1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Utilities/TestDriver
45 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
46  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/smTestDriver-pv5.13" AND
47  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/smTestDriver-pv5.13")
48  file(RPATH_CHECK
49  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/smTestDriver-pv5.13"
50  RPATH "\$ORIGIN:\$ORIGIN/../lib64")
51  endif()
52  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/bin" TYPE EXECUTABLE FILES "/builds/gitlab-kitware-sciviz-ci/build/bin/smTestDriver-pv5.13")
53  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/smTestDriver-pv5.13" AND
54  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/smTestDriver-pv5.13")
55  file(RPATH_CHANGE
56  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/smTestDriver-pv5.13"
57  OLD_RPATH "\$ORIGIN/../lib64::::::::"
58  NEW_RPATH "\$ORIGIN:\$ORIGIN/../lib64")
59  if(CMAKE_INSTALL_DO_STRIP)
60  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/bin/smTestDriver-pv5.13")
61  endif()
62  endif()
63 endif()
64
