3 if(
4 message(FATAL_ERROR
"CMake >= 2.6.0 required")
15 # Protect against multiple inclusion, which would fail when already imported targets are added once more.
17 set(_targetsNotDefined)
19 foreach(_expectedTarget VTK::vtkCommonCorePython VTK::vtkWebCorePython VTK::vtkCommonMathPython VTK::vtkCommonTransformsPython VTK::vtkCommonDataModelPython VTK::vtkCommonExecutionModelPython VTK::vtkIOCorePython VTK::vtkImagingCorePython VTK::vtkIOImagePython VTK::vtkIOXMLParserPython VTK::vtkIOXMLPython VTK::vtkCommonMiscPython VTK::vtkFiltersCorePython VTK::vtkRenderingCorePython VTK::vtkRenderingContext2DPython VTK::vtkRenderingFreeTypePython VTK::vtkRenderingSceneGraphPython VTK::vtkRenderingVtkJSPython VTK::vtkIOExportPython VTK::vtkWebGLExporterPython VTK::vtkFiltersGeneralPython VTK::vtkFiltersSourcesPython VTK::vtkInteractionWidgetsPython VTK::vtkViewsCorePython VTK::vtkViewsContext2DPython VTK::vtkRenderingUIPython VTK::vtkImagingColorPython VTK::vtkTestingRenderingPython VTK::vtkRenderingVolumePython VTK::vtkImagingMathPython VTK::vtkRenderingHyperTreeGridPython VTK::vtkRenderingOpenGL2Python VTK::vtkRenderingVolumeOpenGL2Python VTK::vtkRenderingVolumeAMRPython VTK::vtkParallelCorePython VTK::vtkParallelMPIPython VTK::vtkRenderingLICOpenGL2Python VTK::vtkRenderingParallelLICPython VTK::vtkRenderingParallelPython VTK::vtkRenderingMatplotlibPython VTK::vtkRenderingLabelPython VTK::vtkRenderingContextOpenGL2Python VTK::vtkFiltersCellGridPython VTK::vtkRenderingCellGridPython VTK::vtkParallelMPI4PyPython VTK::vtkImagingFourierPython VTK::vtkIOCellGridPython VTK::vtkIOLegacyPython VTK::vtkIOXdmf2Python VTK::vtkIOVeraOutPython VTK::vtkIOVPICPython VTK::vtkIOTecplotTablePython VTK::vtkIOTRUCHASPython VTK::vtkIOSegYPython VTK::vtkIOParallelXMLPython VTK::vtkIONetCDFPython VTK::vtkIOParallelNetCDFPython VTK::vtkIOLSDynaPython VTK::vtkIOParallelLSDynaPython VTK::vtkIOExodusPython VTK::vtkIOParallelExodusPython VTK::vtkIOPLYPython VTK::vtkIOPIOPython VTK::vtkIOMoviePython VTK::vtkIOOggTheoraPython VTK::vtkIOOMFPython VTK::vtkIOGeometryPython VTK::vtkIOParallelPython VTK::vtkIOMPIImagePython VTK::vtkIOImportPython VTK::vtkIOIOSSPython VTK::vtkIOH5partPython VTK::vtkIOH5RagePython VTK::vtkIOFLUENTCFFPython VTK::vtkIOFDSPython VTK::vtkIOInfovisPython VTK::vtkCommonColorPython VTK::vtkImagingSourcesPython VTK::vtkInfovisCorePython VTK::vtkRenderingGL2PSOpenGL2Python VTK::vtkIOExportGL2PSPython VTK::vtkIOEnSightPython VTK::vtkIOHDFPython VTK::vtkIOERFPython VTK::vtkIOCityGMLPython VTK::vtkIOChemistryPython VTK::vtkIOCONVERGECFDPython VTK::vtkIOCGNSReaderPython VTK::vtkIOAsynchronousPython VTK::vtkIOAMRPython VTK::vtkGeovisCorePython VTK::vtkRenderingAnnotationPython VTK::vtkInteractionStylePython VTK::vtkImagingHybridPython VTK::vtkFiltersTensorPython VTK::vtkFiltersTemporalPython VTK::vtkFiltersPythonPython VTK::vtkFiltersProgrammablePython VTK::vtkFiltersModelingPython VTK::vtkFiltersPointsPython VTK::vtkFiltersVerdictPython VTK::vtkFiltersParallelVerdictPython VTK::vtkFiltersStatisticsPython VTK::vtkFiltersParallelStatisticsPython VTK::vtkCommonSystemPython