1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Accelerators/Vtkm/DataModel
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Accelerators/Vtkm/DataModel/vtkmConfigDataModel.h")
47 endif()
48
49 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
50  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Accelerators/Vtkm/DataModel/vtkmDataSet.h")
51 endif()
52
53 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
54  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkmlib" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Accelerators/Vtkm/DataModel/vtkmlib/ArrayConverters.h")
55 endif()
56
57 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
58  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkmlib" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Accelerators/Vtkm/DataModel/vtkmlib/CellSetConverters.h")
59 endif()
60
61 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
62  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkmlib" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Accelerators/Vtkm/DataModel/vtkmlib/DataSetConverters.h")
63 endif()
64
65 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
66  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkmlib" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Accelerators/Vtkm/DataModel/vtkmlib/ImageDataConverter.h")
67 endif()
68
69 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
70  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkmlib" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Accelerators/Vtkm/DataModel/vtkmlib/ImplicitFunctionConverter.h")
71 endif()
72
73 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
74  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkmlib" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Accelerators/Vtkm/DataModel/vtkmlib/PolyDataConverter.h")
75 endif()
76
77 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
78  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13/vtkmlib" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Accelerators/Vtkm/DataModel/vtkmlib/UnstructuredGridConverter.h")
79 endif()
80
81 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
82  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-5.13" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTK/Accelerators/Vtkm/DataModel/vtkAcceleratorsVTKmDataModelModule.h")
83 endif()
84
85 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
86  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkAcceleratorsVTKmDataModel-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkAcceleratorsVTKmDataModel-hierarchy.txt")
87 endif()
88
89 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
90  foreach(file
91  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkAcceleratorsVTKmDataModel-pv5.13.so.5.13"
92  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkAcceleratorsVTKmDataModel-pv5.13.so.1"
93  )
94  if(EXISTS "${file}" AND
95  NOT IS_SYMLINK "${file}")
96  file(RPATH_CHECK
97  FILE "${file}"
98  RPATH "\$ORIGIN")
99  endif()
100  endforeach()
101  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
102  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkAcceleratorsVTKmDataModel-pv5.13.so.5.13"
103  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkAcceleratorsVTKmDataModel-pv5.13.so.1"
104  )
105  foreach(file
106  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkAcceleratorsVTKmDataModel-pv5.13.so.5.13"
107  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkAcceleratorsVTKmDataModel-pv5.13.so.1"
108  )
109  if(EXISTS "${file}" AND
110  NOT IS_SYMLINK "${file}")
111  file(RPATH_CHANGE
112  FILE "${file}"
113  OLD_RPATH "\$ORIGIN:"
114  NEW_RPATH "\$ORIGIN")
115  if(CMAKE_INSTALL_DO_STRIP)
116  execute_process(COMMAND "/usr/bin/strip" "${file}")
117  endif()
118  endif()
119  endforeach()
120 endif()
121
122 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
123  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkAcceleratorsVTKmDataModel-pv5.13.so" AND
124  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkAcceleratorsVTKmDataModel-pv5.13.so")
125  file(RPATH_CHECK
126  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkAcceleratorsVTKmDataModel-pv5.13.so"
127  RPATH "\$ORIGIN")
128  endif()
129  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkAcceleratorsVTKmDataModel-pv5.13.so")
130  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkAcceleratorsVTKmDataModel-pv5.13.so" AND
131  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkAcceleratorsVTKmDataModel-pv5.13.so")
132  file(RPATH_CHANGE
133  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkAcceleratorsVTKmDataModel-pv5.13.so"
134  OLD_RPATH "\$ORIGIN:"
135  NEW_RPATH "\$ORIGIN")
136  if(CMAKE_INSTALL_DO_STRIP)
137  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkAcceleratorsVTKmDataModel-pv5.13.so")
138  endif()
139  endif()
140 endif()
141
142 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xlicensesx" OR NOT CMAKE_INSTALL_COMPONENT)
143  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/licenses/ParaView/vtkAcceleratorsVTKmDataModel" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/VTK/Accelerators/Vtkm/DataModel/LICENSE")
144 endif()
145
