1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Utilities/Versioning 3 # Set the install prefix 4 if(NOT DEFINED CMAKE_INSTALL_PREFIX)
5 set(CMAKE_INSTALL_PREFIX
"/usr/local")
7 string(REGEX REPLACE
"/$" "" CMAKE_INSTALL_PREFIX
"${CMAKE_INSTALL_PREFIX}")
12 string(REGEX REPLACE
"${BUILD_TYPE}")
"Debug")
17 message(STATUS
23 message(STATUS
"${COMPONENT}")
"0")
37 set(CMAKE_CROSSCOMPILING
"FALSE")
42 set(CMAKE_OBJDUMP
"/usr/bin/objdump")
45 if(
46 file(INSTALL DESTINATION
47 "/builds/gitlab-kitware-sciviz-ci/Utilities/Versioning/vtkParaViewDeprecation.h" 48 "/builds/gitlab-kitware-sciviz-ci/build/Utilities/Versioning/vtkPVVersion.h" 49 "/builds/gitlab-kitware-sciviz-ci/build/Utilities/Versioning/vtkPVVersionQuick.h" 53 if("x${CMAKE_INSTALL_COMPONENT}x
" STREQUAL "xdevelopmentx
" OR NOT CMAKE_INSTALL_COMPONENT) 54 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/
vtk/hierarchy/ParaView
" TYPE FILE RENAME "vtkPVVersioning-hierarchy.txt
vtk/hierarchy/ParaView/vtkPVVersioning-hierarchy.txt
" STREQUAL "xlicensesx
" OR NOT CMAKE_INSTALL_COMPONENT) 58 file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkPVVersioning
" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Utilities/Versioning/LICENSE
