)) \ 179 __pragma(warning(disable:4201)) \ 180 __pragma(warning(disable:4244)) \ 181 __pragma(warning(disable:4267)) \ 182 __pragma(warning(disable:4324)) \ 183 __pragma(warning(disable:4510)) \ 184 __pragma(warning(disable:4512)) \ 185 __pragma(warning(disable:4515)) \ 186 __pragma(warning(disable:4610)) \ 187 __pragma(warning(disable:4800)) 188 #define VTKM_THIRDPARTY_POST_INCLUDE \ 189 __pragma(warning(pop)) 191 #define VTKM_THIRDPARTY_PRE_INCLUDE 192 #define VTKM_THIRDPARTY_POST_INCLUDE 196 #if defined(__GLIBCXX__) && \ 197 (__GLIBCXX__ < 20150422 || __GLIBCXX__ == 20160726 || __GLIBCXX__ == 20150626 || \ 198 __GLIBCXX__ == 20150623) 215 #define VTKM_USING_GLIBCXX_4 224 #if ( defined(VTKM_GCC) && ( __GNUC__ > 4 || (__GNUC__ == 4 && __GNUC_MINOR__ >= 9) ) ) || \ 225 ( defined(VTKM_ICC) && (__INTEL_COMPILER >= 1500) ) || \ 226 ( defined(VTKM_CLANG) && defined(__apple_build_version__) && (__apple_build_version__ >= 7000000) ) || \ 227 ( defined(VTKM_CLANG) && !defined(__apple_build_version__) && (__clang_major__ > 3) ) || \ 228 ( defined(VTKM_CLANG) && !defined(__apple_build_version__) && (__clang_major__ == 3 && __clang_minor__ >= 5) ) 229 #define VTKM_COMPILER_SUPPORTS_VECTOR_PRAGMAS 1 239 #if defined(VTKM_COMPILER_SUPPORTS_VECTOR_PRAGMAS) &&\ 240 defined(VTKM_VECTORIZATION_ENABLED) 241 #if defined(VTKM_CLANG) 243 #define VTKM_VECTORIZATION_PRE_LOOP \ 244 _Pragma("clang loop vectorize(enable) interleave(enable)") 245 #define VTKM_VECTORIZATION_IN_LOOP 246 #elif defined(VTKM_ICC) && defined(NDEBUG) 261 #define VTKM_VECTORIZATION_PRE_LOOP 262 #define VTKM_VECTORIZATION_IN_LOOP 263 #elif defined(VTKM_GCC) 265 #define VTKM_VECTORIZATION_PRE_LOOP \ 267 #define VTKM_VECTORIZATION_IN_LOOP 270 #define VTKM_VECTORIZATION_PRE_LOOP 271 #define VTKM_VECTORIZATION_IN_LOOP 275 #define VTKM_VECTORIZATION_PRE_LOOP 276 #define VTKM_VECTORIZATION_IN_LOOP 280 #ifndef VTKM_ENABLE_CUDA 284 #ifndef VTKM_ENABLE_TBB 288 #ifndef VTKM_ENABLE_OPENMP 292 #ifndef VTKM_ENABLE_KOKKOS 296 #ifndef VTKM_KOKKOS_CUDA 300 #ifndef VTKM_KOKKOS_HIP 304 #if defined(VTKM_KOKKOS_HIP) || defined(VTKM_KOKKOS_CUDA) 317 #ifdef VTKM_ENABLE_CUDA 318 #define VTKM_CUDA_VERSION_MAJOR 319 #define VTKM_CUDA_VERSION_MINOR 322 #if __cplusplus >= 201402L || \ 323 ( defined(VTKM_MSVC) && _MSC_VER >= 1910 ) || \ 324 ( defined(VTKM_ICC) && defined(__INTEL_CXX11_MODE__) ) 325 #define VTKM_HAVE_CXX_14 327 #error "VTK-m requires at least a C++14 compiler" 331 #define VTKM_ENABLE_LOGGING 344 #define VTKM_SWALLOW_SEMICOLON_PRE_BLOCK \ 345 __pragma(warning(push)) \ 346 __pragma(warning(disable:4127)) \ 348 #define VTKM_SWALLOW_SEMICOLON_POST_BLOCK \ 350 __pragma(warning(pop)) 351 #else // not VTKM_MSVC 352 #define VTKM_SWALLOW_SEMICOLON_PRE_BLOCK \ 354 #define VTKM_SWALLOW_SEMICOLON_POST_BLOCK \ 364 #define VTKM_PASS_COMMAS(...) __VA_ARGS__ 394 #define VTKM_EXPAND(expr) expr 400 #pragma warning(disable:4503) 410 #pragma warning(disable:4251) 419 #if !defined(VTKM_FALLTHROUGH) && defined(__has_cpp_attribute) 420 # if __cplusplus >= 201703L && __has_cpp_attribute(fallthrough) 421 # define VTKM_FALLTHROUGH [[fallthrough]] 422 # elif __cplusplus >= 201103L && __has_cpp_attribute(gnu::fallthrough) 423 # define VTKM_FALLTHROUGH [[gnu::fallthrough]] 424 # elif __cplusplus >= 201103L && __has_cpp_attribute(clang::fallthrough) 425 # define VTKM_FALLTHROUGH [[clang::fallthrough]] 429 #ifndef VTKM_FALLTHROUGH 430 # define VTKM_FALLTHROUGH ((void)0) 433 #endif //vtkm_internal_Configure_h