VTK::vtkFiltersGeometryPython VTK::vtkFiltersExtractionPython VTK::vtkFiltersHybridPython VTK::vtkFiltersHyperTreePython VTK::vtkFiltersTexturePython VTK::vtkFiltersParallelPython VTK::vtkFiltersParallelGeometryPython VTK::vtkCommonComputationalGeometryPython VTK::vtkFiltersFlowPathsPython VTK::vtkFiltersParallelFlowPathsPython VTK::vtkFiltersParallelDIY2Python VTK::vtkFiltersImagingPython VTK::vtkImagingGeneralPython VTK::vtkFiltersGeometryPreviewPython VTK::vtkFiltersGenericPython VTK::vtkFiltersAMRPython VTK::vtkFiltersParallelMPIPython VTK::vtkDomainsChemistryPython VTK::vtkDomainsChemistryOpenGL2Python VTK::vtkChartsCorePython VTK::vtkAcceleratorsVTKmCorePython VTK::vtkAcceleratorsVTKmDataModelPython VTK::vtkAcceleratorsVTKmFiltersPython VTK::vtkFiltersReductionPython VTK::vtkpythonmodules)
20 list(APPEND _expectedTargets ${_expectedTarget})
21 if(NOT TARGET ${_expectedTarget})
22 list(APPEND _targetsNotDefined ${_expectedTarget})
24 if(TARGET ${_expectedTarget})
25 list(APPEND _targetsDefined ${_expectedTarget})
28 if("${_targetsDefined}
") 29 unset(_targetsDefined) 30 unset(_targetsNotDefined) 31 unset(_expectedTargets) 32 set(CMAKE_IMPORT_FILE_VERSION) 36 if(NOT "${_targetsDefined}
" STREQUAL "") 37 message(FATAL_ERROR "Some (but not all) targets in
this export
") 39 unset(_targetsDefined) 40 unset(_targetsNotDefined) 41 unset(_expectedTargets) 44 # Compute the installation prefix relative to this file. 45 get_filename_component(_IMPORT_PREFIX "${CMAKE_CURRENT_LIST_FILE}
" PATH) 46 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 47 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 48 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 49 get_filename_component(_IMPORT_PREFIX "${_IMPORT_PREFIX}
" PATH) 50 if(_IMPORT_PREFIX STREQUAL "/
") 51 set(_IMPORT_PREFIX "") 54 # Create imported target VTK::vtkCommonCorePython 55 add_library(VTK::vtkCommonCorePython MODULE IMPORTED) 57 # Create imported target VTK::vtkWebCorePython 58 add_library(VTK::vtkWebCorePython MODULE IMPORTED) 60 # Create imported target VTK::vtkCommonMathPython 61 add_library(VTK::vtkCommonMathPython MODULE IMPORTED) 63 # Create imported target VTK::vtkCommonTransformsPython 64 add_library(VTK::vtkCommonTransformsPython MODULE IMPORTED) 66 # Create imported target VTK::vtkCommonDataModelPython 67 add_library(VTK::vtkCommonDataModelPython MODULE IMPORTED) 69 # Create imported target VTK::vtkCommonExecutionModelPython 70 add_library(VTK::vtkCommonExecutionModelPython MODULE IMPORTED) 72 # Create imported target VTK::vtkIOCorePython 73 add_library(VTK::vtkIOCorePython MODULE IMPORTED) 75 # Create imported target VTK::vtkImagingCorePython 76 add_library(VTK::vtkImagingCorePython MODULE IMPORTED) 78 # Create imported target VTK::vtkIOImagePython 79 add_library(VTK::vtkIOImagePython MODULE IMPORTED) 81 # Create imported target VTK::vtkIOXMLParserPython 82 add_library(VTK::vtkIOXMLParserPython MODULE IMPORTED) 84 # Create imported target VTK::vtkIOXMLPython 85 add_library(VTK::vtkIOXMLPython MODULE IMPORTED) 87 # Create imported target VTK::vtkCommonMiscPython 88 add_library(VTK::vtkCommonMiscPython