1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Utilities/PythonInterpreterPath 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
"/builds/gitlab-kitware-sciviz-ci/build/Utilities/PythonInterpreterPath/vtkUtilitiesPythonInterpreterPathModule.h")
49 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xruntimex
" OR NOT CMAKE_INSTALL_COMPONENT) 51 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInterpreterPath-pv5.13.so.5.13
" 52 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInterpreterPath-pv5.13.so.1
" 54 if(EXISTS "${file}
" TYPE SHARED_LIBRARY FILES 62 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkUtilitiesPythonInterpreterPath-pv5.13.so.5.13
" 63 "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkUtilitiesPythonInterpreterPath-pv5.13.so.1
" 66 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInterpreterPath-pv5.13.so.5.13
" 67 "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInterpreterPath-pv5.13.so.1
" 69 if(EXISTS "${file}
" "${file}
") 82 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 83 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInterpreterPath-pv5.13.so
" AND 84 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInterpreterPath-pv5.13.so
") 86 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInterpreterPath-pv5.13.so
" 89 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64
" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkUtilitiesPythonInterpreterPath-pv5.13.so
") 90 if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInterpreterPath-pv5.13.so
" AND 91 NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInterpreterPath-pv5.13.so
") 93 FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInterpreterPath-pv5.13.so
" 96 if(CMAKE_INSTALL_DO_STRIP) 97 execute_process(COMMAND "/usr/bin/strip
" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkUtilitiesPythonInterpreterPath-pv5.13.so
