1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core
47  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkMemberFunctionCommand.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkCLIOptions.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkCommunicationErrorCatcher.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkDistributedTrivialProducer.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkEmulatedTimeAlgorithm.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkFileSequenceParser.h"
53  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkLogRecorder.h"
54  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkMultiProcessControllerHelper.h"
55  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVCompositeDataPipeline.h"
56  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVDataUtilities.h"
57  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVInformationKeys.h"
58  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVLogger.h"
59  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVNullSource.h"
60  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVPostFilter.h"
61  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVPostFilterExecutive.h"
62  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVTestUtilities.h"
63  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVTrivialProducer.h"
64  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVXMLElement.h"
65  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVXMLParser.h"
66  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkStringList.h"
67  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkUndoElement.h"
68  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkUndoSet.h"
69  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkUndoStack.h"
70  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/vtkPVStringFormatter.h"
71  "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/Core/vtkPVVTKExtensionsCoreModule.h"
72  )
73 endif()
74
75 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
76  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkPVVTKExtensionsCore-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkPVVTKExtensionsCore-hierarchy.txt")
77 endif()
78
79 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
80  foreach(file
81  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.13.so.5.13"
82  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.13.so.1"
83  )
84  if(EXISTS "${file}" AND
85  NOT IS_SYMLINK "${file}")
86  file(RPATH_CHECK
87  FILE "${file}"
88  RPATH "\$ORIGIN")
89  endif()
90  endforeach()
91  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
92  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsCore-pv5.13.so.5.13"
93  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsCore-pv5.13.so.1"
94  )
95  foreach(file
96  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.13.so.5.13"
97  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.13.so.1"
98  )
99  if(EXISTS "${file}" AND
100  NOT IS_SYMLINK "${file}")
101  file(RPATH_CHANGE
102  FILE "${file}"
103  OLD_RPATH "\$ORIGIN:"
104  NEW_RPATH "\$ORIGIN")
105  if(CMAKE_INSTALL_DO_STRIP)
106  execute_process(COMMAND "/usr/bin/strip" "${file}")
107  endif()
108  endif()
109  endforeach()
110 endif()
111
112 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
113  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.13.so" AND
114  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.13.so")
115  file(RPATH_CHECK
116  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.13.so"
117  RPATH "\$ORIGIN")
118  endif()
119  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsCore-pv5.13.so")
120  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.13.so" AND
121  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.13.so")
122  file(RPATH_CHANGE
123  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.13.so"
124  OLD_RPATH "\$ORIGIN:"
125  NEW_RPATH "\$ORIGIN")
126  if(CMAKE_INSTALL_DO_STRIP)
127  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsCore-pv5.13.so")
128  endif()
129  endif()
130 endif()
131