MODULE IMPORTED) 90 # Create imported target VTK::vtkFiltersCorePython 91 add_library(VTK::vtkFiltersCorePython MODULE IMPORTED) 93 # Create imported target VTK::vtkRenderingCorePython 94 add_library(VTK::vtkRenderingCorePython MODULE IMPORTED) 96 # Create imported target VTK::vtkRenderingContext2DPython 97 add_library(VTK::vtkRenderingContext2DPython MODULE IMPORTED) 99 # Create imported target VTK::vtkRenderingFreeTypePython 100 add_library(VTK::vtkRenderingFreeTypePython MODULE IMPORTED) 102 # Create imported target VTK::vtkRenderingSceneGraphPython 103 add_library(VTK::vtkRenderingSceneGraphPython MODULE IMPORTED) 105 # Create imported target VTK::vtkRenderingVtkJSPython 106 add_library(VTK::vtkRenderingVtkJSPython MODULE IMPORTED) 108 # Create imported target VTK::vtkIOExportPython 109 add_library(VTK::vtkIOExportPython MODULE IMPORTED) 111 # Create imported target VTK::vtkWebGLExporterPython 112 add_library(VTK::vtkWebGLExporterPython MODULE IMPORTED) 114 # Create imported target VTK::vtkFiltersGeneralPython 115 add_library(VTK::vtkFiltersGeneralPython MODULE IMPORTED) 117 # Create imported target VTK::vtkFiltersSourcesPython 118 add_library(VTK::vtkFiltersSourcesPython MODULE IMPORTED) 120 # Create imported target VTK::vtkInteractionWidgetsPython 121 add_library(VTK::vtkInteractionWidgetsPython MODULE IMPORTED) 123 # Create imported target VTK::vtkViewsCorePython 124 add_library(VTK::vtkViewsCorePython MODULE IMPORTED) 126 # Create imported target VTK::vtkViewsContext2DPython 127 add_library(VTK::vtkViewsContext2DPython MODULE IMPORTED) 129 # Create imported target VTK::vtkRenderingUIPython 130 add_library(VTK::vtkRenderingUIPython MODULE IMPORTED) 132 # Create imported target VTK::vtkImagingColorPython 133 add_library(VTK::vtkImagingColorPython MODULE IMPORTED) 135 # Create imported target VTK::vtkTestingRenderingPython 136 add_library(VTK::vtkTestingRenderingPython MODULE IMPORTED) 138 # Create imported target VTK::vtkRenderingVolumePython 139 add_library(VTK::vtkRenderingVolumePython MODULE IMPORTED) 141 # Create imported target VTK::vtkImagingMathPython 142 add_library(VTK::vtkImagingMathPython MODULE IMPORTED) 144 # Create imported target VTK::vtkRenderingHyperTreeGridPython 145 add_library(VTK::vtkRenderingHyperTreeGridPython MODULE IMPORTED) 147 # Create imported target VTK::vtkRenderingOpenGL2Python 148 add_library(VTK::vtkRenderingOpenGL2Python MODULE IMPORTED) 150 # Create imported target VTK::vtkRenderingVolumeOpenGL2Python 151 add_library(VTK::vtkRenderingVolumeOpenGL2Python MODULE IMPORTED) 153 # Create imported target VTK::vtkRenderingVolumeAMRPython 154 add_library(VTK::vtkRenderingVolumeAMRPython MODULE IMPORTED) 156 # Create imported target VTK::vtkParallelCorePython 157 add_library(VTK::vtkParallelCorePython MODULE IMPORTED) 159 # Create imported target VTK::vtkParallelMPIPython 160 add_library(VTK::vtkParallelMPIPython MODULE IMPORTED) 162 # Create imported target VTK::vtkRenderingLICOpenGL2Python 163 add_library(VTK::vtkRenderingLICOpenGL2Python MODULE IMPORTED) 165 # Create imported target VTK::vtkRenderingParallelLICPython 166 