1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTK/Common/Misc
47  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Misc/vtkContourValues.h"
48  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Misc/vtkErrorCode.h"
49  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Misc/vtkExprTkFunctionParser.h"
50  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Misc/vtkFunctionParser.h"
51  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Misc/vtkHeap.h"
52  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Misc/vtkPolygonBuilder.h"
53  "/builds/gitlab-kitware-sciviz-ci/VTK/Common/Misc/vtkResourceFileLocator.h"
54  "/builds/gitlab-kitware-sciviz-ci/build/VTK/Common/Misc/vtkCommonMiscModule.h"
55  )
56 endif()
57
58 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
59  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkCommonMisc-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkCommonMisc-hierarchy.txt")
60 endif()
61
62 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xruntimex" OR NOT CMAKE_INSTALL_COMPONENT)
63  foreach(file
64  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.13.so.5.13"
65  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.13.so.1"
66  )
67  if(EXISTS "${file}" AND
68  NOT IS_SYMLINK "${file}")
69  file(RPATH_CHECK
70  FILE "${file}"
71  RPATH "\$ORIGIN")
72  endif()
73  endforeach()
74  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
75  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkCommonMisc-pv5.13.so.5.13"
76  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkCommonMisc-pv5.13.so.1"
77  )
78  foreach(file
79  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.13.so.5.13"
80  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.13.so.1"
81  )
82  if(EXISTS "${file}" AND
83  NOT IS_SYMLINK "${file}")
84  file(RPATH_CHANGE
85  FILE "${file}"
86  OLD_RPATH "\$ORIGIN:"
87  NEW_RPATH "\$ORIGIN")
88  if(CMAKE_INSTALL_DO_STRIP)
89  execute_process(COMMAND "/usr/bin/strip" "${file}")
90  endif()
91  endif()
92  endforeach()
93 endif()
94
95 if("x${CMAKE_INSTALL_COMPONENT}x" STREQUAL "xdevelopmentx" OR NOT CMAKE_INSTALL_COMPONENT)
96  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.13.so" AND
97  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.13.so")
98  file(RPATH_CHECK
99  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.13.so"
100  RPATH "\$ORIGIN")
101  endif()
102  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkCommonMisc-pv5.13.so")
103  if(EXISTS "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.13.so" AND
104  NOT IS_SYMLINK "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.13.so")
105  file(RPATH_CHANGE
106  FILE "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.13.so"
107  OLD_RPATH "\$ORIGIN:"
108  NEW_RPATH "\$ORIGIN")
109  if(CMAKE_INSTALL_DO_STRIP)
110  execute_process(COMMAND "/usr/bin/strip" "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkCommonMisc-pv5.13.so")
111  endif()
112  endif()
113 endif()
114
