1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore
47  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkAdditionalFieldReader.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkCSVWriter.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkFileSeriesReader.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkFileSeriesWriter.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkMetaReader.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkParallelSerialWriter.h"
53  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkPVDReader.h"
54  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkStringReader.h"
55  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkStringWriter.h"
56  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkXMLCollectionReader.h"
57  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/vtkXMLPVDWriter.h"
58  "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/IOCore/vtkPVVTKExtensionsIOCoreModule.h"
59  )
60 endif()
61
62 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
63  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkPVVTKExtensionsIOCore-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkPVVTKExtensionsIOCore-hierarchy.txt")
64 endif()
65
66 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
67  foreach(file
68  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOCore-pv5.13.so.5.13"
69  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOCore-pv5.13.so.1"
70  )
71  if(EXISTS "${file}" AND
72  NOT IS_SYMLINK "${file}")
73  file(RPATH_CHECK
74  FILE "${file}"
75  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
76  endif()
77  endforeach()
78  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
79  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsIOCore-pv5.13.so.5.13"
80  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsIOCore-pv5.13.so.1"
81  )
82  foreach(file
83  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOCore-pv5.13.so.5.13"
84  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOCore-pv5.13.so.1"
85  )
86  if(EXISTS "${file}" AND
87  NOT IS_SYMLINK "${file}")
88  file(RPATH_CHANGE
89  FILE "${file}"
90  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
91  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
92  if(CMAKE_INSTALL_DO_STRIP)
93  execute_process(COMMAND "/usr/bin/strip" "${file}")
94  endif()
95  endif()
96  endforeach()
97 endif()
98
99 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
100  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOCore-pv5.13.so" AND
101  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOCore-pv5.13.so")
102  file(RPATH_CHECK
103  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOCore-pv5.13.so"
104  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
105  endif()
106  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsIOCore-pv5.13.so")
107  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOCore-pv5.13.so" AND
108  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOCore-pv5.13.so")
109  file(RPATH_CHANGE
110  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOCore-pv5.13.so"
111  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
112  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
113  if(CMAKE_INSTALL_DO_STRIP)
114  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOCore-pv5.13.so")
115  endif()
116  endif()
117 endif()
118
119 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xlicensesx" OR NOT CMAKE_INSTALL_COMPONENT)
120  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkPVVTKExtensionsIOCore" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/LICENSE")
121 endif()
122
