1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core
47  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkAxis.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkAxisExtended.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkCategoryLegend.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkChart.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkChartBox.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkChartHistogram2D.h"
53  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkChartLegend.h"
54  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkChartMatrix.h"
55  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkChartParallelCoordinates.h"
56  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkChartPie.h"
57  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkChartXY.h"
58  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkChartXYZ.h"
59  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkColorLegend.h"
60  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkColorTransferControlPointsItem.h"
61  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkColorTransferFunctionItem.h"
62  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkCompositeControlPointsItem.h"
63  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkCompositeTransferFunctionItem.h"
64  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkContextArea.h"
65  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkContextPolygon.h"
66  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkControlPointsItem.h"
67  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkInteractiveArea.h"
68  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkLookupTableItem.h"
69  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPiecewiseControlPointsItem.h"
70  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPiecewiseFunctionItem.h"
71  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPiecewisePointHandleItem.h"
72  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlot.h"
73  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlot3D.h"
74  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlotArea.h"
75  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlotBag.h"
76  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlotBar.h"
77  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlotBarRangeHandlesItem.h"
78  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlotBox.h"
79  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlotFunctionalBag.h"
80  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlotGrid.h"
81  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlotHistogram2D.h"
82  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlotLine.h"
83  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlotLine3D.h"
84  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlotParallelCoordinates.h"
85  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlotPie.h"
86  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlotPoints.h"
87  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlotPoints3D.h"
88  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlotRangeHandlesItem.h"
89  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlotStacked.h"
90  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkPlotSurface.h"
91  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkRangeHandlesItem.h"
92  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkScalarsToColorsItem.h"
93  "/builds/gitlab-kitware-sciviz-ci/VTK/Charts/Core/vtkScatterPlotMatrix.h"
94  "/builds/gitlab-kitware-sciviz-ci/build/VTK/Charts/Core/vtkChartsCoreModule.h"
95  )
96 endif()
97
98 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
99  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkChartsCore-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkChartsCore-hierarchy.txt")
100 endif()
101
102 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
103  foreach(file
104  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkChartsCore-pv5.13.so.5.13"
105  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkChartsCore-pv5.13.so.1"
106  )
107  if(EXISTS "${file}" AND
108  NOT IS_SYMLINK "${file}")
109  file(RPATH_CHECK
110  FILE "${file}"
111  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
112  endif()
113  endforeach()
114  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
115  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkChartsCore-pv5.13.so.5.13"
116  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkChartsCore-pv5.13.so.1"
117  )
118  foreach(file
119  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkChartsCore-pv5.13.so.5.13"
120  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkChartsCore-pv5.13.so.1"
121  )
122  if(EXISTS "${file}" AND
123  NOT IS_SYMLINK "${file}")
124  file(RPATH_CHANGE
125  FILE "${file}"
126  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
127  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
128  if(CMAKE_INSTALL_DO_STRIP)
129  execute_process(COMMAND "/usr/bin/strip" "${file}")
130  endif()
131  endif()
132  endforeach()
133 endif()
134
135 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
136  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkChartsCore-pv5.13.so" AND
137  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkChartsCore-pv5.13.so")
138  file(RPATH_CHECK
139  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkChartsCore-pv5.13.so"
140  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
141  endif()
142  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkChartsCore-pv5.13.so")
143  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkChartsCore-pv5.13.so" AND
144  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkChartsCore-pv5.13.so")
145  file(RPATH_CHANGE
146  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkChartsCore-pv5.13.so"
147  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
148  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
149  if(CMAKE_INSTALL_DO_STRIP)
150  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkChartsCore-pv5.13.so")
151  endif()
152  endif()
153 endif()
154