add_library(VTK::vtkRenderingParallelLICPython MODULE IMPORTED) 168 # Create imported target VTK::vtkRenderingParallelPython 169 add_library(VTK::vtkRenderingParallelPython MODULE IMPORTED) 171 # Create imported target VTK::vtkRenderingMatplotlibPython 172 add_library(VTK::vtkRenderingMatplotlibPython MODULE IMPORTED) 174 # Create imported target VTK::vtkRenderingLabelPython 175 add_library(VTK::vtkRenderingLabelPython MODULE IMPORTED) 177 # Create imported target VTK::vtkRenderingContextOpenGL2Python 178 add_library(VTK::vtkRenderingContextOpenGL2Python MODULE IMPORTED) 180 # Create imported target VTK::vtkFiltersCellGridPython 181 add_library(VTK::vtkFiltersCellGridPython MODULE IMPORTED) 183 # Create imported target VTK::vtkRenderingCellGridPython 184 add_library(VTK::vtkRenderingCellGridPython MODULE IMPORTED) 186 # Create imported target VTK::vtkParallelMPI4PyPython 187 add_library(VTK::vtkParallelMPI4PyPython MODULE IMPORTED) 189 # Create imported target VTK::vtkImagingFourierPython 190 add_library(VTK::vtkImagingFourierPython MODULE IMPORTED) 192 # Create imported target VTK::vtkIOCellGridPython 193 add_library(VTK::vtkIOCellGridPython MODULE IMPORTED) 195 # Create imported target VTK::vtkIOLegacyPython 196 add_library(VTK::vtkIOLegacyPython MODULE IMPORTED) 198 # Create imported target VTK::vtkIOXdmf2Python 199 add_library(VTK::vtkIOXdmf2Python MODULE IMPORTED) 201 # Create imported target VTK::vtkIOVeraOutPython 202 add_library(VTK::vtkIOVeraOutPython MODULE IMPORTED) 204 # Create imported target VTK::vtkIOVPICPython 205 add_library(VTK::vtkIOVPICPython MODULE IMPORTED) 207 # Create imported target VTK::vtkIOTecplotTablePython 208 add_library(VTK::vtkIOTecplotTablePython MODULE IMPORTED) 210 # Create imported target VTK::vtkIOTRUCHASPython 211 add_library(VTK::vtkIOTRUCHASPython MODULE IMPORTED) 213 # Create imported target VTK::vtkIOSegYPython 214 add_library(VTK::vtkIOSegYPython MODULE IMPORTED) 216 # Create imported target VTK::vtkIOParallelXMLPython 217 add_library(VTK::vtkIOParallelXMLPython MODULE IMPORTED) 219 # Create imported target VTK::vtkIONetCDFPython 220 add_library(VTK::vtkIONetCDFPython MODULE IMPORTED) 222 # Create imported target VTK::vtkIOParallelNetCDFPython 223 add_library(VTK::vtkIOParallelNetCDFPython MODULE IMPORTED) 225 # Create imported target VTK::vtkIOLSDynaPython 226 add_library(VTK::vtkIOLSDynaPython MODULE IMPORTED) 228 # Create imported target VTK::vtkIOParallelLSDynaPython 229 add_library(VTK::vtkIOParallelLSDynaPython MODULE IMPORTED) 231 # Create imported target VTK::vtkIOExodusPython 232 add_library(VTK::vtkIOExodusPython MODULE IMPORTED) 234 # Create imported target VTK::vtkIOParallelExodusPython 235 add_library(VTK::vtkIOParallelExodusPython MODULE IMPORTED) 237 # Create imported target VTK::vtkIOPLYPython 238 add_library(VTK::vtkIOPLYPython MODULE IMPORTED) 240 # Create imported target VTK::vtkIOPIOPython 241 add_library(VTK::vtkIOPIOPython MODULE IMPORTED) 243 # Create imported target VTK::vtkIOMoviePython 244 add_library(VTK::vtkIOMoviePython MODULE IMPORTED) 246 # Create imported target VTK::vtkIOOggTheoraPython 