1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc
47  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/vtkAppendRectilinearGrid.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/vtkAttributeDataReductionFilter.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/vtkCleanArrays.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/vtkCompleteArrays.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/vtkEnvironmentAnnotationFilter.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/vtkMergeBlocks.h"
53  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/vtkMinMax.h"
54  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/vtkPExtractHistogram.h"
55  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/vtkPVExtractHistogram2D.h"
56  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/vtkPVBox.h"
57  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/vtkPVChangeOfBasisHelper.h"
58  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/vtkPVCylinder.h"
59  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/vtkPVMergeTables.h"
60  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/vtkPVMergeTablesMultiBlock.h"
61  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/vtkPVPlane.h"
62  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/vtkPVTransform.h"
63  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/vtkPVRotateAroundOriginTransform.h"
64  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/vtkReductionFilter.h"
65  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/vtkSelectionSerializer.h"
66  "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/Misc/vtkPVVTKExtensionsMiscModule.h"
67  )
68 endif()
69
70 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
71  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkPVVTKExtensionsMisc-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkPVVTKExtensionsMisc-hierarchy.txt")
72 endif()
73
74 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
75  foreach(file
76  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.13.so.5.13"
77  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.13.so.1"
78  )
79  if(EXISTS "${file}" AND
80  NOT IS_SYMLINK "${file}")
81  file(RPATH_CHECK
82  FILE "${file}"
83  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
84  endif()
85  endforeach()
86  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
87  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsMisc-pv5.13.so.5.13"
88  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsMisc-pv5.13.so.1"
89  )
90  foreach(file
91  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.13.so.5.13"
92  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.13.so.1"
93  )
94  if(EXISTS "${file}" AND
95  NOT IS_SYMLINK "${file}")
96  file(RPATH_CHANGE
97  FILE "${file}"
98  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
99  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
100  if(CMAKE_INSTALL_DO_STRIP)
101  execute_process(COMMAND "/usr/bin/strip" "${file}")
102  endif()
103  endif()
104  endforeach()
105 endif()
106
107 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
108  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.13.so" AND
109  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.13.so")
110  file(RPATH_CHECK
111  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.13.so"
112  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
113  endif()
114  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsMisc-pv5.13.so")
115  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.13.so" AND
116  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.13.so")
117  file(RPATH_CHANGE
118  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.13.so"
119  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
120  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
121  if(CMAKE_INSTALL_DO_STRIP)
122  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsMisc-pv5.13.so")
123  endif()
124  endif()
125 endif()
126