247 add_library(VTK::vtkIOOggTheoraPython MODULE IMPORTED) 249 # Create imported target VTK::vtkIOOMFPython 250 add_library(VTK::vtkIOOMFPython MODULE IMPORTED) 252 # Create imported target VTK::vtkIOGeometryPython 253 add_library(VTK::vtkIOGeometryPython MODULE IMPORTED) 255 # Create imported target VTK::vtkIOParallelPython 256 add_library(VTK::vtkIOParallelPython MODULE IMPORTED) 258 # Create imported target VTK::vtkIOMPIImagePython 259 add_library(VTK::vtkIOMPIImagePython MODULE IMPORTED) 261 # Create imported target VTK::vtkIOImportPython 262 add_library(VTK::vtkIOImportPython MODULE IMPORTED) 264 # Create imported target VTK::vtkIOIOSSPython 265 add_library(VTK::vtkIOIOSSPython MODULE IMPORTED) 267 # Create imported target VTK::vtkIOH5partPython 268 add_library(VTK::vtkIOH5partPython MODULE IMPORTED) 270 # Create imported target VTK::vtkIOH5RagePython 271 add_library(VTK::vtkIOH5RagePython MODULE IMPORTED) 273 # Create imported target VTK::vtkIOFLUENTCFFPython 274 add_library(VTK::vtkIOFLUENTCFFPython MODULE IMPORTED) 276 # Create imported target VTK::vtkIOFDSPython 277 add_library(VTK::vtkIOFDSPython MODULE IMPORTED) 279 # Create imported target VTK::vtkIOInfovisPython 280 add_library(VTK::vtkIOInfovisPython MODULE IMPORTED) 282 # Create imported target VTK::vtkCommonColorPython 283 add_library(VTK::vtkCommonColorPython MODULE IMPORTED) 285 # Create imported target VTK::vtkImagingSourcesPython 286 add_library(VTK::vtkImagingSourcesPython MODULE IMPORTED) 288 # Create imported target VTK::vtkInfovisCorePython 289 add_library(VTK::vtkInfovisCorePython MODULE IMPORTED) 291 # Create imported target VTK::vtkRenderingGL2PSOpenGL2Python 292 add_library(VTK::vtkRenderingGL2PSOpenGL2Python MODULE IMPORTED) 294 # Create imported target VTK::vtkIOExportGL2PSPython 295 add_library(VTK::vtkIOExportGL2PSPython MODULE IMPORTED) 297 # Create imported target VTK::vtkIOEnSightPython 298 add_library(VTK::vtkIOEnSightPython MODULE IMPORTED) 300 # Create imported target VTK::vtkIOHDFPython 301 add_library(VTK::vtkIOHDFPython MODULE IMPORTED) 303 # Create imported target VTK::vtkIOERFPython 304 add_library(VTK::vtkIOERFPython MODULE IMPORTED) 306 # Create imported target VTK::vtkIOCityGMLPython 307 add_library(VTK::vtkIOCityGMLPython MODULE IMPORTED) 309 # Create imported target VTK::vtkIOChemistryPython 310 add_library(VTK::vtkIOChemistryPython MODULE IMPORTED) 312 # Create imported target VTK::vtkIOCONVERGECFDPython 313 add_library(VTK::vtkIOCONVERGECFDPython MODULE IMPORTED) 315 # Create imported target VTK::vtkIOCGNSReaderPython 316 add_library(VTK::vtkIOCGNSReaderPython MODULE IMPORTED) 318 # Create imported target VTK::vtkIOAsynchronousPython 319 add_library(VTK::vtkIOAsynchronousPython MODULE IMPORTED) 321 # Create imported target VTK::vtkIOAMRPython 322 add_library(VTK::vtkIOAMRPython MODULE IMPORTED) 324 # Create imported target VTK::vtkGeovisCorePython 325 add_library(VTK::vtkGeovisCorePython MODULE IMPORTED) 327 # Create imported target VTK::vtkRenderingAnnotationPython 328 add_library(VTK::vtkRenderingAnnotationPython MODULE IMPORTED) 330 # Create imported target VTK::vtkInteractionStylePython 331 add_library(VTK::vtkInteractionStylePython MODULE IMPORTED) 333 # Create imported target VTK::vtkImagingHybridPython 334 add_library(VTK::vtkImagingHybridPython MODULE IMPORTED) 336 # Create imported target VTK::vtkFiltersTensorPython 337 add_library(VTK::vtkFiltersTensorPython MODULE IMPORTED) 339 # Create imported target VTK::vtkFiltersTemporalPython 340 add_library(VTK::vtkFiltersTemporalPython MODULE IMPORTED) 342 # Create imported target VTK::vtkFiltersPythonPython 343 add_library(VTK::vtkFiltersPythonPython MODULE IMPORTED) 345 # Create imported target VTK::vtkFiltersProgrammablePython 346 add_library(VTK::vtkFiltersProgrammablePython MODULE IMPORTED) 348 # Create imported target VTK::vtkFiltersModelingPython 349 add_library(VTK::vtkFiltersModelingPython MODULE IMPORTED) 351 # Create imported target VTK::vtkFiltersPointsPython 352 add_library(VTK::vtkFiltersPointsPython MODULE IMPORTED) 354 # Create imported target VTK::vtkFiltersVerdictPython 355 add_library(VTK::vtkFiltersVerdictPython MODULE IMPORTED) 357 # Create imported target VTK::vtkFiltersParallelVerdictPython 358 add_library(VTK::vtkFiltersParallelVerdictPython MODULE IMPORTED) 360 # Create imported target VTK::vtkFiltersStatisticsPython 361 add_library(VTK::vtkFiltersStatisticsPython MODULE IMPORTED) 363 # Create imported target VTK::vtkFiltersParallelStatisticsPython 364 add_library(VTK::vtkFiltersParallelStatisticsPython MODULE IMPORTED) 366 # Create imported target VTK::vtkCommonSystemPython 367 add_library(VTK::vtkCommonSystemPython MODULE IMPORTED) 369 # Create imported target VTK::vtkFiltersGeometryPython 370 add_library(VTK::vtkFiltersGeometryPython MODULE IMPORTED) 372 # Create imported target VTK::vtkFiltersExtractionPython 373 add_library(VTK::vtkFiltersExtractionPython MODULE IMPORTED) 375 # Create imported target VTK::vtkFiltersHybridPython 376 add_library(VTK::vtkFiltersHybridPython MODULE IMPORTED) 378 # Create imported target VTK::vtkFiltersHyperTreePython 379 add_library(VTK::vtkFiltersHyperTreePython MODULE IMPORTED) 381 # Create imported target VTK::vtkFiltersTexturePython 382 add_library(VTK::vtkFiltersTexturePython MODULE IMPORTED) 384 # Create imported target VTK::vtkFiltersParallelPython 385 add_library(VTK::vtkFiltersParallelPython MODULE IMPORTED) 387 # Create imported target VTK::vtkFiltersParallelGeometryPython 388 add_library(VTK::vtkFiltersParallelGeometryPython MODULE IMPORTED) 390 # Create imported target VTK::vtkCommonComputationalGeometryPython 391 add_library(VTK::vtkCommonComputationalGeometryPython MODULE IMPORTED) 393 # Create imported target VTK::vtkFiltersFlowPathsPython 394 add_library(VTK::vtkFiltersFlowPathsPython MODULE IMPORTED) 396 # Create imported target VTK::vtkFiltersParallelFlowPathsPython 397 add_library(VTK::vtkFiltersParallelFlowPathsPython MODULE IMPORTED) 399 # Create imported target VTK::vtkFiltersParallelDIY2Python 400 add_library(VTK::vtkFiltersParallelDIY2Python MODULE IMPORTED) 402 # Create imported target VTK::vtkFiltersImagingPython 403 add_library(VTK::vtkFiltersImagingPython MODULE IMPORTED) 405 # Create imported target VTK::vtkImagingGeneralPython 406 add_library(VTK::vtkImagingGeneralPython MODULE IMPORTED) 408 # Create imported target VTK::vtkFiltersGeometryPreviewPython 409 add_library(VTK::vtkFiltersGeometryPreviewPython MODULE IMPORTED) 411 # Create imported target VTK::vtkFiltersGenericPython 412 add_library(VTK::vtkFiltersGenericPython MODULE IMPORTED) 414 # Create imported target VTK::vtkFiltersAMRPython 415 add_library(VTK::vtkFiltersAMRPython MODULE IMPORTED) 417 # Create imported target VTK::vtkFiltersParallelMPIPython 418 add_library(VTK::vtkFiltersParallelMPIPython MODULE IMPORTED) 420 # Create imported target VTK::vtkDomainsChemistryPython 421 add_library(VTK::vtkDomainsChemistryPython MODULE IMPORTED) 423 # Create imported target VTK::vtkDomainsChemistryOpenGL2Python 424 add_library(VTK::vtkDomainsChemistryOpenGL2Python MODULE IMPORTED) 426 # Create imported target VTK::vtkChartsCorePython 427 add_library(VTK::vtkChartsCorePython MODULE IMPORTED) 429 # Create imported target VTK::vtkAcceleratorsVTKmCorePython 430 add_library(VTK::vtkAcceleratorsVTKmCorePython MODULE IMPORTED) 432 # Create imported target VTK::vtkAcceleratorsVTKmDataModelPython 433 add_library(VTK::vtkAcceleratorsVTKmDataModelPython MODULE IMPORTED) 435 # Create imported target VTK::vtkAcceleratorsVTKmFiltersPython 436 add_library(VTK::vtkAcceleratorsVTKmFiltersPython MODULE IMPORTED) 438 # Create imported target VTK::vtkFiltersReductionPython 439 add_library(VTK::vtkFiltersReductionPython MODULE IMPORTED) 441 # Create imported target VTK::vtkpythonmodules 442 add_library(VTK::vtkpythonmodules INTERFACE IMPORTED) 444 set_target_properties(VTK::vtkpythonmodules PROPERTIES 445 INTERFACE_INCLUDE_DIRECTORIES "${_IMPORT_PREFIX}/include/paraview-5.13/vtkpythonmodules
" 448 if(CMAKE_VERSION VERSION_LESS 3.0.0) 449 message(FATAL_ERROR "This file relies
on consumers
using CMake 3.0.0 or greater.
") 452 # Load information for each installed configuration. 453 get_filename_component(_DIR "${CMAKE_CURRENT_LIST_FILE}
" PATH) 454 file(GLOB CONFIG_FILES "${_DIR}/VTKPython-targets-*.cmake
") 455 foreach(f ${CONFIG_FILES}) 459 # Cleanup temporary variables. 462 # Loop over all imported files and verify that they actually exist 463 foreach(target ${_IMPORT_CHECK_TARGETS} ) 464 foreach(file ${_IMPORT_CHECK_FILES_FOR_${target}} ) 465 if(NOT EXISTS "${file}
" ) 466 message(FATAL_ERROR "The imported
target \
"${target}\" references the file 468 but this file does not exist. Possible reasons include: 469 * The file was deleted, renamed, or moved to another location. 470 * An install or uninstall procedure did not complete successfully. 471 * The installation package was faulty and contained 472 \"${CMAKE_CURRENT_LIST_FILE}\" 473 but not all the files it references. 477 unset(_IMPORT_CHECK_FILES_FOR_${
target})
479 unset(_IMPORT_CHECK_TARGETS)
481 # This file does not depend on other imported targets which have 482 # been exported from the same project but in a separate export set. 484 # Commands beyond this point should not need to know the version. 485 set(CMAKE_IMPORT_FILE_VERSION)
